[geos-devel] Problems creating polygons with holes
strk
strk at keybit.net
Tue Jun 29 21:02:47 EDT 2004
Another alternative would be having pass-by-reference
deep copy and pass-by-pointer take ownership.
Geometries taking vector could base the check on the
vector itself (Collections, Polygon).
This would avoid using the additional argument, which in some
cases could require big changes (casing const pointers
to non-const).
What do you think about this ?
--strk;
On Wed, Jun 30, 2004 at 01:28:02AM +0200, strk wrote:
> On Mon, Jun 28, 2004 at 03:04:21PM -0700, Martin Davis wrote:
> > Not sure there's any neat solution to this problem.... I think you'll
> > have to go with the extra arg.
> > The other option is to just provide the copying functionality in the
> > GeometryFactory, not in the basic constructors.
> We'd have to modify Geometry constructors anyway, so this would not
> really reduce the effort.
> > Personally I would rather keep the whole thing clean, and not provide
> > copying. After all, who is the client for this? And why can't they
> > learn to copy when needed?
> Unfortunately copying is not always clean ...
> For Geometries your have the ->clone() method, while
> the same is not that clear for other types of constructors...
> LineString - for example - take a CoordinateList, which is copied with:
> points=CoordinateListFactory::internalFactory->createCoordinateList(pts)
> (which is ugly and very unconfortable).
> Polygon - another example - take vector<Geometry *>*holes as second
> argument, which takes a loop to be copied.
> My point is that current GEOS status has not a neat copying interface
> for all everyday use classes, so hiding the complexity of it might be
> worth. Another point - but that is opinable - is that as a standard
> way of programming any object should be destroyed by the object that
> created it, for mind serenity's sake, so a non-standard behaviour should
> be explicitly advertised (an additional arg would do).
> See also darren problems with memory management
> (sure he DO can learn...)
> --strk;
> > Martin Davis, Senior Technical Architect
> > Vivid Solutions Inc. www.vividsolutions.com
> > Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
> > Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> > > -----Original Message-----
> > > From: strk [mailto:strk at keybit.net]
> > > Sent: June 28, 2004 2:56 PM
> > > To: Martin Davis
> > > Subject: Re: [geos-devel] Problems creating polygons with holes
> > > On Mon, Jun 28, 2004 at 02:21:12PM -0700, Martin Davis wrote:
> > > > Good point.
> > > > How are you going to indicate that copying is required in the
> > > > constructors?
> > > I'm stuck on that part :)
> > > Basically I was thinking about duplicating each constructor
> > > so to have a deep-copier and a ownership-taker.
> > > The two constructors would be distinguished by a fake
> > > additional argument (an argument needed just to distinguish
> > > them, whose value does not matter). I don't like this setup,
> > > but I don't see any enlightment.
> > > Just one more alternative is putting this logic in the
> > > geometryfactory which could create empty versions and then
> > > 'install' actual content... this would waste some space and
> > > cpu but not that much.
> > > What do you think?
> > > --strk;
> > > > > Sent: June 28, 2004 2:20 PM
> > > > > To: Martin Davis
> > > > > Cc: geos-devel at geos.refractions.net
> > > > > On Mon, Jun 28, 2004 at 02:15:31PM -0700, Martin Davis wrote:
> > > > > > By pattern/support class is just fancy software engineering
> > > > > speak for
> > > > > > "make it standard and simple for the client".
> > > > > > What do you mean by "duplicating each constructor"? Do you mean
> > > > > > duplicating each method on the GeometryFactory?
> > > > > Wooo.. actually I meant each Geometry constructor AND
> > > > > GeometryFactory methods. GeometryFactory methods call
> > > > > Geometry constructors after
> > > > > all so the double-approach must be present in both places.
> > > > > --strk;
> > > > > > > Sent: June 28, 2004 1:59 PM
> > > > > > > To: Martin Davis
> > > > > > > Cc: GEOS Development List
> > > with holes
> > > > > > > On Mon, Jun 28, 2004 at 01:50:09PM -0700, Martin Davis wrote:
> > > > > > > > Strk:
> > > > > > > > IMO the current paradigm (that of constructors taking
> > > > > ownership of
> > > > > > > > their
> > > > > > > > components) is the correct one. The reason is to avoid
> > > > > unecessary
> > > > > > > > copying of argument data (which could be large). It should
> > > > > > > be left up
> > > > > > > > to the caller to decide when and where they need to copy
> > > > > > > > arguments.
