[geos-devel] GEOS returning invalid geometries
Carl Anderson carl.anderson at vadose.org
Thu Sep 16 19:51:16 EDT 2004
I just stumbled on an issue that in Postgis/GEOS.
in Pg
select difference(a.shape,b.shape)   (shapes,script attached )
returns:
   1)   invalid geometry
   2)   different results than JUMP 1.1.2
Notice the first ring has the same coords in the 1st, 3rd and 5th
vertex.
Notice the second ring is equally bad.
postgresql 7.4.5, Postgis 9.0, Geos 2.0
I changed
   geosInit in Postgis to explicitly declare FLOATING
with no change.
postgis result
MULTIPOLYGON (((
            2149664.15952312 1302059.43445874,
            2149522.80170403 1302723.18036188,
            2149720.712 1302078.1109,
            2153145.9794 1304923.3463,
            2153267.92794731 1305161.93238453,
jump result
MULTIPOLYGON (((
            2149664.1595231155 1302059.4344587359,
            2153267.9279473107 1305161.93238453,
poking into GEOS, for a solution now.
C.
Carl Anderson
select difference(a.shape,b.shape) from
 ( select GEOMETRY('SRID=-1;MULTIPOLYGON(((2151789.13999476 1301676.31682542,2151093.75 1301677.46872393,2150018.20993862 1301679.25033281,2150000 1301777.94000014,2149991.13000001 1301826.01000014,2149990.70206952 1301875,2149989.80000009 1301978.27000013,2149683.7003487 1301967.32001233,2149681.2300006 1301979.27999987,2149522.80170403 1302723.18036188,2149664.15952312 1302059.43445874,2149720.712 1302078.1109,2149720.7965 1302078.1388,2149892.2119 1302134.7359,2149896.595 1302137.4362,2149903.9186 1302138.6315,2149944.9186 1302152.3815,2149961.798 1302162.8349,2149988.562 1302167.4438,2150029.062 1302181.8188,2150044.8628 1302191.7964,2150067.9124 1302195.9518,2150108.1624 1302210.9518,2150118.765 1302217.7636,2150133.2724 1302220.4552,2150163.5224 1302232.0802,2150174.2178 1302239.0288,2150188.1479 1302241.6855,2150218.1479 1302253.5605,2150233.3703 1302263.5589,2150252.0655 1302267.2588,2150291.8155 1302283.6338,2150303.748 1302291.5901,2150317.5638 1302294.4004,2150347.3138 1302307.0254,2150363.2398 1302317.7665,2150380.602 1302321.4225,2150410.102 1302334.4225,2150424.7141 1302344.4242,2150439.6689 1302347.6692,2150478.9189 1302365.5442,2150494.5547 1302376.3882,2150509.5962 1302379.7529,2150548.3462 1302398.0029,2150565.5129 1302410.0721,2150573.0132 1302413.5425,2150587.7749 1302416.9734,2150616.7749 1302431.2234,2150621.1957 1302434.3865,2150624.9805 1302435.2731,2150653.9805 1302449.6481,2150659.2961 1302453.4655,2150686.5906 1302466.0946,2150715.3406 1302480.8446,2150721.7342 1302485.5035,2150747.8226 1302497.795,2150776.3226 1302512.92,2150781.9122 1302517.0527,2150800.7625 1302526.0554,2150829.0125 1302541.4304,2150834.4323 1302545.4817,2150850.3944 1302553.1958,2150888.1444 1302574.1958,2150898.0569 1302581.6772,2150923.4227 1302594.1771,2150951.1727 1302610.1771,2150955.5516 1302613.5352,2150965.2489 1302618.3511,2150993.2489 1302634.7261,2151006.9358 1302645.2893,2151033.8101 1302658.9367,2151061.3101 1302675.6867,2151066.8193 1302680.0177,2151076.1703 1302684.8053,2151103.6703 1302701.8053,2151113.0242 1302709.2089,2151127.5506 1302716.7443,2151154.8006 1302733.9943,2151164.7798 1302741.9799,2151178.634 1302749.2611,2151205.634 1302766.7611,2151215.1772 1302774.482,2151227.0955 1302780.8199,2151254.0955 1302798.6949,2151264.3705 1302807.0908,2151275.9667 1302813.3318,2151301.4667 1302830.5818,2151317.4612 