[geos-devel] Re: gettimeofday for win32
Paul Ramsey pramsey at refractions.net
Fri Dec 3 10:47:17 EST 2004
It's sufficiently far behind reality at this point that I don't see the
point in including it in the built distribution. It's obtainable in CVS
is anyone wants to update it.
On Friday, December 3, 2004, at 02:28 AM, strk at refractions.net wrote:
> On Thu, Dec 02, 2004 at 09:22:27AM -0500, Frank Warmerdam wrote:
>> I don't see any VisualStudio directory in the 2.1.0 distribution.   Is
>> it only available in CVS?  I don't really want a project/workspace
>> file anyways, though I suppose if it worked smoothly enough it
>> would do.
> I confirm it's not included in the distribution.
> Paul, should it ?
>>  o The definition of int64 in platform.h lacks a win32 case.
>>  o The use of the long long static uid in various items in geom.h
>> caused
>>     a problem.   I just hacked out the UIDs as they don't seem to
>> have any
>>     purpose.
> That is mainly Martin's way of versioning classes.
> Anyway a 64-bit int type is needed for the DoubleBits class, better
> to handle win32 case in platform.h.
>>  o The base class toVector() returns a const result while the
>> overrides return
>>     non-const. I had to change the base to non-const as well, though
>> I am
>>     not clear what the original intent was.
> We should probably have two methods:
>         const vector<Coordinate>* toVector() const;
>         vector<Coordinate>* toVector();
> --strk;
>>  o Some problems with time stuff for the profiler.  It was your
>> mention of
>>     this that made me think you were building on win32 as well.
>> I haven't gone back to try things on VC6 but if I do, i will
>> keep the stlport thing in mind.  I do my FWTools builds with
>> VC6, so if I am to GEOS enable that distribution I will need to
>> solve VC6 builds.
>> Best regards,
>> I set the clouds in motion - turn up   | Frank Warmerdam,
>> warmerdam at pobox.com
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush    | Geospatial Programmer for
>> Rent
>> geos-devel mailing list
>> geos-devel at geos.refractions.net
>> http://geos.refractions.net/mailman/listinfo/geos-devel
      Paul Ramsey
      Refractions Research
      Email: pramsey at refractions.net
      Phone: (250) 885-0632