> > > > > > > > Yes, this is a potential source of errors for clients, if
> > > > > > > they don't
> > > > > > > > understand how to properly use the library. But the
> > > > > > > > alternative forces clients to tolerate extra overhead even
> > > > > > > > when
> > > > > they don't need
> > > > > > > > it, which is not friendly behaviour from a library.
> > > > > > > > If this is really onerous, two versions of each constructor
> > > > > > > could be
> > > > > > > > provided. Or possibly even better, a pattern & support
> > > > > > > class to make
> > > > > > > > it easy to copy arguments.
> > > > > > > Unfortunately geos-1.0 was released with mixed
> > > policy, which is
> > > > > > > what I'm trying to conform now.
> > > > > > > I like the idea of letting callers specify whether or not to
> > > > > > > take ownership and so far duplicationg each constructor seems
> > > > > > > the cleaner way (adding a parameter takeOwnership
> > > would make all
> > > > > > > const correctness useless and will require
> > > modifications in many
> > > > > > > places).
> > > > > > > What do you mean by pattern & support class ?
> > > > > > > --strk;
> > > > > > > > > Sent: June 28, 2004 12:59 PM
> > > > > > > > > To: Darren Carman
> > > > > with holes
> > > > > > > > > I could not find the problem.
> > > > > > > > > Here is a reduced code exploiting the error.
> > > > > > > > > I'll keep inspecting this...
> > > > > > > > > BTW: I don't feel comportable in Polygon
> > > constructor taking
> > > > > > > > > ownership of passed arguments, what people think
> > > > > about modifying
> > > > > > > > > this as well ?
> > > > > > > > > --strk;
> > > > > > > > > //--------------------------8<-------------------
> > > > > > > > > #include <geos/io.h>
> > > > > > > > > #include <geos/geom.h>
> > > > > > > > > #include <geos/util.h>
> > > > > > > > > using namespace std;
> > > > > > > > > using namespace geos;
> > > > > > > > > int main(int argc, char *argv[]) {
> > > > > > > > > Coordinate c;
> > > > > > > > > CoordinateList *cl1 =
> > > > > CoordinateListFactory::internalFactory->createCoordinateList();
> > > > > > > > > CoordinateList *cl2 =
> > > > > > > > > c.x = 339252; c.y = 1019302; cl1->add(c);
> > > > > > > > > c.x = 339252; c.y = 1029077; cl1->add(c);
> > > > > > > > > c.x = 348752; c.y = 1029077; cl1->add(c);
> > > > > > > > > c.x = 346102; c.y = 1019653; cl1->add(c);
> > > > > > > > > c.x = 340000; c.y = 1020000; cl2->add(c);
> > > > > > > > > c.x = 340000; c.y = 1021000; cl2->add(c);
> > > > > > > > > c.x = 341000; c.y = 1021000; cl2->add(c);
> > > > > > > > > c.x = 341000; c.y = 1020000; cl2->add(c);
> > > > > > > > > try {
> > > > > > > > > GeometryFactory *gf=new
> > > GeometryFactory(new
> > > > > > > > > PrecisionModel(),0);
> > > > > > > > > Geometry
> > > > > > > > > *geom1=gf->createPolygon(gf->createLinearRing(cl1),NULL);
> > > > > > > > > cout<<"geom1: "<<geom1->toString()<<endl;
> > > > > > > > > Geometry
> > > > > > > > > *geom2=gf->createPolygon(gf->createLinearRing(cl2),NULL);
> > > > > > > > > cout<<"geom2: "<<geom2->toString()<<endl;
> > > > > > > > > vector<Geometry*>*holes = new
> > > > > > > vector<Geometry*>(1);
> > > > > > > > > (*holes)[0] = geom2->clone();
> > > > > > > > > Geometry
> > > > > > > > > *geom3=gf->createPolygon(gf->createLinearRing(cl1),holes);
> > > > > > > > > cout<<"geom3: "<<geom3->toString()<<endl;
> > > > > > > > > delete cl1;
> > > > > > > > > delete cl2;
> > > > > > > > > } catch (GEOSException *ge) {
> > > > > > > > > cout << "ERROR: " <<