1302843.7847,2151333.3123 1302852.4658,2151358.5623 1302870.0908,2151369.6794 1302879.4052,2151379.4254 1302884.8042,2151409.4254 1302906.1792,2151419.2455 1302914.488,2151427.0944 1302918.8784,2151452.0944 1302937.0034,2151472.4321 1302954.3557,2151486.5 1302962.375,2151511 1302980.75,2151515.1992 1302984.392,2151517.871 1302985.9208,2151542.371 1303004.4208,2151555.1977 1303015.5819,2151562.6829 1303019.9132,2151587.1829 1303038.7882,2151610.0429 1303058.8751,2151621.2578 1303065.4878,2151645.2578 1303084.6128,2151663.7847 1303101.1633,2151671.4043 1303105.7217,2151711.9043 1303138.8467,2151727.2156 1303152.701,2151732.6408 1303155.9842,2151756.8908 1303176.2342,2151782.5682 1303199.7071,2151789.7587 1303204.1393,2151813.5087 1303224.6393,2151815.4484 1303227.3239,2151819.5128 1303229.8376,2151843.2628 1303250.4626,2151852.6027 1303263.4298,2151871.3638 1303275.2179,2151894.8638 1303296.2179,2151906.1862 1303312.175,2151927.2847 1303325.6772,2151950.2847 1303346.9272,2151952.3184 1303349.8444,2151955.947 1303352.174,2151978.947 1303373.549,2151988.9745 1303387.9774,2152006.1016 1303399.1451,2152028.8516 1303420.8951,2152035.9727 1303431.2978,2152047.4844 1303438.8846,2152077.4844 1303468.1346,2152086.8776 1303482.0018,2152101.2619 1303491.6131,2152123.5119 1303513.8631,2152132.0285 1303526.6091,2152144.3676 1303534.9544,2152166.3676 1303557.4544,2152172.8994 1303567.3499,2152181.9513 1303573.5281,2152203.7013 1303596.1531,2152214.6948 1303612.9624,2152229.0911 1303622.9366,2152250.5911 1303645.9366,2152257.4059 1303656.5172,2152265.9047 1303662.4592,2152287.1547 1303685.5842,2152297.3726 1303701.5984,2152309.4524 1303710.1576,2152337.4524 1303741.4076,2152345.6217 1303754.3901,2152354.7984 1303760.9608,2152375.5484 1303784.5858,2152383.8197 1303797.8761,2152386.5234 1303800.8243,2152394.9562 1303806.9342,2152415.4562 1303830.8092,2152418.3714 1303835.5523,2152433.496 1303852.0447,2152460.496 1303884.1697,2152467.3612 1303895.4729,2152496.3725 1303927.7951,2152522.6225 1303960.4201,2152525.57 1303965.3922,2152535.4179 1303976.4501,2152554.9179 1304001.0751,2152559.4686 1304008.82,2152573.0882 1304024.286,2152592.3382 1304049.161,2152596.1793 1304055.7826,2152606.3682 1304067.4552,2152625.3682 1304092.4552,2152630.5974 1304101.561,2152643.0307 1304115.966,2152661.7807 1304141.216,2152666.5386 1304149.609,2152676.6344 1304161.4187,2152701.3844 1304195.4187,2152710.4796 1304211.642,2152727.294 1304231.6502,2152745.294 1304257.2752,2152751.7247 1304268.9761,2152762.0038 1304281.3464,2152779.7538 1304307.2214,2152784.7898 1304316.5062,2152792.0924 1304325.3692,2152815.5924 1304360.2442,2152827.3255 1304382.0927,2152842.0803 1304400.3359,2152864.8303 1304435.4609,2152870.4023 1304446.0671,2152876.5904 1304453.7831,2152899.0904 1304489.1581,2152909.6084 1304509.381,2152919.878 1304522.3828,2152941.878 1304558.1328,2152954.3887 1304582.6296,2152964.6697 1304595.8717,2152980.6697 1304622.8717,2152989.1298 1304639.7844,2152995.1819 1304647.6678,2153010.9319 1304674.9178,2153016.6057 1304686.4162,2153020.3083 1304691.275,2153041.0583 1304727.775,2153056.5276 1304759.4091,2153064.849 1304770.5414,2153084.849 1304807.2914,2153093.2632 1304824.9102,2153097.1535 1304830.1684,2153111.9035 1304857.9184,2153119.6672 1304874.3827,2153122.8304 1304878.6981,2153137.3304 1304906.5731,2153143.6675 1304920.1684,2153145.9794 1304923.3463,2153267.92794731 