[geos-devel] geos-config
strk
strk at keybit.net
Fri Jun 25 04:40:44 EDT 2004
I don't like this also.
I think it should produce just the path without the -I switch.
Anyway, you should find a geos.m4 file in the GEOS distribution
handy for application's configure scripts.
--strk;
On Thu, Jun 24, 2004 at 11:38:23PM -0500, Stephen Lime wrote:
> Hi folks: Trying to integrate geos into a configure script based on the
> output from geos-config. I'm curious if the --includes and --cflags
> options should be producing the same output (they do). I expected one
> of them to produce "-I/usr/local/include/geos". I can work around this
> using the --prefix but was wondering if the behavior is as intended.
> Steve
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
