[geos-devel] AW:Dissolve obsolete polygon borders
Martin Davis
mbdavis at VividSolutions.com
Tue Oct 21 13:20:29 EDT 2003
JCS contains a CoverageCleaning API & GUI, which allows fixing this kind of error. However, it's not 100% automatic - it can fix about 95% of problems automatically, but in some cases manual input is still required.
Martin Davis, Senior Technical Architect
Vivid Solutions Inc.
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 Fax: (250) 385 6046
> -----Original Message-----
> From: strk [mailto:strk at keybit.net]
> Sent: Tuesday, October 21, 2003 9:23 AM
> To: GEOS Development List
> Subject: Re: [geos-devel] AW:Dissolve obsolete polygon borders
> mbdavis wrote:
> > Again, this is almost certainly a robustness issue.
> Robustness issues typically surface in cases where there is
> linework in two polygons which is very similar, but not
> identical. About all you can do is to fix the linework so
> that the vertices are either identical or further apart.
> Is JCS capable of automating this process ?
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