1305161.93238453,2154026.63000005 1305154.04,2153992.05267314 1305003.28168046,2153991.3 1305000,2153989.61 1304992.6199948,2153982.72001646 1304962.58006643,2154750.21 1304968.07999877,2154776.26 1304919.729999,2155000 1304549.62,2155021.95316321 1304513.30753534,2155027.75999909 1304502.53999999,2155000 1304502.49,2154952.76 1304502.4099999,2153978.37994067 1304500.67999335,2153980.23652088 1303912.53744191,2153980.27685333 1303899.7606036,2153982.15 1303306.36999417,2153984.18885325 1302661.11999184,2153985.39999116 1302277.82279529,2152915.71 1302279.8499909,2152922.35035352 1301875,2152925.63999457 1301674.43671002,2151883.82 1301676.15999009,2151789.13999476 1301676.31682542)))
') as shape ) as a,
( select GEOMETRY('SRID=-1;MULTIPOLYGON(((2151350.7217 1310917.5965,2151339.5676 1310910.5202,2151302.3176 1310876.6452,2151297.8501 1310870.2905,2151289.6534 1310865.053,2151245.1534 1310824.053,2151240.0141 1310816.692,2151230.8916 1310810.8154,2151077.5581 1310667.4379,2150943.2228 1310541.8251,2150472.3975 1310101.5709,2150472.3916 1310101.5654,2150269.1608 1309911.5328,2150018.1534 1309676.8264,2150011.7476 1309667.5791,2150000.8143 1309660.466,2149977.3143 1309638.091,2149968.4138 1309625.1176,2149953.9846 1309615.6036,2149922.9846 1309585.3536,2149913.8957 1309571.9297,2149899.9881 1309562.6369,2149876.9881 1309539.6369,2149867.6953 1309525.7293,2149854.2714 1309516.6404,2149824.0214 1309485.6404,2149810.1939 1309464.6693,2149791.6492 1309451.8721,2149769.3992 1309428.2471,2149764.0477 1309419.9723,2149757.2177 1309415.2249,2149727.7177 1309383.4749,2149715.5818 1309364.57,2149700.9697 1309354.2501,2149679.2197 1309330.1251,2149667.8659 1309312.1432,2149655.0904 1309302.9881,2149626.5904 1309270.4881,2149619.9438 1309259.7992,2149612.803 1309254.6389,2149591.553 1309230.0139,2149587.0709 1309222.7414,2149563.3955 1309196.8353,2149535.6455 1309163.5853,2149532.0492 1309157.641,2149516.9875 1309140.9754,2149496.4875 1309115.8504,2149491.692 1309107.8236,2149474.5874 1309088.6439,2149454.3374 1309063.1439,2149449.9614 1309055.708,2149436.6269 1309040.5914,2149410.1269 1309006.4664,2149405.0463 1308997.725,2149391.4807 1308982.1653,2149365.2307 1308947.5403,2149357.5995 1308934.2335,2149340.0908 1308913.8251,2149320.8408 1308887.5751,2149313.0902 1308873.8069,2149298.0539 1308856.0168,2149279.3039 1308829.6418,2149276.8402 1308825.1888,2149272.5211 1308820.0556,2149247.5211 1308784.5556,2149237.5675 1308766.4702,2149221.9698 1308747.6089,2149203.7198 1308720.7339,2149194.3091 1308703.2854,2149181.7879 1308687.9115,2149158.0379 1308651.7865,2149151.7272 1308639.8734,2149144.2773 1308630.6365,2149120.7773 1308594.1365,2149107.9197 1308569.5814,2149094.9303 1308553.1703,2149077.9303 1308525.6703,2149075.0211 1308519.988,2149072.3413 1308516.5882,2149055.3413 1308488.8382,2149043.1727 1308464.952,2149033.3503 1308452.2814,2149011.3503 1308415.0314,2149002.3719 1308397.0495,2148996.0862 1308388.8442,2148979.8362 1308360.5942,2148968.1629 1308336.8754,2148961.1958 1308327.6444,2148940.1958 1308289.8944,2148930.6484 1308270.1387,2148925.7423 1308263.5609,2148910.2423 1308234.9359,2148896.4137 1308205.9012,2148890.6223 1308198.0067,2148870.6223 1308159.6317,2148863.9651 1308145.3641,2148861.5189 1308142.0031,2148743.5189 1307911.3781,2148743.1524 1307910.5848,2148743.0206 1307910.4037,2148448.8151 1307334.8057,2148444.0868 1307325.716,2148440.9425 