[geos-devel] Failures in testLeaksBig.xml
Martin Davis mbdavis at VividSolutions.com
Thu May 20 11:42:20 EDT 2004
I checked out the 5 failures in the testLeaksBig.xml file.  They're all
spurious, and due to the fact that JTS 1.4 now allows repeated points in
geometries, as per the SFS spec.
So these don't indicate any problem with GEOS.  You should fix up your
testLeaksBig.xml file to change the results of those cases to "true".
Martin Davis, Senior Technical Architect
Vivid Solutions Inc.
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> -----Original Message-----
> From: strk [mailto:strk at keybit.net]
> Sent: May 17, 2004 5:55 AM
> To: geos-devel at geos.refractions.net; Paul Ramsey
> Subject: Re: [geos-devel] Current status
> On Mon, May 17, 2004 at 02:32:41PM +0200, strk wrote:
> > I've fixed a but in PrecisionModel::makePrecise().
> > Now the testLeaksBig.xml test gives the same result in both jts-1.4
> > and geos CVS (5 isValid failures).
> > I've also run with success all jts-1.4 tests in
> test/validate. Tests
> > in test/vivid with failures are:
> > 	TestFunctionPLPrec.xml
> > 	TestSimple.xml
> > 	TestValid.xml
> > 	TestValid2-big.xml
> > 	TestValid2.xml
> > 	TestWithinDistance.xml
> > Other tests succeed.
> Good news: the detected failures were due to bugs in the XML
> parser. No more failures. All JTS-1.4 tests run with success.
> The 5 isValid failures of testLeaksBig might be errors in the
> XML itself... Martin ?
> --strk;
> > --strk;
> > On Thu, May 06, 2004 at 07:46:42PM +0200, strk wrote:
> > > I've got doc/example to run with no leaks.
> > > Now it's time to get results correct.
> > > In particular here are a the issues I'll approach next:
> > > 	o  check for leaks with runs against .xml
> > > 	o  doc/example catches "side location conflict"
> > > 	   TopologyExceptions is it an expected behaviour ?
> > > 	o  Every attempt to compute a buffer with original
> > > 	   precision (bufferOriginalPrecision) results in a
> > > 	   "depth mismatch" exception.
> > > 	o  Buffered geoms starts and end with a point
> > > 	   from the original geometry.
> > > --strk;
> > > _______________________________________________
> > > geos-devel mailing list
> > > http://geos.refractions.net/mailman/listinfo/geos-devel
