[geos-devel] Exception Issues
Norman Vine
nhv at cape.com
Tue May 27 18:21:12 EDT 2003
David Blasby writes:
> > Questions:
> > 1) What version of gcc are you using
> 2.96
FWIW AFAIK:
2.96 is a Redhat variaty and is not an official release of gcc
also the current 3.2 is I believe *much* more C++ standard compliant
> > 2) What happens if you link PostgreSQL against -lsupc++
> > instead of -lstdc++
> I dont think we have that library. What is it?
here is a 'good' explanation
http://gcc.gnu.org/ml/gcc/2000-12/msg00714.html
Note this is part of gcc since 3.0
http://gcc.gnu.org/gcc-3.0/features.html
HTH
Norman