1307319.8004,2148438.8481 1307315.952,2148434.8507 1307308.9203,2148432.8178 1307305.4032,2148427.2519 1307296.6523,2148423.4812 1307290.8305,2148419.5392 1307284.9804,2148418.1981 1307283.0254,2148415.2445 1307278.9679,2148412.7351 1307275.5886,2148409.6069 1307271.4725,2148406.4321 1307267.3701,2148402.4487 1307262.3397,2148400.376 1307259.7637,2148398.6851 1307257.7944,2148396.3262 1307255.1087,2148388.1192 1307245.9491,2148385.7169 1307243.3348,2148384.5102 1307242.0439,2148383.3064 1307240.7917,2148379.528 1307236.9274,2148370.8448 1307228.4613,2148364.3803 1307222.4536,2148363.389 1307221.5376,2148360.4854 1307219.0161,2148357.0551 1307216.0553,2148346.3124 1307207.2687,2148339.5603 1307202.1702,2148335.9714 1307199.4785,2148327.1273 1307193.1771,2148323.1011 1307190.5116,2148318.7418 1307187.6862,2148315.3497 1307185.5389,2148307.3302 1307180.5813,2148306.7766 1307180.2576,2148303.6398 1307178.449,2148294.2694 1307173.2363,2148290.2346 1307171.0404,2148284.1188 1307168.0089,2148278.8608 1307165.4252,2148275.1969 1307163.6996,2148267.2819 1307160.095,2148257.8458 1307156.2078,2148257.1408 1307155.9288,2148251.7585 1307153.8603,2148243.8438 1307150.9108,2148230.9302 1307146.58,2148065.2881 1307091.8891,2148065.2251 1307091.8503,2148065.1189 1307091.8332,2146984.1189 1306734.8332,2146980.0186 1306732.307,2146973.1653 1306731.1892,2146953.6387 1306724.6458,2146933.8663 1306718.0896,2146926.3547 1306713.4554,2146913.9736 1306711.4058,2146890.4736 1306703.4058,2146885.895 1306700.5559,2146878.5898 1306699.3286,2146831.5898 1306683.0786,2146826.9677 1306680.1863,2146819.7645 1306678.9587,2146796.2645 1306670.7087,2146789.9192 1306666.7171,2146780.2966 1306665.0453,2146733.5466 1306648.2953,2146725.7758 1306643.3722,2146714.3931 1306641.3493,2146690.8931 1306632.7243,2146687.345 1306630.4572,2146682.29 1306629.5498,2146635.79 1306612.2998,2146630.9221 1306609.1775,2146624.1232 1306607.9405,2146577.6232 1306590.4405,2146567.771 1306584.0883,2146554.4756 1306581.6048,2146507.9756 1306563.6048,2146501.0174 1306559.0722,2146491.9826 1306557.3541,2146445.7326 1306539.1041,2146438.6279 1306534.443,2146429.6901 1306532.7131,2146383.6901 1306514.2131,2146373.3794 1306507.4004,2146360.9032 1306504.9252,2146291.9032 1306476.4252,2146281.4583 1306469.4536,2146269.3769 1306466.9987,2146246.3769 1306457.2487,2146244.1368 1306455.7384,2146241.6101 1306455.2224,2146195.8601 1306435.7224,2146188.2353 1306430.5712,2146179.8229 1306428.8241,2146157.0729 1306418.9491,2146151.6918 1306415.2877,2146145.9102 1306414.0731,2146123.1602 1306404.0731,2146117.7499 1306400.3736,2146112.065 1306399.1657,2146066.565 1306378.9157,2146061.1266 1306375.1785,2146055.5376 1306373.9776,2146032.7876 1306363.7276,2146027.5643 1306360.1207,2146022.311 1306358.9799,2145977.061 1306338.3549,2145966.1663 1306330.7965,2145955.5824 1306328.4485,2145910.5824 1306307.4485,2145904.9805 1306303.5248,2145899.7034 1306302.3414,2145877.2034 1306291.7164,2145871.5773 1306287.7567,2145866.3941 1306286.5821,2145843.8941 1306275.8321,2145838.3399 1306271.904,2145833.3341 1306270.7579,2145788.5841 1306249.1329,2145777.1734 1306241.025,2145767.2544 1306238.707,2145722.7544 1306216.707,2145716.9771 1306212.5627,2145712.1061 1306211.4128,2145667.6061 1306189.1628,2145661.8088 1306184.9843,2145657.0293 1306183.8447,2145634.7793 1306172.5947,2145631.941 1306170.5393,2145618.901 