AW: AW: [geos-devel] automake error??
Paul Ramsey pramsey at refractions.net
Wed Sep 3 11:41:25 EDT 2003
Strange, when I manually run my automatic script, I get the configure,
but when cron does it, I do not. There's one there now, and hopefully I
have fixed the problem.
P.
Düster Horst wrote:
> Paul
> I can't find a ./configure script in the snap shot 20030903
> geos-cvs.tar.gz?????
> Horst
> -----Ursprüngliche Nachricht-----
> Von: Paul Ramsey [mailto:pramsey at refractions.net]
> Gesendet am: Dienstag, 2. September 2003 17:06
> An: GEOS Development List
> Betreff: Re: AW: [geos-devel] automake error??
> If you are going to run autogen.sh, you should really replace the stock
> automake, libtool, aclocal and autoconf with the latest versions. It
> works much much nicer then. Just "rpm -e" the old ones and install the
> new ones from source.
> Failing that, the CVS daily snaphot now includes a ./configure script
> which hopefully should be plug'n'play.
> P.
> Düster Horst wrote:
>>Norman,
>>I ask this question due to I'm not able to compile GEOS. You say automake
> is
>>OK. I think that configure runs OK but the compilation process breaks with
> a
>>lot of error messages I sent to the list some days ago. It was my last
> hope
>>that these messages were the cause of the compilation error.
>>I believe that automake creates a wrong link path to the compiled objects.
>>The error message says p.e.:
>>gcc: ../algorithm/CentroidArea.lo: No such file or directory
>>and occurs for all *.lo objects. All these objects were stored in the
>>directory ../geom but not in the expected directories like
>>../algorithm
>>../graph
>>etc.
>>where the source is located.
>>Perhaps you can help to find a solution.
>>My system:
>>redhat 7.2
>>Horst
>>Von: Norman Vine [mailto:nhv at cape.com]
>>Gesendet am: Dienstag, 2. September 2003 16:37
>>Betreff: RE: [geos-devel] automake error??
>>Düster Horst writes:
>>>Hallo all
>>>When running autogen.sh automake-1.4-p5 reports the following messages:
>>>automake: configure.in: installing `./install-sh'
>>>automake: configure.in: installing `./mkinstalldirs'
>>>automake: configure.in: installing `./missing'
>>>configure.in: 160: installing `./config.guess
>>>What's the meaning of these messages??
>>automake is copying < or making symlinks > some files
>>to the GEOS directory
>>These files may be different depending on the automake
>>version you are using
>>This is normal behaviour
>>see
>>% info automake
>>HTH
>>Norman
>>_______________________________________________
>>geos-devel mailing list
>>geos-devel at geos.refractions.net
>>http://geos.refractions.net/mailman/listinfo/geos-devel
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
