[geos-devel] Problem compiling geos on Gentoo Linux
SIGéal sigeal at sigeal.fr
Mon Dec 6 08:29:05 EST 2004
I upgraded automake and autoconf, and finally got it to work
Thanks for your very quick answer.
Christophe Damour (SIGéal)
"Chez Charles"
16480 Saint Laurent des Combes
Téléphone : 05 45 98 36 06
Télécopie : 05 45 98 36 07
Courriel : sigeal at sigeal.fr
strk at refractions.net a écrit :
> On Mon, Dec 06, 2004 at 10:08:02AM +0100, SIGéal wrote:
>>Hi,
>>I am trying to compile it on gentoo (kernel 2.6) and I couldn't succeed...
>>I get that error when I make geos (2.1.0) :
>>./configure: line 8673: syntax error near unexpected token 'long'
>>./configure: line 8673: 'PGAC_TYPE_64BIT_INT' (long int)
>>I found that error in a couple of forums, but no clue to solve it. Is it
>>a version problem ? Or did I miss something ?
>>I use :
>>- automake 1.8.3
>>- autoconf 2.13
>>- libtoolize 1.4.3
>>- gcc 3.3.3
>>Thank you for your help.
> Try upgrading autoconf. I've read an old thread about this problem and
> it seemd that autoconf was not expanding that macro, found in acsite.m4.
> As an alternative, re-extract your package and run ./configure again, you
> shouldn't be running autoconf/automake manually anyway.
> --strk;
>>SIGéal
>>"Chez Charles"
>>_______________________________________________
>>geos-devel mailing list
>>geos-devel at geos.refractions.net
>>http://geos.refractions.net/mailman/listinfo/geos-devel
