[geos-devel] build problem on Solaris
Jan Kolar kolda at 3dgi.dk
Fri Nov 19 10:33:43 EST 2004
ok, including
#include <ieeefp.h>
in platforms.h solves the problem with finite()/isinf() functions. to what
has been posted i can add that i have found that isinf() was in earlier
versions of Solaris, however since Solaris 8/9 isinf() doesn't exist at
all. so no i get further and have a new error :(
 g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
-I../../source/headers/geos -I../../source/headers -DGEOS_VERSION=2.1.0 -g
-O2 -c ../index/quadtree/QuadTreeNode.cpp -Wp,-MD,.deps/QuadTreeNode.TPlo
-fPIC -DPIC -o .libs/QuadTreeNode.o
../index/quadtree/QuadTreeNode.cpp: In method `class string
geos::QuadTreeNode::toString() const':
../index/quadtree/QuadTreeNode.cpp:175: implicit declaration of function
`int geos::sprintf(...)'
*** Error code 1
make: Fatal error: Command failed for target `QuadTreeNode.lo'
Current working directory
/group/3dgidata/Postgres/source/postgresql-7.4.6/contrib/geos-2.1.0/source/geom
*** Error code 1
make: Fatal error: Command failed for target `all-recursive'
*** Error code 1
