[geos-devel] Library Creation
Norman Vine nhv at cape.com
Fri Feb 20 06:16:16 EST 2004
Darren Houston writes
> Happened with me on Cygwin also. It was the Feb. 10 24:00 MST (Alberta) CVS
> check-out.
This is the corrext behaviour Cygwin should DLLs
should *not* be adding a .so extension
i.e. Cygwin uses the Win32 DLL mechanisms not the Unix ones
Cheers
Norman
