[geos-devel] fastunion aggregate
Paul Ramsey
pramsey at refractions.net
Mon Oct 27 13:57:14 EST 2003
Go for it.
P.
strk wrote:
> pramsey wrote:
>>strk wrote:
>>>If 'fastunion' is a good name for you I'll commit, so we can test
>>>togheter.
>>Lets think about this. If the fastunion in fact takes up no more space
>>than the regular union, then perhaps we can simply use it with the name
>>as the geomunion(A,B)?
>>Then we have:
>>geomunion(A,B)
>>geomunion(recordset)
>>memgeomunion(recordset) for the future slow'n'steady version?
> I can do the following:
> - commit changes to geomUnion() for soon-memory-release
> - commit support routines for "fast" union
> - post on the mailing list SQL query to enable/disable "fast" union
> In this way we can test both of them on different dataset.
> Fundamentally the point is the the "WORST" case memory occupation
> will be about the same, while the "BEST" case memory occupation
> will be MUCH less with the old code.
> Imagine 3000 square polygons whose union makes a rectangle :)
> Old way will take up (releasing memory soon) a rectangle size memory.
> New way will take up 3000 * square size memory (before staring to release it)
> What do you think ?
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
