[geos-devel] make problems under fedora core 2
Michael Mallete mrmallete at gmail.com
Tue Oct 12 23:13:38 EDT 2004
good day everyone!
i've encountered this problem with geos 1.0 up to goes 2.0.
unfortunately, i still encounter it with geos 2.0.1
whenever i run make, i get this error:
cd . && \
  /bin/sh /root/installers/geos-2.0.1/missing --run automake-1.7 --gnu  Makefile
configure.in:23: version mismatch.  This is Automake 1.7.9,
configure.in:23: but the definition used by this AM_INIT_AUTOMAKE
configure.in:23: comes from Automake 1.7.8.  You should recreate
configure.in:23: aclocal.m4 with aclocal and run automake again.
make: *** [Makefile.in] Error 1
so i run aclocal, then automake.
then when i run make again, i get this:
./configure: line 19506: syntax error near unexpected token `long'
./configure: line 19506: `PGAC_TYPE_64BIT_INT(long int)'
i am using an i686 pc under fedora core 2. automake is 1.7.9.
thanx in advance and more power! :)
-Myk