> > > ge->toString() << endl;
> > > > > > > > > } catch (...) {
> > > > > > > > > cout << "generic ERROR" << endl;
> > > > > > > > > On Mon, Jun 28, 2004 at 11:47:17AM +0100, Darren Carman
> > > > > > > > > > typedef struct boundaryPt {
> > > > > > > > > > double x;
> > > > > > > > > > double y;
> > > > > > > > > > typedef vector<boundaryPt> boundary;
> > > > > > > > > > typedef vector<boundary> boundaryList;
> > > > > > > > > > typedef vector<boundaryList> polygonList;
> > > > > > > > > > polygonList ptPolygons;
> > > > > > > > > > vector<Geometry *> polygons;
> > > > > > > > > > vector<Geometry *> holes;
> > > > > > > > > > int i,j,k;
> > > > > > > > > > string resStr = "";
> > > > > > > > > > boundaryPt poly1[5];
> > > > > > > > > > boundaryPt hole1[5];
> > > > > > > > > > boundary tmpBoundary;
> > > > > > > > > > boundaryList tmpBoundaryList;
> > > > > > > > > > poly1[0].x = 339252;
> > > > > > > > > > poly1[0].y = 1019302;
> > > > > > > > > > poly1[1].x = 339252;
> > > > > > > > > > poly1[1].y = 1029077;
> > > > > > > > > > poly1[2].x = 348752;
> > > > > > > > > > poly1[2].y = 1029077;
> > > > > > > > > > poly1[3].x = 346102;
> > > > > > > > > > poly1[3].y = 1019653;
> > > > > > > > > > poly1[4].x = 339252;
> > > > > > > > > > poly1[4].y = 1019302;
> > > > > > > > > > hole1[0].x = 340000;
> > > > > > > > > > hole1[0].y = 1020000;
> > > > > > > > > > hole1[1].x = 340000;
> > > > > > > > > > hole1[1].y = 1021000;
> > > > > > > > > > hole1[2].x = 341000;
> > > > > > > > > > hole1[2].y = 1021000;
> > > > > > > > > > hole1[3].x = 341000;
> > > > > > > > > > hole1[3].y = 1020000;
> > > > > > > > > > hole1[4].x = 340000;
> > > > > > > > > > hole1[4].y = 1020000;
> > > > > > > > > > for (i=0; i<5; i++) {
> > > > > > > > > > tmpBoundary.push_back(poly1[i]);
> > > > > > > > > > tmpBoundaryList.push_back(tmpBoundary);
> > > > > > > > > > tmpBoundary.clear();
> > > > > > > > > > tmpBoundary.push_back(hole1[i]);
> > > > > > > > > > ptPolygons.push_back(tmpBoundaryList);
> > > > > > > > > > for(int i=0; i<
> > > > > > > static_cast<int>(tmpBoundaryList.size()); i++) {
> > > > > > > > > > tmpBoundaryList[i].clear();
> > > > > > > > > > tmpBoundaryList.clear();
> > > > > > > > > > try{
> > > > > > > > > > GeometryFactory *gf=new GeometryFactory(new
> > > > > > > > > > // for each outer ring create a
> > > CoordinateList and add
> > > > > > > > > all the points to it
> > > > > > > > > > for(i=0; i<
> > > static_cast<int>(ptPolygons.size()); i++) {
> > > > > > > > > > CoordinateList
> > > *cl1=CoordinateListFactory::internalFactory->createCoordinateList();
> > > > > > > > > > boundaryList bl = ptPolygons[i];
> > > > > > > > > > boundary b = bl[0];
> > > > > > > > > > cout << "Polygon " << i << endl;
> > > > > > > > > > for(k=0; k< static_cast<int>(b.size()); k++) {
> > > > > > > > > > cout << "Added point " << b[k].x << ',' <<
> > > > > > > b[k].y << endl;
> > > > > > > > > > cl1->add(*(new Coordinate(b[k].x,b[k].y)));
> > > > > > > > > > // for each hole create a coordinate list like
> > > > > > > > > > above,
> > > > > > > > > create a polygon and add to a Geometry vector
> > > > > > > > > > for(j=1; j< static_cast<int>(bl.size()); j++) {
> > > > > > > > > > cout << "Hole " << j << endl;
> > > > > > > > > > boundary b = bl[j];
> > > > > > > > > > CoordinateList
> > > *cl2=CoordinateListFactory::internalFactory->createCoordinateList();
> > > > > > > b[k].y << endl;
> > > > > > > > > > cl2->add(*(new Coordinate(b[k].x,b[k].y)));
