[geos-devel] Exception policy
strk
strk at keybit.net
Mon May 3 06:46:27 EDT 2004
Ok, I've read something around (http://www.gotw.ca/publications/mill22.htm).
Exception specification seems to be considered harmful most of
the times. I've then left the specifications in the code as comments,
since I'm still convinced its worth knowing (as far as the mantainer
can tell) which exceptions could be thrown.
Carl, could you check if you still get all those SIGABORT ?
--strk;
On Fri, Apr 30, 2004 at 11:37:30AM +0200, strk wrote:
> About the SIGABORT, I've found the problem.
> It's my fault.
> Trying to make the code strict I've added some throw() specifications
> and I missed to include some of the possible trhown exceptions,
> in particular AssertionFailedExceptions.
> I've now modified some of the code to specify a GEOSException *,
> from which AssertionFailedExecption derives.
> I did not known that, but I've learned that once you add a throw
> specificaion you cannot catch exceptions not specified in the
> list, but you're bound to receive a terminate()->abort() call.
> Now. Since it is in theory possible that exceptions other then
> GEOSException are thrown (out of memory for example), how should
> GEOS act, being it a library ?
> Should we completely omit throw specifications ?
> Is the default abort() acceptable in this case ?
> Should we add 'exception' to the specification list ?
> Comments welcome.
> --strk;
> On Mon, Apr 26, 2004 at 10:09:20PM -0400, Carl Anderson wrote:
> > On 04/26/2004 12:20:42 PM, strk wrote:
> > > On Mon, Apr 26, 2004 at 09:11:04AM -0700, Martin Davis wrote:
> > > > no need to pass it to the toGeometry method. Really, the
> > > toGeometry
> > > > method is only there to support converting Envelopes to a Geometry
> > > > it's not intended for outside use. Probably should be
> > > package-private
> > > > in JTS.
> > > > Make sense?
> > > Sure, so the bug is in the comment alone :)
> > > If that function is not part of the API, what code was trying to use
> > > it Carl ?
> > > --strk;
> > in PostGIS-0.8.1
> > postgis_geos_wrapper.cpp:
> > g = geomFactory->toGeometry(envelope,geomFactory-
> > >getPrecisionModel(), SRID);
> > matches a function in GEOS-1.0 but does not match anything in GEOS-CVS
> > Pls remember that my original email was addressing two seperate issues
> > (1) - the API creep
> > (2) - the stability of the geos library due to Asserts /
> > Exceptions / SegFaults. Especially in the context of the
> > C program Postgres
> > the latter involve bugs, the former with tagging and whether fixes to
> > 1.0.0 or CVS would be appropriate.
> > C.
> > Carl Anderson
> > GIS Manager Fulton County Georgia
> > carl.anderson at vadose.org
> > carl.anderson at co.fulton.ga.us
> > geos-devel mailing list
> > geos-devel at geos.refractions.net
> > http://geos.refractions.net/mailman/listinfo/geos-devel
