[geos-devel] Still Leaking in PostGIS
Paul Ramsey
pramsey at refractions.net
Sun Oct 19 11:59:18 EDT 2003
In an adhoc way. Since Yury does not use it, either me or Norman have
been putting it back in order after major commits.
On Sunday, October 19, 2003, at 03:14 AM, strk wrote:
> pramsey wrote:
>> I loaded up a polygon table, and then did this:
>> select wb_id from csn_waterbodies where isvalid(the_geom) limit
>> 100;
>> I did this over and over. Each time, the postgres instance I was
>> connected to got a little bit larger. Probably this is repeatable with
>> any data set at all, but I can provide the 100 records I used if
>> necessary.
>> P.
> We should inspect stdlibc++ "smart" automatic memory
> caching/management.
> I think if we can keep lib/compiler from using this "feature" (as an
> option
> at compile/run time) it will be easier to debug these kind of leaks.
> PS: is anybody mantaining the build system ?
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
