[geos-devel] Using SWIG to interface with GEOS, undefined symbols
Sean Gillies sgillies at frii.com
Mon Jul 12 18:05:48 EDT 2004
On Jul 12, 2004, at 1:13 PM, strk wrote:
> On Mon, Jul 12, 2004 at 12:15:58PM -0600, Sean Gillies wrote:
>> On Jul 12, 2004, at 9:39 AM, strk wrote:
>>> On Mon, Jul 12, 2004 at 09:10:53AM -0600, Sean Gillies wrote:
>>>> On Jul 12, 2004, at 9:00 AM, strk wrote:
>>>>> On Mon, Jul 12, 2004 at 08:41:07AM -0600, Sean Gillies wrote:
>>>>>> Hi all,
>>>>>> Yesterday I began to try to use SWIG to generate a Python
>>>>>> GEOS module using the CVS GEOS.  To start, I am only wrapping
>>>>>> the classes in geom.h and precision.h.
>>>>> precision.h does not really contain 'basic' classes.
>>>>> PrecisionModel class is in geom.h.
>>>>>> SWIG 1.3.20 generates wrapper code with only a few warnings
>>>>>> and the module does build, resulting in geos.py and a very
>>>>>> large _geos.so (I have statically linked against libgeos.a).
>>>>>> On import of the geos module, an import error is raised:
>>>>>> ImportError:
>>>>>> /home/sean/projects/PyGEOS/build/lib.linux-i686-2.3/_geos.so:
>>>>>> undefined symbol: _ZN4geos14PrecisionModel19maximumPreciseValueE
>>>>> Could you have built _geos.so and the geos.py in at different
>>>>> times ?
>>>>> CVS api is changing , and you get those kind of errors for every
>>>>> simple
>>>>> 'const' addition.
>>>>> --strk;
>>>> Thanks for the reply!  _geos.so and geos.py are synchronous, no
>>>> problem
>>>> there.  I was having this same issue with GEOS 1.0 and SWIG, so I am
>>>> ruling out API changes.  It's either my lack of knowledge of C++,
>>>> some
>>>> undocumented SWIG issue or a combination of these.
>>>> Sean
>>> I've checked the code. It seems a bug in both GEOS-1.0 and GEOS-CVS
>>> PrecisionModel::maximumPreciseValue is never given a value.
>>> geos::maximumPreciseValue is, but the header declare
>>> geos::PrecisionModel::maximumPreciseValue, which is not.
>>> I've fixed it, please try now.
>>> --strk;
>> Yes, that one bug seems to be fixed.
>> Now there is exposed another one :)
>>   ImportError:
>>   undefined symbol:   _ZNK4geos14CoordinateList17toCoordinateArrayEv
>> If I direct SWIG to ignore the toCoordinateArray() method of
>> CoordinateList,
>> then there is yet another undefined symbol:
>>   ImportError:
>>   undefined symbol:
>> _ZN4geos14CoordinateList3addEPSt6vectorINS_10CoordinateESaIS2_EEb
>> Strk, I appreciate that you have taken the time to look into it,
>> but this might be more time consuming.  I don't know if it will
>> be possible to SWIG GEOS or if it is in the project's interest to
>> be altered so that a SWIG module is possible.
>> cheers,
>> Sean
> Sean, no problem, you might help us as well, as we are redefining
> the API, so every feedback is appreciated.
> The problem here is with CoordinateList being currently removed
> from interface. CoordinateList class reference is still in the
> geom.h file, but the corresponding module is not built into
> the library. We are still discussing wheter to keep or not that
> class. In the meanwhile, I commented out the definition,
> this should fix your problem.
> --strk;
Strk,
I decided to revert to GEOS-1.0.  Hiding CoordinateList helped,
but there were then problems with GeometryCollection ... and I
think I'll try to get it working with 1.0 first.  After a bit of
tweaking, I have a Python geos module that I can import.
* applied the change to PrecisionModel.cpp that you committed into
   the CVS head.
