[geos-devel] Current status
Martin Davis mbdavis at VividSolutions.com
Mon May 17 17:26:47 EDT 2004
Yury:
I've made one small bug fix to JTS since March.  (It will be in 1.4.1,
which we haven't quite released yet).  The change is minor - fixes a bug
which causes some kinds of MultiPolygons to report as invalid.  Seems to
me you might as well implement this in GEOS as well right now.  I've
attached the file which changed (let me know if you need help in
figuring out the exact changes).
Martin
Martin Davis, Senior Technical Architect
Vivid Solutions Inc.
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> -----Original Message-----
> From: Yury A. Bychkov [mailto:me at yury.ca]
> Sent: May 17, 2004 2:16 PM
> To: 'GEOS Development List'
> Subject: [geos-devel] Current status
> The GEOS code is now completely up to date. It has been
> synchronized with the latest (March 26, 2004) changes to JTS.
> The changes were minor and wouldn't affect any test results.
> Yury
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
Type: application/octet-stream
Desc: IsValidOp.java
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20040517/6724cf77/IsValidOp.obj
