[geos-devel] AW:Dissolve obsolete polygon borders
strk
strk at keybit.net
Tue Oct 21 12:23:28 EDT 2003
mbdavis wrote:
> Again, this is almost certainly a robustness issue. Robustness issues typically surface in cases where there is linework in two polygons which is very similar, but not identical. About all you can do is to fix the linework so that the vertices are either identical or further apart.
Is JCS capable of automating this process ?
--strk;
