[geos-devel] is this a bug polygon intersection?
strk strk at keybit.net
Wed Nov 12 13:45:10 EST 2003
pramsey wrote:
> Stuff it through jts1.3, that is the code base which matches the current
> geos. Then stuff it through 1.4 and see if it's fixed :)
> P.
How is JTS-stuffing done ? :>
Is there any ready unix utility for xml runs ?
--strk;
> strk wrote:
> > strk wrote:
> >>jingping.xie wrote:
> >>>an exception was got:
> >>>Microsoft C++ exception: geos::TopologyException @ 0x0012e5e0。
> >>Messages is [ exception->toString() ]:
> >>	TopologyException: side location conflict (16200,45000)
> > I tried importing xie's test data into PostGIS and I get a different message:
> > 	TopologyException: no outgoing dirEdge found (17000,46000)
> > It might be related to the PrecisionModel used.
> > Does any bell rings ?
> > --strk
> > geos-devel mailing list
> > geos-devel at geos.refractions.net
> > http://geos.refractions.net/mailman/listinfo/geos-devel
>        __
>       | Paul Ramsey
>       | Refractions Research
>       | Email: pramsey at refractions.net
>       | Phone: (250) 885-0632
>       \_
pallamondo.net  <-- take a look !