> > > > > > > > > > cout << "Creating polygon for hole " <<
> > > j << ": "
> > > > > > > > > << cl2->toString() << endl;
> > > > > > > > > > Geometry
> > > > > > > > > *geom1=gf->createPolygon(gf->createLinearRing(cl2),NULL);
> > > > > > > > > > cout << "Geometry " << j << " : " <<
> > > > > > > > > geom1->toString() << endl;
> > > > > > > > > > holes.push_back(geom1);
> > > > > > > > > > delete cl2;
> > > > > > > > > > // create a polygon from the 1st CoordinateList
> > > > > > > and the holes
> > > > > > > > > > cout << "Creating polygon " << i << ": " <<
> > > > > > > > > cl1->toString() << endl;
> > > > > > > > > > Geometry
> > > *geom2=gf->createPolygon(gf->createLinearRing(cl1),&holes);
> > > > > > > > > > cout << "test " << endl;
> > > > > > > > > > cout << "Geometry " << i << " : " <<
> > > > > > > > > geom2->toString() << endl;
> > > > > > > > > > // save this polygon in another vector
> > > > > > > > > > cout << "Adding polygon " << i << endl;
> > > > > > > > > > polygons.push_back(geom2);
> > > > > > > > > > delete cl1;
> > > > > > > > > > cout << "Creating multi-polygon" << endl;
> > > > > > > > > > // when all done create a MultiPolygon object
> > > > > > > > > > Geometry *geom3=gf->createMultiPolygon(&polygons);
> > > > > > > > > > cout << "Creating string" << endl;
> > > > > > > > > > resStr = geom3->toString();
> > > > > > > > > > //clean up
> > > > > > > > > > delete geom3;
> > > > > > > > > > delete gf;
> > > > > > > > > > cout << "ERROR: " << ge->toString() << endl;
> > > > > > > > > > cout << resStr << endl;
> > > > > > > > > > Sent: 28 June 2004 11:28
> > > > > > > > > > To: GEOS Development List
> > > polygons with
> > > > > > > > > > holes
> > > > > > > > > > Can you produce a neter code exploiting the bug
> > > ? I mean a
> > > > > > > > > > .cpp file I can compile and run and debug :)
> > > > > > > > > > -strk;
> > > > > > > > > > On Mon, Jun 28, 2004 at 11:05:22AM +0100, Darren
> > > > > Carman wrote:
> > > > > > > > > > > defs:
> > > > > > > > > > > double x;
> > > > > > > > > > > double y;
> > > > > > > > > > > class members used:
> > > > > > > > > > > string tmpStr;
> > > > > > > > > > > string errMsg;
> > > > > > > > > > > class function:
> > > > > > > > > > > string c_polygon_gml::WKTString(void) {
> > > > > > > > > > > TRACE_FUNC("c_polygon_gml::WKTString");
> > > > > > > > > > > int i,j,k;
> > > > > > > > > > > string resStr = "";
> > > > > > > > > > > try{
> > > > > > > > > > > // for each outer ring create a CoordinateList and
> > > > > > > > > add all the points to it
> > > > > > > > > > > for(i=0; i<
> > > > > > > > > > > CoordinateList
> > > > > > > > > > > boundary b = bl[0];
> > > > > > > > > > > TRACE_OUTPUT("Polygon " << i);
> > > > > > > > > > > TRACE_OUTPUT("Added point " << b[k].x << ','
> > > > > > > << b[k].y);
> > > > > > > > > above, create a polygon and add to a Geometry vector
> > > > > > > > > > > TRACE_OUTPUT("Hole " << j);
> > > > > > > > > > > boundary b = bl[j];
> > > > > > > > > > > CoordinateList
> > > > > > > ',' << b[k].y);
> > > > > > > > > > > TRACE_OUTPUT("Creating polygon for
> > > hole " << j
> > > > > > > > > ": " << cl2->toString());
> > > > > > > > > > > Geometry
> > > > > > > > > > > TRACE_OUTPUT("Geometry " << j << " : " <<
> > > > > > > > > geom1->toString());
> > > > > > > > > > > delete cl2;
> > > > > > > > > > > and
> > > > > > > > > the holes
> > > > > > > > > > > TRACE_OUTPUT("Creating polygon " << i << ": " <<
> > > > > > > > > cl1->toString());
> > > > > > > > > > > Geometry
> > > > > > > > > > > TRACE_OUTPUT("test ");
