[geos-devel] future changes
ross ross.elliott at ntlworld.com
Thu Jul 15 15:56:39 EDT 2004
I've been fixing a bug in my application code recently and found two things in geos that could do with some attention:
1/ have a getGeometryType member function that returns an integer rather than a string as testing integers is faster than a string compare;
2/ make geometry.intersection always return a GeometryCollection, even if it only contains one geometry. This removes the need to check what has actually been returned, you only need to itterate through the GeometryCollection;
Ross
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20040715/97190227/attachment.html
