[geos-devel] GeometryFactory argument in Geometry constructors
strk
strk at keybit.net
Thu Jul 1 10:48:08 EDT 2004
I've found this change does not always work.
Sometime client application does not have control over Geometries'
factory. Namely the PrecisionReducer class creates a new GeometryFactory
for the new Geometry. If Geometry do not take ownership of the factory
this results in a memory leak.
Having Geometry own a private GeometryFactory means you have
less memory management problems but memory occupation and CPU
cycles will increase. Take a collection of 100 Geometries.
This will have 101 GeometryFactories, 101 copies and 101 deletes.
Each GeometryFactory copy will also copy its PrecisionModel.
Apart from the fact that this duplication of info might be useless
(is a collection of Geometries with different Factory valid ?)
Do we really need it ?
A possible solution is to specify wheter or not to take ownership of
passed GeometryFactory. This specification would set a flag which
would be checked at Geometry destruction time. Taking ownership of
a GeometryFactory could mean just destroy it at Geometry destruction
time, without making any copy at construction time (duplicating
a GeometryFactory should be pretty easy). With this setup code
willing to use a Geometry factory for constructing another Geometry
should check ownership of it, as the new Geometry might refer to
a factory which will be destructed by former Geometry destructor...
Another solution might be reference counting, which I discouraged
in the past (mainly due to my lack of experience).
Actually reference counting might more closely reflect JTS, which
gets memory management for free... This - again - would be a bigger
change and will shift release time.
Final and easier solution is to keep copying Factory and forget about
it.
Comments ?
--strk;
On Wed, Jun 30, 2004 at 10:58:29PM +0200, strk wrote:
> I ask and answer myself :)
> I've removed GeometryConstrauctor automatic copy from
> Geometry constructors. This want change the way applications
> will call them.
> Now on with the ref/pointer switch for ownership...
> --strk;
> On Wed, Jun 30, 2004 at 09:49:14PM +0200, strk wrote:
> > Another element which should be take part of the next API
> > is GeoemtryFactory. GEOS-1.0 did not have geom constructors
> > taking GeometryFactory (did have PrecisionModel and SRID which
> > the constructors used to build a new Factory). Next GEOS will
> > have GeometryFactory as an argument to the constructor (so to
> > have PrecisionModel and SRID already defined there).
> > Would the factory element of each Geometry be better a pointer
> > to external resource or a owned copy ? It is currently a copy
> > so I was wondering. If we need both behaviour with this too
> > it will make 4 constructor versions for each geometry :!!
> > Just a note: when building a geometry with no defined factory
> > current behaviour is to create a new Factory (which would leak
> > unless deleted at geometry destruction time). If we decide to
> > go with pointer-to-external-object we could use an
> > internalGeometryFactory in thee cases.
> > --strk;
> > geos-devel mailing list
> > geos-devel at geos.refractions.net
> > http://geos.refractions.net/mailman/listinfo/geos-devel
