[geos-devel] GEOS Microsoft Visual C++.NET Port Working
strk at refractions.net
Sat Dec 4 10:55:47 EST 2004
On Fri, Dec 03, 2004 at 11:35:45AM -0500, Frank Warmerdam wrote:
> I have commited a source/Makefile.vc and source/headers/geos/platform.h.vc
> that allow building GEOS with MSCV .NET at the commandline. Just
> cd into source, run VCVARS32.BAT (or whatever it is called for VS.NET)
> and then "nmake /f makefile.vc".
> If you have an existing platform.h in headers/geos you will need to
> remove it first, so it can be replaced by platform.h.vc. It seemed
> that the geos 2.1.0 tarball included a platform.h though I don't think
> it is supposed to.
I've added the Makefile.vc and platform.h.vc file into the distribution
togheter with the VisualStudio directory already present.
The generated platform.h and version.h have been removed (platform.h.in
and version.h.in are still there).
--strk;
