[geos-devel] Interface changes
Ferdinando Villa ferdinando.villa at uvm.edu
Wed Jun 16 10:28:36 EDT 2004
On Wed, 2004-06-16 at 10:20, strk wrote:
> On Wed, Jun 16, 2004 at 09:30:13AM -0400, Ferdinando Villa wrote:
> > Yes please, add the version info - I think I originally put it at the
> > very start of configure.in, with a matching AC_SUBST at the end - that
> > should take care of it for geos-config and should propagate to the
> > object files through a gcc command line define. Maybe I just thought I
> > put it there :)
> No geos headers appear in AC_SUBST.
> Do you think geom.h is the right place ?
Yes, or better, have these defined in geos_version.h and include it
first thing in geom.h (btw - shouldn't it be geos.h, or maybe we should
have a geos.h including geos_version.h and geom.h?). I usually prefer to
have version numbers configured in configure.in and use the gcc command
line to propagate them, but this has the disadvantage of needing a
different strategy for Windows. Your defs and interface functions sound
great to me.
ferdinando
> I think these would be useful to have:
> 	#define GEOS_MAJOR_VERSION 1
> 	#define GEOS_MINOR_VERSION 4
> 	#define GEOS_PATCHLEVEL 0
> 	#define GEOS_VERSION "1.4.0"
> 	int geos::geos_major_version();
> 	int geos::geos_minor_version();
> 	int geos::geos_patchlevel();
> 	string geos::geos_version();
> Comments ?
> BTW, to split version in major/minor/patchlevel configure.in should also
> be modified..
> > One point about version numbers: the geos.m4 macro file that I added to
> > the distribution (which defines GEOS_INIT(version) to be used in
> > configure.in by any automake-based program that wants to check for geos)
> > depends on having all three version numbers, and will not work correctly
> > with two. So if we want that to keep working, we should have 1.4.0, not
> > 1.4, or the m4 macro should be made smarter (probably a better idea).
> probably a better idea...
> --strk;
> > Ciao,
> > ferdinando
> > On Wed, 2004-06-16 at 09:18, strk wrote:
> > > I've updated GEOS interface to make all geometry constructors
> > > copy given arguments (vector AND content).
> > > As a side effect:
> > >         o SegmentString constructor also copy given CoordinateList
> > >           and deletes it at destruction time
> > >         o SegmentString::getCoordinates() returns a copy of internal
> > >           CoordinateList
> > >         o new SegmentString::getCoordinatesRO() returns a pointer to
> > >           the internal CoordinateList (no copy involved)
> > >         o GeometryFactory::buildGeometry always returns a newly
> > >           allocated geometry, so that the caller is free to delete
> > >           arguments passed to it.
> > >         o GeometryFactory geometry collection creators
> > >           (createMulti*, createGeometryCollection) copy given
> > >           vector AND content.
> > > Reasoning about clients switched I've found that geos-config was
> > > broken in GEOS-1.0 (run with --version returned @@GEOS_VERSION@@
> > > instead of actual version). I've fixed that, but I think a version
> > > number (major,minor,patchlevel) should be put in some header for
> > > ease of use. What do you think Frank ?
> > > --strk;
> > > _______________________________________________
> > > geos-devel mailing list
> > > geos-devel at geos.refractions.net
> > > http://geos.refractions.net/mailman/listinfo/geos-devel
