[geos-devel] use of const in GeometryFactory constructor
strk strk at keybit.net
Thu Oct 9 12:55:40 EDT 2003
Ok, problems with compiler seems to be gone (dunno how)...
I've already added a const keyword to PrecisionModel *
argument of GoemetryFactory constructor.
Right now I'm in the process of formalizing the const nature
of the CoordinateList * passed to the LineString constructor,
and this is being really really long ... it is tainting the
whole code set !
.. we might have found a good way to consistency ..
--strk;
nhv wrote:
> strk writes:
> > GeometryFactory(PrecisionModel * newPrecisionModel, int SRID)
> > Will copy the PrecisionModel arg into private space.
> > The arguments naming convention used elsewere makes you think
> > the PresionModel object has to be created on purpose and thus
> > that you'll have to forget about it. Anyway this is not the
> > actual implementation and I don't know about usage of it
> > by other GEOS parts.
> > As a test, I tried to "formalize" the implementation behaviour
> > adding a 'const' in front of the first arg both in GeometryFactory.cpp
> > and geom.h (and changing the name of it to disambiguate meaning).
> > The library resulted by this was corrupted, when trying to run a
> > linked executable I got:
> > ./example: error while loading shared libraries: ./example: undefined symbol:
> > __Q24geos15GeometryFactoryPQ24geos14PrecisionModeli
> > Question 1: do you think using 'const' there is the right way to go ?
> Most likely
> http://www.parashift.com/c++-faq-lite/const-correctness.html
> > Question 2: do you think I've a bogus compiler ? (gcc-2.96)
> If it hasn't been patched *yes* 2.96 was a RedHat special that needed patching
> from it's original release < note this was not an official gnu release >
> check RedHat site for needed patches
> http://gcc.gnu.org/gcc-2.96.html
> The *real* 3.x series is *much* more C++ standard conformant and seems
> to produce slightly faster code esp on the newer procesors
> If you do upgrade I reccomend 3.3.1 < the current release >
> http://gcc.gnu.org/gcc-3.3/changes.html
> Norman
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