1306164.4989,2145574.651 1306141.7489,2145571.5527 1306139.4893,2145558.7589 1306133.5102,2145536.7589 1306122.0102,2145534.5753 1306120.4063,2145526.3548 1306116.5422,2145482.3548 1306093.2922,2145480.0767 1306091.611,2145472.0238 1306087.8038,2145450.0238 1306076.0538,2145446.3483 1306073.3288,2145434.2275 1306067.5481,2145390.4775 1306043.7981,2145386.5407 1306040.8586,2145374.6758 1306035.1501,2145331.1758 1306011.1501,2145328.4982 1306009.1366,2145321.0284 1306005.5224,2145299.2784 1305993.3974,2145296.3363 1305991.1748,2145288.5672 1305987.3935,2145245.3172 1305963.0185,2145239.3004 1305958.4511,2145224.5366 1305951.1826,2145203.0366 1305938.8076,2145199.9738 1305936.4606,2145193.082 1305933.049,2145128.582 1305895.549,2145125.4378 1305893.1287,2145118.7025 1305889.7764,2145097.2025 1305877.1514,2145090.3714 1305871.8697,2145076.705 1305864.9903,2145033.955 1305839.3653,2145030.1862 1305836.424,2145023.2278 1305832.9007,2144980.7278 1305807.1507,2144973.4689 1305801.4578,2144960.9603 1305795.0549,2144599.4785 1305571.6781,2144625.5132 1305718.1234,2144661.9205 1305942.635,2144674.0563 1306106.4678,2144686.192 1306276.3685,2144686.192 1306561.5588,2144680.1241 1306701.1201,2144655.8526 1306858.885,2144631.4922 1307040.906,2144619 1307108.625,2144601.2417 1307204.7542,2144588.4368 1307252.7725,2144556.8188 1307371.3401,2144558.3938 1307373.9214,2144554.25 1307389.875,2144547.25 1307415.5,2144540 1307441,2144532.5 1307466.5,2144525 1307491.875,2144517.25 1307517.25,2144509.25 1307542.625,2144501.25 1307567.875,2144493 1307593.125,2144484.5 1307618.25,2144475.75 1307643.375,2144462.5 1307680.875,2144453.5 1307705.75,2144444.25 1307730.625,2144430 1307767.75,2144415.25 1307804.875,2144405.25 1307829.375,2144395.25 1307853.875,2144384.75 1307878.375,2144374.25 1307902.75,2144363.5 1307927,2144352.75 1307951.25,2144336.25 1307987.375,2144324.75 1308011.375,2144313.5 1308035.375,2144295.75 1308071.125,2144284 1308094.875,2144272 1308118.5,2144259.75 1308142,2144241 1308177.125,2144228.25 1308200.5,2144215.5 1308223.75,2144202.5 1308246.875,2144189.5 1308269.875,2144176 1308292.875,2144162.75 1308315.75,2144125.5 1308378,2144109 1308404.875,2144089.25 1308437,2144072.25 1308463.75,2144052 1308495.5,2144031 1308527,2144006.25 1308563.5,2143984.75 1308594.625,2143558.5 1309203.875,2143543.5 1309227,2143529.25 1309250.75,2143515.75 1309275,2143503.25 1309299.625,2143491.5 1309324.625,2143480.75 1309350.125,2143470.75 1309375.875,2143461.75 1309402.125,2143453.5 1309428.5,2143446.25 1309455.25,2143440 1309482.125,2143434.75 1309509.25,2143430.5 1309536.625,2143427 1309564,2143424.5 1309591.625,2143395.25 1310000,2143364.75 1310425.375,2143332 1310885,2143289.25 1311534.375,2143251.25 1312088.25,2143249 1312119.625,2143246.75 1312152.625,2143244.5 1312191.25,2143243 1312217.125,2143241.25 1312252.125,2143238.75 1312296.375,2143236 1312340.625,2143231.5 1312407,2143226.75 1312473.25,2143215.25 1312621.75,2143205.25 1312757.875,2143171.25 1313276.875,2143158.5 1313467.625,2143106.5 1314235.75,2143073.5 1314716.5,2143071.5 1314753.625,2143069 1314799.875,2143066.75 1314837.75,2143055.75 1315000,2142996.5 1315867.5,2142973 1316443.375,2142952.5 1316515.625,2142943 1316671.375,2142940.75 1316707.75,2142916.75 1317052.875,2142906.5 1317204,2142895.5 1317383.25,2142873 1317690.625,2142804.75 1318725.625,2142772.25 1319185.75,2142719.5 1320000,2142714.75 