[geos-devel] geos-config
strk strk at keybit.net
Fri Jun 25 10:47:20 EDT 2004
On Fri, Jun 25, 2004 at 10:31:18AM -0400, Ferdinando Villa wrote:
> That's debatable, but my vote would go to cflags pointing to /includes,
> and prefixing all includes as geos/. I don't see
> a problem in having geo{s|m}.h containing lines like
> #ifndef __geos_platform_h
> #include <geos/platform.h>
> #endif
> using the bracket notation should keep us safe from ambiguity and it
> would work as long as the include path is given as /includes. Looks
> elegant to me, too, but that's me...
Note that geom.h is included by GEOS modules themself, whose headers
do not currently reside under a geos/ directory, so the switch should
be something like
#ifdef __BUILDING_GEOS
#include "platform.h"
#else
#endif
The switch would not be needed for geos.h since it is a front-end only
header file....
--strk;
> cheers
> f
> On Fri, 2004-06-25 at 10:29, strk wrote:
> > On Fri, Jun 25, 2004 at 09:16:08AM -0400, Ferdinando Villa wrote:
> > > Yes - --cflags should produce the -I line, --includes should just list
> > > the path. The current script is buggy - strk can you fix it?
> > The fix is in current CVS.
> > Ferdinando, do you think includes should be
> > .../includes or .../includes/geos ?
> > I'd like application to use #include "geos/geom.h" or
> > similar (which would work with current geos-config output)
> > but then geom.h includes platform.h (and not geos/platform.h)
> > and it should not work then....
> > What do you think should be done about this ?
> > --strk;
> > > The procedure to use the geos.m4 macro is as follows:
> > > put GEOS_INIT(1.0.0) in configure.int
> > > run aclocal -I macros instead of aclocal
> > > the rest is the same
> > > your CXXFLAGS will include the geos path automatically and your LIBS
> > > will link geos in.
> > > ferdinando
> > > On Fri, 2004-06-25 at 04:40, strk wrote:
> > > > I don't like this also.
> > > > I think it should produce just the path without the -I switch.
> > > > Anyway, you should find a geos.m4 file in the GEOS distribution
> > > > handy for application's configure scripts.
> > > > --strk;
> > > > On Thu, Jun 24, 2004 at 11:38:23PM -0500, Stephen Lime wrote:
> > > > > Hi folks: Trying to integrate geos into a configure script based on the
> > > > > output from geos-config. I'm curious if the --includes and --cflags
> > > > > options should be producing the same output (they do). I expected one
> > > > > of them to produce "-I/usr/local/include/geos". I can work around this
> > > > > using the --prefix but was wondering if the behavior is as intended.
> > > > > Steve
> > > > > _______________________________________________
> > > > > geos-devel mailing list
> > > > > geos-devel at geos.refractions.net
> > > > > http://geos.refractions.net/mailman/listinfo/geos-devel
