[geos-devel] geos in Pythoon
Niki Spahiev niki.spahiev at gmail.com
Wed Dec 15 12:51:07 EST 2004
Proposed changes to swig module. Attached is translation of
example.cpp which generates exact same output.
There are some problems with createPolygon() overloading. Uncommenting
%ignore line in geos.i:33 throws strange exception.
 * $Id: geos.i,v 1.3 2004/07/26 18:53:38 sgillies Exp $
 * geos.i
 * Copyright 2004 Sean Gillies, sgillies at frii.com
 * Interface for a SWIG generated geos module.
 * This is free software; you can redistribute and/or modify it under
 * the terms of the GNU Lesser General Public Licence as published
 * by the Free Software Foundation.
 * See the COPYING file for more information.
%module geos
%include "std_string.i"
%include "std_vector.i"
%include "exception.i"
#include "../../source/headers/geos.h"
// Following methods are prototypes but unimplemented and are to be ignored
%ignore geos::MultiPoint::isClosed;
// no transfer of ownership
%ignore geos::GeometryFactory::createPoint(CoordinateSequence *) const;
%ignore geos::GeometryFactory::createLineString(CoordinateSequence *) const;
%ignore geos::GeometryFactory::createLinearRing(CoordinateSequence *) const;
//~ %ignore geos::GeometryFactory::createPolygon(LinearRing *,vector<Geometry * > *) const;
%ignore geos::GeometryFactory::createGeometryCollection(vector<Geometry * > *) const;
%ignore geos::GeometryFactory::buildGeometry(vector<Geometry * > *) const;
%ignore geos::GeometryFactory::createMultiPoint(vector<Geometry * > *) const;
%ignore geos::GeometryFactory::createMultiLineString(vector<Geometry * > *) const;
%ignore geos::GeometryFactory::createMultiLinearRing(vector<Geometry * > *) const;
%ignore geos::GeometryFactory::createMultiPolygon(vector<Geometry * > *) const;
// Required renaming
%rename(Coordinate_Coordinate) Coordinate::Coordinate;
%exception {
    try {
        $action
    catch (geos::GEOSException *e) {
        SWIG_exception(SWIG_RuntimeError, e->toString().data());
// Now include the headers to be wrapped
%include "../../source/headers/geos/geom.h"
%include "../../source/headers/geos/util.h"
%include "../../source/headers/geos/io.h"
//~ template<class T>
//~ class vector {
//~ public:
    //~ vector();
    //~ ~vector();
    //~ void push_back(const T obj);
    //~ void reserve(size_t n);
%template(vector_GeometryP) vector<geos::Geometry *>;
Type: application/x-python
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20041215/995961f5/example.bin
