[geos-devel] Problems creating polygons with holes
strk
strk at keybit.net
Mon Jun 28 15:58:54 EDT 2004
I could not find the problem.
Here is a reduced code exploiting the error.
I'll keep inspecting this...
BTW: I don't feel comportable in Polygon constructor taking
ownership of passed arguments, what people think about modifying
this as well ?
--strk;
//--------------------------8<-------------------
#include <geos/io.h>
#include <geos/geom.h>
#include <geos/util.h>
using namespace std;
using namespace geos;
int main(int argc, char *argv[]) {
Coordinate c;
CoordinateList *cl1 = CoordinateListFactory::internalFactory->createCoordinateList();
CoordinateList *cl2 = CoordinateListFactory::internalFactory->createCoordinateList();
c.x = 339252; c.y = 1019302; cl1->add(c);
c.x = 339252; c.y = 1029077; cl1->add(c);
c.x = 348752; c.y = 1029077; cl1->add(c);
c.x = 346102; c.y = 1019653; cl1->add(c);
c.x = 340000; c.y = 1020000; cl2->add(c);
c.x = 340000; c.y = 1021000; cl2->add(c);
c.x = 341000; c.y = 1021000; cl2->add(c);
c.x = 341000; c.y = 1020000; cl2->add(c);
try {
GeometryFactory *gf=new GeometryFactory(new PrecisionModel(),0);
Geometry *geom1=gf->createPolygon(gf->createLinearRing(cl1),NULL);
cout<<"geom1: "<<geom1->toString()<<endl;
Geometry *geom2=gf->createPolygon(gf->createLinearRing(cl2),NULL);
cout<<"geom2: "<<geom2->toString()<<endl;
vector<Geometry*>*holes = new vector<Geometry*>(1);
(*holes)[0] = geom2->clone();
Geometry *geom3=gf->createPolygon(gf->createLinearRing(cl1),holes);
cout<<"geom3: "<<geom3->toString()<<endl;
delete cl1;
delete cl2;
} catch (GEOSException *ge) {
cout << "ERROR: " << ge->toString() << endl;
} catch (...) {
cout << "generic ERROR" << endl;
> typedef struct boundaryPt {
> double x;
> double y;
> typedef vector<boundaryPt> boundary;
> typedef vector<boundary> boundaryList;
> typedef vector<boundaryList> polygonList;
> polygonList ptPolygons;
> vector<Geometry *> polygons;
> vector<Geometry *> holes;
> int i,j,k;
> string resStr = "";
> boundaryPt poly1[5];
> boundaryPt hole1[5];
> boundary tmpBoundary;
> boundaryList tmpBoundaryList;
> poly1[0].x = 339252;
> poly1[0].y = 1019302;
> poly1[1].x = 339252;
> poly1[1].y = 1029077;
> poly1[2].x = 348752;
> poly1[2].y = 1029077;
> poly1[3].x = 346102;
> poly1[3].y = 1019653;
> poly1[4].x = 339252;
> poly1[4].y = 1019302;
> hole1[0].x = 340000;
> hole1[0].y = 1020000;
> hole1[1].x = 340000;
> hole1[1].y = 1021000;
> hole1[2].x = 341000;
> hole1[2].y = 1021000;
> hole1[3].x = 341000;
> hole1[3].y = 1020000;
> hole1[4].x = 340000;
> hole1[4].y = 1020000;
> for (i=0; i<5; i++) {
> tmpBoundary.push_back(poly1[i]);
> tmpBoundaryList.push_back(tmpBoundary);
> tmpBoundary.clear();
> tmpBoundary.push_back(hole1[i]);
> ptPolygons.push_back(tmpBoundaryList);
> for(int i=0; i< static_cast<int>(tmpBoundaryList.size()); i++) {
> tmpBoundaryList[i].clear();
> tmpBoundaryList.clear();
> try{
> // for each outer ring create a CoordinateList and add all the points to it
> for(i=0; i< static_cast<int>(ptPolygons.size()); i++) {
> CoordinateList *cl1=CoordinateListFactory::internalFactory->createCoordinateList();
> boundaryList bl = ptPolygons[i];
> boundary b = bl[0];
> cout << "Polygon " << i << endl;
> for(k=0; k< static_cast<int>(b.size()); k++) {
> cout << "Added point " << b[k].x << ',' << b[k].y << endl;
> cl1->add(*(new Coordinate(b[k].x,b[k].y)));
> // for each hole create a coordinate list like above, create a polygon and add to a Geometry vector
