[geos-devel] GEOS Todo
Norman Vine nhv at cape.com
Tue May 27 18:49:16 EDT 2003
David Blasby writes:
> There are two outstanding issues in GEOS:
> 1. memory management.  This is high priority.
Using the c++ autoptr or a homegrown equivalant
would help *alot* here
> 2. GEOS writes out debugging information like this:
3: Moving everything into a GEOS namespace
This is the easiest and *best* method of preventing
namespace clashes which will happen eventually if
this 'good software practice' isn't followed
The longer this modification is postponed the more difficult
and disruptive the change will become
Cheers
Norman