1320072,2142712.75 1320102.75,2142710.5 1320133.5,2142708.25 1320164.25,2142706 1320195,2142703.25 1320229.5,2142668.25 1320760.375,2142665.75 1320797,2142641.75 1321134.25,2142639.75 1321160.5,2142637.75 1321186.875,2142635.75 1321213.125,2142633.75 1321239.5,2142632 1321265.875,2142630.25 1321292.125,2142628.5 1321318.5,2142626.75 1321344.875,2142625.25 1321371.25,2142624 1321397.5,2142622.5 1321423.875,2142619.75 1321476.5,2142618 1321502.875,2142601 1321732.625,2142593.25 1321845.625,2142591.75 1321881.625,2142589.75 1321917.625,2142587.75 1321953.5,2142585.5 1321989.5,2142583.25 1322025.375,2142580.5 1322061.375,2142577.75 1322097.25,2142566 1322242.25,2142563.75 1322272,2142562 1322301.75,2142560.5 1322331.375,2142555.5 1322437.125,2142554 1322464.25,2142552.25 1322491.375,2142550.5 1322518.5,2142548.5 1322545.5,2142546.25 1322572.625,2142544 1322597.625,2142524 1322875.625,2142502 1323209.5,2142500 1323239.75,2142498.75 1323269.875,2142497.5 1323300.125,2142496.75 1323330.375,2142496.25 1323360.625,2142496 1323390.875,2142495.75 1323558.375,2142495.75 1323584.25,2142496 1323610.25,2142496.25 1323636.125,2142496.75 1323662.125,2142497.25 1323688,2142498 1323714,2142498.75 1323739.875,2142499.75 1323765.75,2142501 1323791.75,2142502.25 1323817.625,2142503.5 1323843.5,2142505.25 1323869.375,2142506.75 1323895.25,2142508.5 1323921.125,2142510.5 1323947,2142512.5 1323972.875,2142514.75 1323998.75,2142548 1324375.75,2142551.5 1324413.75,2142573.25 1324653.625,2142588 1324828.625,2142604.75 1325000,2142623.25 1325190.625,2142625.75 1325223.25,2142628.5 1325255.875,2142631 1325288.625,2142633.75 1325321.25,2142636.5 1325353.875,2142639.5 1325386.5,2142642.25 1325419.125,2142645.25 1325451.75,2142648.25 1325484.25,2142651.5 1325516.875,2142654.5 1325549.5,2142720.5 1326267.25,2142723 1326300.75,2142725.25 1326325.875,2142728 1326351,2142733.75 1326397.5,2142736.5 1326423.5,2142738.75 1326451.625,2142740.25 1326479.875,2142745.5 1326538,2142812.25 1327263.875,2142821.75 1327336.25,2142826.5 1327375,2142829.75 1327399.875,2142834 1327425.5,2142841.5 1327457,2142861 1327527.25,2142859.75 1327569.875,2142856.25 1327702.625,2142855.25 1327730.5,2142855.25 1327755.375,2142856.25 1327783.25,2142858.75 1327820.25,2142862.5 1327854.125,2142867.25 1327884.75,2142882 1327960.875,2142888 1327988.625,2142895 1328018.25,2142961 1328253,2142969.75 1328281.25,2142979 1328307.125,2142990.5 1328334.375,2143001.25 1328357.25,2143014.25 1328379,2143031.75 1328402.75,2143049.5 1328423.25,2143070.75 1328445.25,2143094.75 1328466.125,2143120 1328445,2143145.25 1328424.25,2143171 1328403.875,2143203.75 1328378.875,2143230 1328359.25,2143263.5 1328335.375,2143290.5 1328316.625,2143324.25 1328294,2143354.75 1328266.875,2143352.25 1328221,2143351.25 1328193,2143350.5 1328146.375,2143386 1328157.25,2143409.25 1328168.5,2143438.5 1328181.875,2143480.5 1328200.125,2143530 1328173.75,2143566.75 1328155.25,2143663 1328113.125,2143686 1328103,2144240.25 1327864.5,2144514.25 1327746.5,2145000 1327540.125,2145240.25 1327438.375,2145264.25 1327429.25,2145298.25 1327417.375,2145332.5 1327406.25,2145362 1327397.375,2145386.75 1327390.5,2145427.5 1327375.375,2145476.75 1327369.375,2145502 1327364.625,2145527.25 1327360.25,2145585.25 1327351,2145621.75 1327346.625,2145651.75 1327344.125,2145685 1327342.375,2145711.75 1327342,2145746.5 1327342.5,2145776 1327343.5,2145812.75 