[geos-devel] Using SWIG to interface with GEOS, undefined symbols
Sean Gillies
sgillies at frii.com
Mon Jul 12 14:15:58 EDT 2004
On Jul 12, 2004, at 9:39 AM, strk wrote:
> On Mon, Jul 12, 2004 at 09:10:53AM -0600, Sean Gillies wrote:
>> On Jul 12, 2004, at 9:00 AM, strk wrote:
>>> On Mon, Jul 12, 2004 at 08:41:07AM -0600, Sean Gillies wrote:
>>>> Hi all,
>>>> Yesterday I began to try to use SWIG to generate a Python
>>>> GEOS module using the CVS GEOS. To start, I am only wrapping
>>>> the classes in geom.h and precision.h.
>>> precision.h does not really contain 'basic' classes.
>>> PrecisionModel class is in geom.h.
>>>> SWIG 1.3.20 generates wrapper code with only a few warnings
>>>> and the module does build, resulting in geos.py and a very
>>>> large _geos.so (I have statically linked against libgeos.a).
>>>> On import of the geos module, an import error is raised:
>>>> ImportError:
>>>> /home/sean/projects/PyGEOS/build/lib.linux-i686-2.3/_geos.so:
>>>> undefined symbol: _ZN4geos14PrecisionModel19maximumPreciseValueE
>>> Could you have built _geos.so and the geos.py in at different times ?
>>> CVS api is changing , and you get those kind of errors for every
>>> simple
>>> 'const' addition.
>>> --strk;
>> Thanks for the reply! _geos.so and geos.py are synchronous, no
>> problem
>> there. I was having this same issue with GEOS 1.0 and SWIG, so I am
>> ruling out API changes. It's either my lack of knowledge of C++, some
>> undocumented SWIG issue or a combination of these.
>> Sean
> I've checked the code. It seems a bug in both GEOS-1.0 and GEOS-CVS
> PrecisionModel::maximumPreciseValue is never given a value.
> geos::maximumPreciseValue is, but the header declare
> geos::PrecisionModel::maximumPreciseValue, which is not.
> I've fixed it, please try now.
> --strk;
Yes, that one bug seems to be fixed.
Now there is exposed another one :)
ImportError:
undefined symbol: _ZNK4geos14CoordinateList17toCoordinateArrayEv
If I direct SWIG to ignore the toCoordinateArray() method of
CoordinateList,
then there is yet another undefined symbol:
ImportError:
undefined symbol:
_ZN4geos14CoordinateList3addEPSt6vectorINS_10CoordinateESaIS2_EEb
Strk, I appreciate that you have taken the time to look into it,
but this might be more time consuming. I don't know if it will
be possible to SWIG GEOS or if it is in the project's interest to
be altered so that a SWIG module is possible.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
