[geos-devel] make problems under fedora core 2
Michael Mallete
mrmallete at gmail.com
Wed Oct 13 22:15:53 EDT 2004
hello sir! thanx for the respone. i figured out what i was doing
wrong. i extracted the package using konqueror instead of the usual
bunzip2 command. it usually works with gunzip files. i've installed it
now. sorry for the slight disturbance. thanx again! :)
>Micheal, when downloading a packaged version you should not need
>to run automake, autoconf or whatever.
>Just configure; make; make install;
>If you got a CVS snapshot use the ./autogen.sh script.
>Please, let me know.
>--strk;