* directed SWIG to ignore declarations of 'throw_exception' because
   of an undefined symbol related to Geometry::throw_exception
* directed SWIG to ignore declarations of 'isClosed' because of an
   undefined symbol: _ZNK4geos10MultiPoint8isClosedEv
These last two changes leave the module in a less than fully
functional state, but I am encouraged.  Any idea what might be
the problem with Geometry::throw_exception and MultiPoint::isClosed?
thanks again,
Sean
Here's a "screenshot" for the curious:
Python 2.3.3 (#1, Jan  4 2004, 11:27:28)
[GCC 3.2.2 20030222 (Red Hat Linux 3.2.2-5)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
 >>> import geos
 >>> dir(geos)
['BasicCoordinateList', 'BasicCoordinateListFactory',
'BasicCoordinateListFactoryPtr', 'BasicCoordinateListPtr',
'Coordinate', 'CoordinateFilter', 'CoordinateFilterPtr',
'CoordinateList', 'CoordinateListFactory', 'CoordinateListFactoryPtr',
'CoordinateListPtr', 'CoordinateList_equals',
'CoordinateList_hasRepeatedPoints', 'CoordinateList_indexOf',
'CoordinateList_minCoordinate', 'CoordinateList_removeRepeatedPoints',
'CoordinateList_reverse', 'CoordinateList_scroll', 'CoordinatePtr',
'Dimension', 'DimensionPtr', 'Dimension_toDimensionSymbol',
'Dimension_toDimensionValue', 'Envelope', 'EnvelopePtr',
'GEOS_GEOMETRYCOLLECTION', 'GEOS_LINESTRING', 'GEOS_MULTILINESTRING',
'GEOS_MULTIPOINT', 'GEOS_MULTIPOLYGON', 'GEOS_POINT', 'GEOS_POLYGON',
'Geometry', 'GeometryCollection', 'GeometryCollectionIterator',
'GeometryCollectionIteratorPtr', 'GeometryCollectionPtr',
'GeometryComponentFilter', 'GeometryComponentFilterPtr',
'GeometryFactory', 'GeometryFactoryPtr',
'GeometryFactory_createPointFromInternalCoord',
'GeometryFactory_toGeometry', 'GeometryFilter', 'GeometryFilterPtr',
'GeometryPtr', 'IntersectionMatrix', 'IntersectionMatrixPtr',
'LineSegment', 'LineSegmentPtr', 'LineString', 'LineStringPtr',
'LinearRing', 'LinearRingPtr', 'Location', 'LocationPtr',
'Location_toLocationSymbol', 'MultiLineString', 'MultiLineStringPtr',
'MultiPoint', 'MultiPointPtr', 'MultiPolygon', 'MultiPolygonPtr',
'Point', 'PointCoordinateList', 'PointCoordinateListFactory',
'PointCoordinateListFactoryPtr', 'PointCoordinateListPtr', 'PointPtr',
'Polygon', 'PolygonPtr', 'PrecisionModel', 'PrecisionModelPtr',
'SFSCurve', 'SFSCurvePtr', 'SFSGeometry', 'SFSGeometryCollection',
'SFSGeometryCollectionPtr', 'SFSGeometryPtr', 'SFSLineString',
'SFSLineStringPtr', 'SFSLinearRing', 'SFSLinearRingPtr',
'SFSMultiCurve', 'SFSMultiCurvePtr', 'SFSMultiLineString',
'SFSMultiLineStringPtr', 'SFSMultiPoint', 'SFSMultiPointPtr',
'SFSMultiPolygon', 'SFSMultiPolygonPtr', 'SFSMultiSurface',
'SFSMultiSurfacePtr', 'SFSPoint', 'SFSPointPtr', 'SFSPolygon',
'SFSPolygonPtr', 'SFSSurface', 'SFSSurfacePtr', '__builtins__',
'__doc__', '__eq__', '__file__', '__name__', '_geos', 'cvar',
'greaterThen', 'lessThen', 'point_3d', 'point_3dPtr']
