[geos-devel] relational operators in example.cpp
strk strk at keybit.net
Thu Nov 13 07:02:57 EST 2003
strk wrote:
> I've added relational operators example usage in doc/example.cpp
> as usual, this showed some more leaks on exception throwing.
I was wrong. the example code was making the wrong call.
It has now been fixed. Contextually added both relate calls
(with and without intersection pattern).
--strk;
