AW: [geos-devel] OGR and Shape.idx
Düster Horst
Horst.Duester at bd.so.ch
Fri Feb 13 10:16:42 EST 2004
Frank
Thank you very much for your response. You are right to mention that this is
not the right place for this subject. I thought that perhaps somebody
reading this list has some experience or ideas for a solution.
So I will take a further look at ESRI ArcView lists.
Best Regards
Dr. Horst Düster
GIS-Koordinator
Amt für Geoinformation
Abteilung SO!GIS Koordination
Werkhofstr. 65
4509 Solothurn
Tel.: 032 627 25 32
Fax: 032 627 22 14
horst.duester at bd.so.ch <mailto:horst.duester at bd.so.ch>
www.sogis.so.ch <http://www.sogis.so.ch/>
-----Ursprüngliche Nachricht-----
Von: Frank Warmerdam [mailto:warmerdam at pobox.com]
Gesendet am: Freitag, 13. Februar 2004 15:36
An: GEOS Development List
Betreff: Re: [geos-devel] OGR and Shape.idx
Düster Horst wrote:
> I work with large datasets > 1'000'000 recs in a PostGIS DB. For direct
use
> with ArcView we need to export these data to ESRI shapefiles with ogr2ogr.
> This export works automatically and nightly very stable. Now I'm faced
with
> the problem that this export doesn't create spatial indexes. Working with
> this data in ArcView is very slow. My solution today, I create this
indexes
> by hand with ArcView every day.
> Now I'm looking for a better solution to automate the shape index
creation.
> I'm appreciative for every hint.
Dr. Düster,
I am unaware of any public definition of the Shapefile index formats. I
took
a peek at it once, and it wasn't completely trivial though I imagine it
could
be worked out with sufficient effort.
I think reverse engineering the ESRI spatial index format would be an
interesting project for some geo-programmer with time on their hands, and
access to ArcView. However, that isn't me at this time, and this list might
not be the best place to try and find such a person.
Isn't there a way of launching ArcView scripts "in batch" as part of your
whole transfer process?
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Programmer for Rent
geos-devel mailing list
geos-devel at geos.refractions.net
http://geos.refractions.net/mailman/listinfo/geos-devel
