[geos-devel] Next Step
strk strk at keybit.net
Fri May 21 09:46:04 EDT 2004
Postgis builds cleanly.
All tests from JTS-1.4 tree pass.
In testLeaksBig.xml there are:
	59 intersection tests
	51 difference tests
	55 sydifference tests
There are a couple of issues left:
	1) Yury is trying what works in PrecisionModel::makePrecise()
	   to round to nearest integer in a JTS-1.4 compatible way
	   [ rint() did not work, round() is not JTS-1.4 compatible,
	     nearbyint() is in test ]
	2) doc/example runs get TopologyException: side location conflict
	   (0,250) on intersection. I'm working on this.
	3?) BufferSubgraph::computeDepths might be faster then it is
	     (read comments there)
--strk;
On Thu, May 20, 2004 at 08:38:47AM -0700, Paul Ramsey wrote:
> Sounds like the current revision is ready for other testing?
> Does postgis still build cleanly against this new version? Probably some
> stress testing there would be the next step...
> Q: Do the test cases available cover the
> Intersection/Difference/Symdifference areas well, or are those
> relatively lightly tested?
>        __
>       | Paul Ramsey
>       | Refractions Research
>       | Email: pramsey at refractions.net
>       | Phone: (250) 885-0632
>       \_
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
