[geos-devel] Current status
strk
strk at keybit.net
Mon May 17 08:54:42 EDT 2004
On Mon, May 17, 2004 at 02:32:41PM +0200, strk wrote:
> I've fixed a but in PrecisionModel::makePrecise().
> Now the testLeaksBig.xml test gives the same result in both
> jts-1.4 and geos CVS (5 isValid failures).
> I've also run with success all jts-1.4 tests in test/validate.
> Tests in test/vivid with failures are:
> TestFunctionPLPrec.xml
> TestSimple.xml
> TestValid.xml
> TestValid2-big.xml
> TestValid2.xml
> TestWithinDistance.xml
> Other tests succeed.
Good news: the detected failures were due to bugs in the XML parser.
No more failures. All JTS-1.4 tests run with success.
The 5 isValid failures of testLeaksBig might be errors in the XML itself...
Martin ?
--strk;
> --strk;
> On Thu, May 06, 2004 at 07:46:42PM +0200, strk wrote:
> > I've got doc/example to run with no leaks.
> > Now it's time to get results correct.
> > In particular here are a the issues I'll approach next:
> > o check for leaks with runs against .xml
> > o doc/example catches "side location conflict"
> > TopologyExceptions is it an expected behaviour ?
> > o Every attempt to compute a buffer with original
> > precision (bufferOriginalPrecision) results in a
> > "depth mismatch" exception.
> > o Buffered geoms starts and end with a point
> > from the original geometry.
> > --strk;
> > geos-devel mailing list
> > geos-devel at geos.refractions.net
> > http://geos.refractions.net/mailman/listinfo/geos-devel