> > > > > > > > > > > TRACE_OUTPUT("Geometry " << i << " : " <<
> > > > > > > > > geom2->toString());
> > > > > > > > > > > TRACE_OUTPUT("Adding polygon " << i);
> > > > > > > > > > > delete cl1;
> > > > > > > > > > > TRACE_OUTPUT("Creating multi-polygon");
> > > > > > > > > > > TRACE_OUTPUT("Creating string");
> > > > > > > > > > > //clean up
> > > > > > > > > > > delete geom3;
> > > > > > > > > > > delete gf;
> > > > > > > > > > > errMsg = ge->toString();
> > > > > > > > > > > return resStr;
> > > > > > > > > > > XML read in by class and stored in ptPolygons: <?xml
> > > > > > > > > > > version="1.0" encoding="UTF-8"?> <AreaDefinition>
> > > > > > > > > > > <GDSRequest>
> > > > > > > > > > > <query>
> > > > > > > > > > > <AreaQuery outputContent="public">
> > > > > > > > > > > <queryArea>
> > > > > > > > > > > <Polygon srsName="osgb:BNG">
> > > > > > > > > > > <outerBoundaryIs>
> > > > > > > > > > > <LinearRing>
> > > > > > > > > > > <coordinates>
> > > > > > > > > > > 339252,1019302
> > > > > > > > > > > 339252,1029077
> > > > > > > > > > > 348752,1029077
> > > > > > > > > > > 346102,1019653
> > > > > > > > > > > 339252,1019302
> > > > > > > > > > > </coordinates>
> > > > > > > > > > > </LinearRing>
> > > > > > > > > > > </outerBoundaryIs>
> > > > > > > > > > > <innerBoundaryIs>
> > > > > > > > > > > <LinearRing>
> > > > > > > > > > > <coordinates>
> > > > > > > > > > > 340000,1020000
> > > > > > > > > > > 340000,1021000
> > > > > > > > > > > 341000,1021000
> > > > > > > > > > > 341000,1020000
> > > > > > > > > > > 340000,1020000
> > > > > > > > > > > </coordinates>
> > > > > > > > > > > </LinearRing>
> > > > > > > > > > > </innerBoundaryIs>
> > > > > > > > > > > </Polygon>
> > > > > > > > > > > </queryArea>
> > > > > > > > > > > </AreaQuery>
> > > > > > > > > > > </query>
> > > > > > > > > > > </GDSRequest>
> > > > > > > > > > > </AreaDefinition>
> > > > > > > > > > > Output:
> > > > > > > > > > > TR: TRACE ENTRY:c_polygon_gml::WKTString line 168 file
> > > > > > > > > c_polygon_gml.cpp
> > > > > > > > > > > TR: Polygon 0
> > > > > > > > > > > TR: Added point 339252,1.0193e+06
> > > > > > > > > > > TR: Added point 339252,1.02908e+06
> > > > > > > > > > > TR: Added point 348752,1.02908e+06
> > > > > > > > > > > TR: Added point 346102,1.01965e+06
> > > > > > > > > > > TR: Hole 1
> > > > > > > > > > > TR: Added point 340000,1.02e+06
> > > > > > > > > > > TR: Added point 340000,1.021e+06
> > > > > > > > > > > TR: Added point 341000,1.021e+06
> > > > > > > > > > > TR: Added point 341000,1.02e+06
> > > > > > > > > > > TR: Creating polygon for hole 1:
> > > > > > > > > (340000,1.02e+06,1.7e-308) (340000,1.021e+06,1.7e-308)
> > > > > > > > > (341000,1.021e+06,1.7e-308) (341000,1.02e+06,1.7e-308)
> > > > > > > > > > > TR: Geometry 1 : POLYGON ((340000.0000000000000000
> > > > > > > > > 1020000.0000000000000000, 340000.0000000000000000
> > > > > > > > > 1021000.0000000000000000, 341000.0000000000000000
> > > > > > > > > 1020000.0000000000000000))
> > > > > > > > > > > TR: Creating polygon 0:
> > > (339252,1.0193e+06,1.7e-308)
> > > > > > > > > (339252,1.02908e+06,1.7e-308)
> > > (348752,1.02908e+06,1.7e-308)
> > > > > > > > > (346102,1.01965e+06,1.7e-308) (339252,1.0193e+06,1.7e-308)
> > > > > > > > > > > TR: test
> > > > > > > > > > > Segmentation fault
> > > > > > > > > > > Output when the hole is removed:
> > > > > > > > > c_polygon_gml.cpp
> > > > > > > > > > > TR: Polygon 0
> > > > > > > > > > > TR: test