1327345.125,2145849.75 1327347,2145886.5 1327349.25,2145923.25 1327351.875,2145967.5 1327355.5,2146285.75 1327385.375,2146328 1327388.5,2146381 1327392,2146423.5 1327394.375,2146476.5 1327397,2146518.75 1327398.75,2146561.25 1327400.25,2146603.75 1327401.5,2146646.25 1327402.375,2146688.75 1327403,2146731.75 1327403.25,2146784.25 1327403.25,2146837.25 1327402.75,2146890.25 1327401.75,2146922.25 1327401,2146964.5 1327399.625,2146996.5 1327398.5,2147049.5 1327396.125,2147091.75 1327394,2147144.75 1327390.75,2147174.25 1327388.25,2147203.75 1327385.75,2147233.25 1327383.125,2147262.75 1327380.5,2147292.25 1327377.75,2147321.5 1327375,2147351 1327372.125,2147380.5 1327369.25,2147410 1327366.375,2147439.5 1327363.375,2147468.75 1327360.25,2147892.25 1327315.625,2147941 1327308.875,2147989.5 1327300.375,2148037.75 1327290.125,2148085.5 1327278.25,2148132.75 1327264.75,2148179.75 1327249.625,2148226 1327232.75,2148271.75 1327214.375,2148316.75 1327194.5,2148361 1327173,2148404.5 1327150,2148447.25 1327125.5,2148489 1327099.5,2148530 1327072,2148570 1327043.25,2148608.75 1327013,2148646.75 1326981.5,2148683.25 1326948.625,2148719 1326914.625,2148753.25 1326879.25,2148786.25 1326842.75,2148837.75 1326784.125,2149263 1326294.5,2149334 1326216.375,2149361 1326186.875,2149381.75 1326165,2149409.75 1326136.125,2149430.75 1326114.875,2149459.5 1326086.625,2149488.5 1326058.875,2149517.75 1326031.625,2149547.5 1326004.625,2149570 1325984.75,2149600.5 1325958.5,2149631.25 1325932.75,2149654.5 1325913.625,2149685.75 1325888.625,2149717.5 1325864.125,2149749.5 1325839.875,2149782 1325816.25,2149814.75 1325793,2149839.25 1325775.875,2149872.5 1325753.375,2149906.25 1325731.375,2149940 1325709.875,2149965.75 1325694,2150000 1325673.375,2150558.5 1325336.5,2150582.75 1325322.5,2150615.25 1325304.5,2150640.25 1325291.625,2150665.25 1325279.25,2150690.5 1325267.375,2150724.75 1325252.375,2150750.75 1325241.75,2150776.75 1325231.75,2150807.5 1325220.75,2150834 1325211.875,2150865.25 1325202.25,2150896.5 1325193.375,2150928.25 1325185.375,2151052.5 1325157.25,2151080.75 1325151,2151118.75 1325143.125,2151147.25 1325137.375,2151392 1325090.875,2151586.5 1325053.625,2151629.25 1325045.125,2151656 1325039.375,2151693.25 1325031.125,2151720 1325024.875,2151754.75 1325016.25,2151781.75 1325009.25,2151814.25 1325000,2151842 1324991.625,2151872 1324981.875,2151899.25 1324972.375,2151929.25 1324961.5,2151958.75 1324950,2151988.25 1324937.75,2152028.75 1324920.25,2152052.75 1324909.375,2152084.75 1324894.375,2152116.75 1324879,2152156 1324859,2152191.25 1324840.375,2152229.75 1324819.125,2152264.25 1324799.25,2152294.5 1324781.125,2152317.25 1324767.25,2152493.5 1324655.375,2152812.5 1324452.625,2152838 1324436.5,2152863.5 1324420.375,2152889.25 1324404.25,2152914.75 1324388.25,2152940.5 1324372.375,2152966 1324356.5,2152991.75 1324340.625,2153017.5 1324324.875,2153043.25 1324309.125,2153069 1324293.375,2153095 1324277.875,2153118.5 1324264,2153140.25 1324251.25,2153285.25 1324160.125,2153426.25 1324068.25,2153575.25 1323962.75,2153716.75 1323856.5,2153877 1323729.875,2153908 1323705.5,2154073 1323575.75,2154162.25 1323507.875,2154195.25 1323482.125,2154227.5 1323456,2154259.75 1323429.25,2154291.25 1323402.125,2154322.25 1323374.5,2154378 1323324,2154395.75 1323306.125,2154413 1323288.125,2154430.25 1323269.875,2154447.25 1323251.5,2154464 1323232.75,2154480.5 