I've modified source/geom/Makefile.am to provide the -release Major.Minor.Patch switch to libtool instead of -version-info, which I could not understand usage of. Can you (and people on the list) try if this works on other systems then mine ? Also, I'm not sure about versioning of archive files (libgeos.a) any hint on how to check that ? TIA --strk;
