[geos-devel] "self intersecting" polys
Martin Davis
mbdavis at VividSolutions.com
Thu Sep 2 19:57:40 EDT 2004
Um... If you mean what I think you mean by "zero-width corridor
polygons" (ie. The case in question) - well, depends what you mean by
"easy". There's no mystery about the machinery, and all the pieces are
there in JTS/GEOS, but there's a certain amount of bookeeping required
to keep everything straight. Especially if you want to handle a series
of ZWC's all touching one another...
Martin Davis, Senior Technical Architect
Vivid Solutions Inc. www.vividsolutions.com
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> -----Original Message-----
> From: Paul Ramsey [mailto:pramsey at refractions.net]
> Sent: September 2, 2004 4:02 PM
> To: GEOS Development List
> Subject: Re: [geos-devel] "self intersecting" polys
> Yes, we all look forward to the magical MakeValid() method :)
> For the relatively simple case of Zero-Width-Corridor polygons, it
> should be easy to write a function that separates out the holes from
> hulls, yes?
> P.
> Martin Davis wrote:
> > Unfortunately I can't think of an easy way to convert
> > self-intersecting polygons to valid JTS/GEOS polygons using the
> > current API. This might be a useful function to have in
> the future,
> > however.
> >>From: Chris G. Nicholas [mailto:cgn at globexplorer.com]
> >>Sent: September 2, 2004 3:37 PM
> >>To: geos-devel at geos.refractions.net
> >>Subject: [geos-devel] "self intersecting" polys
> >>How difficult would it be for GEOS to support so-called "self
> >>intersecting" polygons - i.e. those with a common vertex.
> >>Must we explode this sort of thing into a huge number of
> >>overlapping polygons?
> >>thanks!
> >>Chris Nicholas
> >>GlobeXplorer
> > geos-devel mailing list
> > http://geos.refractions.net/mailman/listinfo/geos-devel
