[geos-devel] is this a big leak?
Yury A. Bychkov me at yury.ca
Wed Oct 1 03:47:40 EDT 2003
Yes, there is a leak in some of the overlay operations. It showed up in one of
the recent versions after a bugfix. I've been trying to plug it for some time
now, but it's rather weird so it'll probably take a couple more days.
Yury
----- Original Message -----
To: <geos-devel at geos.refractions.net>; "strk" <strk at keybit.net>
Sent: Tuesday, September 30, 2003 5:00 PM
Subject: [geos-devel] is this a big leak?
> Yuri,
> Find attached a program that creates a bunch of multipolygons and unions
> them together.
> It appears to leak memory quite quickly. Valgrind says:
> ==3035== 267096 bytes in 41 blocks are still reachable in loss record 14
> of 14
> ==3035==    at 0x40168BBF: malloc (vg_clientfuncs.c:103)
> ==3035==    by 0x804AECA: __default_alloc_template<true,
> 0>::_S_chunk_alloc(unsigned int, int &) (/usr/include/g++-3/stl_alloc.h:490)
> ==3035==    by 0x804ACAB: __default_alloc_template<true,
> 0>::_S_refill(unsigned int) (/usr/include/g++-3/stl_alloc.h:531)
> ==3035==    by 0x402D82FB: basic_string<char, string_char_traits<char>,
> __default_alloc_template<true, 0> >::replace(unsigned int, unsigned int,
> char const *, unsigned int) (/usr/include/g++-3/stl_alloc.h:332)
> ==3035==    by 0x402CE628: __static_initialization_and_destruction_0
> (/usr/include/g++-3/std/bastring.h:223)
> ==3035==    by 0x402CEAB1:
> geos::TopologyValidationError::TopologyValidationError(int,
> geos::Coordinate) (/usr/include/g++-3/stl_map.h:76)
> ==3035==    by 0x402D7424: (within /raid/local/lib/libgeos.so.1.0.0)
> ==3035==    by 0x4000CA20: _dl_init (dl-init.c:70)
> ==3035==    by 0x400012F0: (within /lib/ld-2.2.4.so)
> ==3035==
> ==3035== LEAK SUMMARY:
> ==3035==    definitely lost: 0 bytes in 0 blocks.
> ==3035==    possibly lost:   0 bytes in 0 blocks.
> ==3035==    still reachable: 267936 bytes in 54 blocks.
> ==3035==         suppressed: 0 bytes in 0 blocks.
> ==3035==
> I assume this is a leak of some sort - its a bit of a funny leak.
> dave
> // g++ -g test6.cpp -I/usr/local/include/geos -lgeos; ./a.out
> // g++ -g test6.cpp -I/usr/local/include/geos -lgeos ;
valgrind --leak-check=yes --num-callers=10 ./a.out
> #include "stdio.h"
> #include "io.h"
> #include "geom.h"
> using namespace geos;
> double global_offset = 0;
>     PrecisionModel *pm= new PrecisionModel();
> GeometryFactory *geomFactory = new GeometryFactory( pm, -1);
> //create a simple multi-polygon
> // offset shift the polygon to the left <offset> units
> // MULTIPOLYGON (((0.0000000000000000 0.0000000000000000, 10.0000000000000000
0.0000000000000000, 10.0000000000000000 10.0000000000000000, 0.0000000000000000
10.0000000000000000, 0.0000000000000000 0.0000000000000000), (2.0000000000000000
2.0000000000000000, 4.0000000000000000 2.0000000000000000, 4.0000000000000000
4.0000000000000000, 2.0000000000000000 4.0000000000000000, 2.0000000000000000
2.0000000000000000)))
> Geometry *a(double offset)
> Geometry *g1, *g2 ;
>     Coordinate *c;
>     CoordinateList *cl;
>     LinearRing *outerRing;
>     vector<Geometry *> *innerRings=new vector<Geometry *>;
> LinearRing *innerRing;
>     vector<Geometry *> *polys=new vector<Geometry *>;
> cl = new BasicCoordinateList(5);
> c = new Coordinate(0+offset, 0);
> cl->setAt( *c ,0);
> delete c;
> c = new Coordinate(10+offset, 0);
> cl->setAt( *c ,1);
> delete c;
> c = new Coordinate(10+offset, 10);
> cl->setAt( *c ,2);
> delete c;
> c = new Coordinate(0+offset, 10);
> cl->setAt( *c ,3);
> delete c;
> cl->setAt( *c ,4);
> delete c;
> outerRing = (LinearRing*) geomFactory->createLinearRing(cl);
> c = new Coordinate(2+offset, 2);
> cl->setAt( *c ,0);
> delete c;
> c = new Coordinate(4+offset, 2);
> cl->setAt( *c ,1);
> delete c;
> c = new Coordinate(4+offset, 4);
> cl->setAt( *c ,2);
> delete c;
> c = new Coordinate(2+offset, 4);
> cl->setAt( *c ,3);
> delete c;
> cl->setAt( *c ,4);
> delete c;
> innerRing = (LinearRing *) geomFactory->createLinearRing(cl);
> innerRings->push_back(innerRing);
> g1 = geomFactory->createPolygon(outerRing, innerRings);
> polys->push_back(g1);
> g2 = geomFactory->createMultiPolygon(polys);
> return g2;
> //unions
> //    aa  AND
> //    a new geometry, which is the standard multipolygon translated to the
right
> Geometry *op(Geometry *aa)
> Geometry  *bb, *cc;
> bb = a(global_offset);
> //15 ==> leaks a lot
> //5  ==> leaks a constant amount
> global_offset += 15;
> cc = aa->Union(bb);
> delete aa;
> delete bb;
> return cc;
> int main(int argC, char* argV[])
> Geometry *aa;
> aa = a(global_offset);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> aa = op(aa);
> string s= aa->toString();
> cout << "geom1 == "<<s << endl;
> delete aa;
> delete geomFactory;
> delete pm;
> geos-devel mailing list
> http://geos.refractions.net/mailman/listinfo/geos-devel
