[geos-devel] Solaris
Dave Blasby dblasby at refractions.net
Wed Oct 29 02:36:46 EST 2003
> (gdb) run
Ooops - forgot to tell you to type "r" (or run) to start the program!
> Starting program: /var/home/office/geos/source/test/.libs/./XMLTester
> Program received signal SIGABRT, Aborted.
> #6  0x15e98 in main (argC=-268436416, argV=0xeffffc38) at XMLTester.cpp:109
Hum - not so helpfull.  Sounds like something major is very wrong.  Perhaps
the ./configure is bad?  Are all the libraries being linked properly?
- SIGABRT sounds like a C++ exception being thrown instead of segfault.
- argC=-268436416 implies either that the program started "very wrong" or
memory has been corrupted.
dave