> for(j=1; j< static_cast<int>(bl.size()); j++) {
> cout << "Hole " << j << endl;
> boundary b = bl[j];
> CoordinateList *cl2=CoordinateListFactory::internalFactory->createCoordinateList();
> cl2->add(*(new Coordinate(b[k].x,b[k].y)));
> cout << "Creating polygon for hole " << j << ": " << cl2->toString() << endl;
> Geometry *geom1=gf->createPolygon(gf->createLinearRing(cl2),NULL);
> cout << "Geometry " << j << " : " << geom1->toString() << endl;
> holes.push_back(geom1);
> delete cl2;
> // create a polygon from the 1st CoordinateList and the holes
> cout << "Creating polygon " << i << ": " << cl1->toString() << endl;
> Geometry *geom2=gf->createPolygon(gf->createLinearRing(cl1),&holes);
> cout << "test " << endl;
> cout << "Geometry " << i << " : " << geom2->toString() << endl;
> // save this polygon in another vector
> cout << "Adding polygon " << i << endl;
> polygons.push_back(geom2);
> delete cl1;
> cout << "Creating multi-polygon" << endl;
> // when all done create a MultiPolygon object
> Geometry *geom3=gf->createMultiPolygon(&polygons);
> cout << "Creating string" << endl;
> resStr = geom3->toString();
> //clean up
> delete geom3;
> delete gf;
> cout << resStr << endl;
> -----Original Message-----
> From: strk [mailto:strk at keybit.net]
> Sent: 28 June 2004 11:28
> To: GEOS Development List
> Subject: Re: [geos-devel] Problems creating polygons with holes
> Can you produce a neter code exploiting the bug ?
> I mean a .cpp file I can compile and run and debug :)
> -strk;
> On Mon, Jun 28, 2004 at 11:05:22AM +0100, Darren Carman wrote:
> > defs:
> > double x;
> > double y;
> > class members used:
> > string tmpStr;
> > string errMsg;
> > class function:
> > string c_polygon_gml::WKTString(void) {
> > TRACE_FUNC("c_polygon_gml::WKTString");
> > int i,j,k;
> > string resStr = "";
> > try{
> > boundary b = bl[0];
> > TRACE_OUTPUT("Polygon " << i);
> > TRACE_OUTPUT("Added point " << b[k].x << ',' << b[k].y);
> > TRACE_OUTPUT("Hole " << j);
> > boundary b = bl[j];
> > TRACE_OUTPUT("Creating polygon for hole " << j << ": " << cl2->toString());
> > TRACE_OUTPUT("Geometry " << j << " : " << geom1->toString());
> > delete cl2;
> > TRACE_OUTPUT("Creating polygon " << i << ": " << cl1->toString());
> > TRACE_OUTPUT("test ");
> > TRACE_OUTPUT("Geometry " << i << " : " << geom2->toString());
> > TRACE_OUTPUT("Adding polygon " << i);
> > delete cl1;
> > TRACE_OUTPUT("Creating multi-polygon");
> > TRACE_OUTPUT("Creating string");
> > //clean up
> > delete geom3;
> > delete gf;
> > errMsg = ge->toString();
> > return resStr;
> > XML read in by class and stored in ptPolygons:
> > <?xml version="1.0" encoding="UTF-8"?>
> > <AreaDefinition>
> > <GDSRequest>
> > <query>
> > <AreaQuery outputContent="public">
> > <queryArea>
> > <Polygon srsName="osgb:BNG">
> > <outerBoundaryIs>
> > <LinearRing>
> > <coordinates>
> > 339252,1019302
> > 339252,1029077
> > 348752,1029077
> > 346102,1019653
> > 339252,1019302
> > </coordinates>
> > </LinearRing>
> > </outerBoundaryIs>
> > <innerBoundaryIs>
> > <LinearRing>
> > <coordinates>
> > 340000,1020000
> > 340000,1021000
> > 341000,1021000
> > 341000,1020000
> > 340000,1020000
> > </coordinates>
> > </LinearRing>
> > </innerBoundaryIs>
> > </Polygon>
> > </queryArea>
> > </AreaQuery>
> > </query>
> > </GDSRequest>
> > </AreaDefinition>
> > Output:
> > TR: TRACE ENTRY:c_polygon_gml::WKTString line 168 file c_polygon_gml.cpp
> > TR: Polygon 0
