[geos-devel] Help with Compiling
Steffen Macke
sdteffen at web.de
Sun Nov 30 16:16:19 EST 2003
> I recently downloaded Geos Library and have installed the same on linux
> 8.0. However, I am having problems compiling the source examples. I have
> followed all the instructions given in the install file: a) configured with
> env CPPFLAGS=-I/usr/local/include LDFLAGS=-s ./configure b) did a make
did you try only the following?
./configure
make
make install
What Linux are your running? Which compiler version are you using? You can get
the version with the following command:
g++ -v
Steffen