> > > > > > > > > > > TR: Geometry 0 : POLYGON ((339252.0000000000000000
> > > > > > > > > 1019302.0000000000000000, 339252.0000000000000000
> > > > > > > > > 1029077.0000000000000000, 348752.0000000000000000
> > > > > > > > > 1029077.0000000000000000, 346102.0000000000000000
> > > > > > > > > 1019653.0000000000000000, 339252.0000000000000000
> > > > > > > > > 1019302.0000000000000000))
> > > > > > > > > > > TR: Adding polygon 0
> > > > > > > > > > > TR: Creating multi-polygon
> > > > > > > > > > > TR: Creating string
> > > > > > > > > > > TR: TRACE EXIT:c_polygon_gml::WKTString
> > > > > > > > > > > ERROR:
> > > > > > > > > > > WTF format
> > > > > > > > > > > MULTIPOLYGON (((339252.0000000000000000
> > > > > > > > > > > 1019302.0000000000000000)))
> > > > > > > > > > > Sent: 28 June 2004 11:01
> > > > > > > with holes
> > > > > > > > > > > Can you send the test code ?
> > > > > > > > > > > There are currently no known bug ...
> > > > > > > > > > > --strk;
> > > > > > > > > > > On Mon, Jun 28, 2004 at 10:15:45AM +0100,
> > > Darren Carman
> > > > > > > > > > > wrote:
> > > > > > > > > > > > Hi all,
> > > > > > > > > > > > I am creating polygons with holes and want
> > > to use geos
> > > > > > > > > to allow me
> > > > > > > > > > > > to output them in WKT.
> > > > > > > > > > > > A polygon without a hole works fine, but as
> > > soon as I
> > > > > > > > > add a hole I
> > > > > > > > > > > > get a segmentation fault after calling the
> > > > > > > > > createPolygon function
> > > > > > > > > > > > (GeometryFactory) and trying to run toString on
> > > > > > > that polygon.
> > > > > > > > > > > > I am using version 1.0.
> > > > > > > > > > > > I have tried getting the latest version from CVS but
> > > > > > > > > this causes a
> > > > > > > > > > > > segmentation fault to occur while adding the
> > > > > 5th polygon
> > > > > > > > > > > > coordinate to the CoordinateList (there are only 4
> > > > > > > > > coordinates in
> > > > > > > > > > > > the test polygon, the 5th being the first
> > > one repeated
> > > > > > > > > - I tried
> > > > > > > > > > > > making it 6 to see if it was a problem with closing
> > > > > > > > > > > > the polygon but I still got a segmentation
> > > fault while
> > > > > adding the 5th).
> > > > > > > > > > > > Is there a fix for this, or has anyone come accross
> > > > > > > > > > > > it?
> > > > > > > > > > > > Thanks in advance,
> > > > > > > > > > > > Darren
> > > > > > > > > > > > "The information in this e-mail and any
> > > attachment is
> > > > > > > > > confidential
> > > > > > > > > > > > and may be privileged. If you have received this
> > > > > > > > > > > > e-mail
> > > > > > > > > in error,
> > > > > > > > > > > > please delete it immediately and destroy
> > > any copies on
> > > > > > > > > > > > your system. You should not retain, copy or use this
> > > > > > > e-mail for any
> > > > > > > > > > > > purpose, nor disclose all or any part of
> > > its content
> > > > > > > > > > > > to
> > > > > > > > > any other
> > > > > > > > > > > > person. Opinions expressed in this e-mail may not be
> > > > > > > > > endorsed by
> > > > > > > > > > > > the company and unless explicitly indicated, this
> > > > > > > > > e-mail shall not
> > > > > > > > > > > > form part of any binding agreement".
> > > > > > > > > > > > _______________________________________________
> > > > > > > > > > > > geos-devel mailing list
> > > http://geos.refractions.net/mailman/listinfo/geos-devel
> > > > > > > > > > geos-devel mailing list geos-devel at geos.refractions.net
