[geos-devel] GeometryCollection constructor
Norman Vine
nhv at cape.com
Wed Oct 8 06:54:51 EDT 2003
strk writes:
> Constructing a GeometryCollection from a vector of Geometry pointer
> right now will just copy the pointer to that vector to private
> space, this mean that after having constructed the geometries forming
> the collection and having put them in a vector you pass the
> vector to new GeometryCollection and you are left with pointers to
> memory that from now on should be manipulated only by the
> GeometryCollection object.
> I don't think this is correct. Latest postgis tries to delete the
> vector used to contain child geoms and thus segfaults. I patched
> GeometryCollection to copy the actual vector, not just the pointer,
> but my question is: should memory copy go further copying each
> object in the vector instead of just the vector itself ?
Ack...
I thought we were going to use reference counted pointers
just so we could *safely* pass pointers instead of objects around
and not have to worry about objects being prematurely deleted
or conversely needlessly left on the heap !!
Cheers
Norman