> > TR: Added point 339252,1.0193e+06
> > TR: Added point 339252,1.02908e+06
> > TR: Added point 348752,1.02908e+06
> > TR: Added point 346102,1.01965e+06
> > TR: Hole 1
> > TR: Added point 340000,1.02e+06
> > TR: Added point 340000,1.021e+06
> > TR: Added point 341000,1.021e+06
> > TR: Added point 341000,1.02e+06
> > TR: Creating polygon for hole 1: (340000,1.02e+06,1.7e-308) (340000,1.021e+06,1.7e-308) (341000,1.021e+06,1.7e-308) (341000,1.02e+06,1.7e-308) (340000,1.02e+06,1.7e-308)
> > TR: Geometry 1 : POLYGON ((340000.0000000000000000 1020000.0000000000000000, 340000.0000000000000000 1021000.0000000000000000, 341000.0000000000000000 1021000.0000000000000000, 341000.0000000000000000 1020000.0000000000000000, 340000.0000000000000000 1020000.0000000000000000))
> > TR: Creating polygon 0: (339252,1.0193e+06,1.7e-308) (339252,1.02908e+06,1.7e-308) (348752,1.02908e+06,1.7e-308) (346102,1.01965e+06,1.7e-308) (339252,1.0193e+06,1.7e-308)
> > TR: test
> > Segmentation fault
> > Output when the hole is removed:
> > TR: Polygon 0
> > TR: test
> > TR: Geometry 0 : POLYGON ((339252.0000000000000000 1019302.0000000000000000, 339252.0000000000000000 1029077.0000000000000000, 348752.0000000000000000 1029077.0000000000000000, 346102.0000000000000000 1019653.0000000000000000, 339252.0000000000000000 1019302.0000000000000000))
> > TR: Adding polygon 0
> > TR: Creating multi-polygon
> > TR: Creating string
> > TR: TRACE EXIT:c_polygon_gml::WKTString
> > ERROR:
> > WTF format
> > MULTIPOLYGON (((339252.0000000000000000 1019302.0000000000000000, 339252.0000000000000000 1029077.0000000000000000, 348752.0000000000000000 1029077.0000000000000000, 346102.0000000000000000 1019653.0000000000000000, 339252.0000000000000000 1019302.0000000000000000)))
> > Sent: 28 June 2004 11:01
> > Can you send the test code ?
> > There are currently no known bug ...
> > --strk;
> > On Mon, Jun 28, 2004 at 10:15:45AM +0100, Darren Carman wrote:
> > > Hi all,
> > > I am creating polygons with holes and want to use geos to allow me to output them in WKT.
> > > A polygon without a hole works fine, but as soon as I add a hole I get a segmentation fault after calling the createPolygon function (GeometryFactory) and trying to run toString on that polygon.
> > > I am using version 1.0.
> > > I have tried getting the latest version from CVS but this causes a segmentation fault to occur while adding the 5th polygon coordinate to the CoordinateList (there are only 4 coordinates in the test polygon, the 5th being the first one repeated - I tried making it 6 to see if it was a problem with closing the polygon but I still got a segmentation fault while adding the 5th).
> > > Is there a fix for this, or has anyone come accross it?
> > > Thanks in advance,
> > > Darren
> > > "The information in this e-mail and any attachment is confidential and may be privileged. If you have received this e-mail in error, please delete it immediately and destroy any copies on your system. You should not retain, copy or use this e-mail for any purpose, nor disclose all or any part of its content to any other person.
> > > Opinions expressed in this e-mail may not be endorsed by the company and unless explicitly indicated, this e-mail shall not form part of any binding agreement".
> > > _______________________________________________
> > > geos-devel mailing list
> > > geos-devel at geos.refractions.net
> > > http://geos.refractions.net/mailman/listinfo/geos-devel
