[geos-devel]
[Horst.Duester@bd.so.ch: AW: [postgis-users] Dissolve obsolete
polygon borders]
strk
strk at keybit.net
Tue Oct 21 10:53:12 EDT 2003
Are these bugs or normal administration ?
I mean: does it have to do with malformed/unsupported input geometries
or with bogus GEOS code ? Any hint on this ?
Horst, please, continue this on the mailing list.
--strk;
----- Forwarded message from Düster Horst <Horst.Duester at bd.so.ch> -----
To: "'strk'" <strk at keybit.net>
Subject: AW: [postgis-users] Dissolve obsolete polygon borders
Date: Tue, 21 Oct 2003 11:23:30 +0100
strk
Now Postgis responses with the following NOTICE/MESSAGE
NOTICE: TopologyException: side location conflict (628374,239597)
ERROR: GEOS union() threw an error!
Horst
-----Ursprüngliche Nachricht-----
Von: strk [mailto:strk at keybit.net]
Gesendet am: Montag, 20. Oktober 2003 15:05
An: Düster Horst
Cc: geos-devel at geos.refractions.net
Betreff: Re: [postgis-users] Dissolve obsolete polygon borders
There are two cases for this to happen, can you update your GEOS sources
and try again (a more explicit exception message have been introduced)
--strk;
Horst.Duester wrote:
> strk
> I recompiled GEOS and PostGIS and tied to dissolve the large table. Now
> responsed with a NOTICE:
> NOTICE: AssertionFaiedException: found null Directed Edge
> Horst
> Gesendet am: Donnerstag, 16. Oktober 2003 16:57
> An: Düster Horst
> Do you have heterogeneous geometries in your table ?
> --stkr;
> > Ok. Now I tried to dissolve a large table with more than 80'000 Records.
> > After nearly 20 Minutes of processing time PostGIS breakes with
> > A NOTICE didn't appear.
> > Horst
> > Gesendet am: Donnerstag, 16. Oktober 2003 16:16
> > An: Düster Horst
> > Didn't you get an Exception thrown ?
> > > Thank you for your response. I doesn't work, PostgreSQL responses with
> > > "GEOS union() threw an error!".
> > Please, check if that error is now more meaningful.
> > A NOTICE should appear right before that response.
> > --strk;
> > > Yes, great now it works and I'm able to dissolve my geometry. Thank
you
> > very
> > > much for your efforts and your time you spent for me.
> > > Horst
> > > Gesendet am: Donnerstag, 16. Oktober 2003 08:21
> > > An: PostGIS Users Discussion
> > > Cc: Horst.Duester at bd.so.ch
> > > > strk
with
> > > > Horst
> > > Try downloading the latest postgis from CVS repository, it now
contains
> > > new code to show a more meaningful message (thanks Dave).
> > > --strk;
> > > > Gesendet am: Mittwoch, 15. Oktober 2003 14:58
> > > > Try this:
> > > > CREATE AGGREGATE unite (
> > > > sfunc = GeomUnion,
> > > > basetype = geometry,
> > > > stype = geometry
> > > > ); -- this creates an aggregate out of GEOS's geomunion()
> > > > -- and this is your query
> > > > SELECT your_attribute, unite(the_geom)
> > > > FROM your_table
> > > > GROUP BY your_attribute;
> > > > Note that GEOS cvs version is pretty memory absorbing (actually
> leaking)
> > > > and probably also buggy. Please let me know whether it worked for
you.
> > > > --strk;
> > > > > Is there a way to dissolve obsolete borders between polygons with
> > equal
> > > > > attributes??
> > > > > I will appreciate your hints.
> > > > > Horst
> > > > > _______________________________________________
> > > > > postgis-users mailing list
> > > > > postgis-users at postgis.refractions.net
> > > > > http://postgis.refractions.net/mailman/listinfo/postgis-users
----- End forwarded message -----