1323213.75,2154496.5 1323194.625,2154512.5 1323175.25,2154528.25 1323155.625,2154543.5 1323135.875,2154558.5 1323115.75,2154573.5 1323095.625,2155000 1322492,2155248 1322141.125,2155269 1322112.125,2155288.25 1322087.125,2155305 1322066.25,2155325.25 1322042.125,2155346.25 1322018.625,2155367.5 1321995.625,2155389.5 1321973.25,2155408.75 1321954.375,2155431.75 1321932.875,2155455.25 1321912,2155479.25 1321891.75,2155503.5 1321872,2155525 1321855.5,2155550.25 1321837,2155572.25 1321821.5,2155598.5 1321804.125,2155621.25 1321789.625,2155644.25 1321775.75,2155667.5 1321762.25,2156302 1321416.125,2157145.5 1320956.25,2157236.5 1320906.625,2157728.25 1320638.5,2157770.75 1320614.375,2157812.25 1320588.875,2157852.75 1320561.875,2157892.5 1320533.625,2157931.25 1320503.875,2157968.75 1320472.875,2158005.5 1320440.625,2158040.75 1320407.125,2158075 1320372.375,2158108 1320336.5,2158139.75 1320299.5,2158170.25 1320261.5,2158199.25 1320222.375,2158227.25 1320182.25,2158253.5 1320141.25,2158278.5 1320099.375,2158302 1320056.625,2158317 1320027.125,2158330 1320000,2158344.25 1319969.375,2158357.75 1319938.5,2158368.5 1319912.5,2158380.75 1319881,2158392.25 1319849.375,2158404 1319814.625,2158674.5 1318976.125,2158690 1318929.125,2158702.5 1318891.625,2158715.5 1318854.25,2158725.25 1318826.125,2158738.75 1318788.875,2158749 1318761,2158762.75 1318724,2158773.5 1318696.25,2158787.75 1318659.25,2158806 1318613.25,2158824.75 1318567.5,2158844 1318521.875,2158855.75 1318494.5,2158871.5 1318458.25,2158883.5 1318431.125,2158895.75 1318404,2158912.25 1318368,2158928.75 1318332.125,2158941.5 1318305.25,2158954.5 1318278.5,2158971.75 1318243,2158989.5 1318207.5,2159007.5 1318172.125,2159021 1318145.75,2159167 1317864.25,2159429.5 1317358.125,2159720.2428 1316810.3385,2159722.0187 1316811.38,2160054.6493 1316180.6139,2160054.5041 1316180.5663,2160038.6236 1316175.3533,2160023.0174 1316173.3269,2159996.5174 1316166.3269,2159979.9519 1316160.7363,2159971.5703 1316159.6063,2159936.0703 1316149.8563,2159905.9712 1316139.5342,2159893.2707 1316137.7127,2159858.2707 1316127.4627,2159837.9093 1316120.2877,2159830.6264 1316119.2026,2159806.294 1316111.787,2159804.3764 1316111.2026,2159781.2719 1316102.9188,2159774.2842 1316101.835,2159739.2842 1316090.71,2159697.1744 1316075.3278,2159687.8783 1316073.7882,2159653.3783 1316062.0382,2159643.979 1316056.1868,2159629.1599 1316053.6585,2159594.6599 1316041.5335,2159582.3502 1316033.787,2159563.9706 1316030.5344,2159537.9706 1316021.0344,2159529.5454 1316015.6596,2159515.6243 1316011.444,2159506.9435 1316008.3403,2159501.1571 1316007.2718,2159497.6624 1316005.9356,2159463.8733 1315995.4658,2159450.122 1315990.4992,2159446.0143 1315989.8625,2159403.5143 1315976.3625,2159378.5785 1315967.2565,2159372.3585 1315966.2528,2159330.1085 1315952.2528,2159319.5639 1315945.7488,2159302.2894 1315942.8626,2159274.2894 1315933.2376,2159267.8361 1315929.2074,2159257.7337 1315927.4851,2159215.7337 1315912.7351,2159205.2385 1315906.1322,2159189.4844 1315903.3606,2159147.4844 1315888.1106,2159133.2676 1315879.0612,2159113.1719 1315875.3821,2159064.6719 1315857.0071,2159055.8073 1315851.2777,2159043.9443 1315849.0542,2159006.9443 1315834.6792,2158998.1494 1315828.9424,2158986.8456 1315826.7758,2158962.3456 1315817.0258,2158953.6202 1315811.2834,2158942.8366 1315809.1719,2158918.5866 1315799.2969,2158912.8326 1315795.4771,2158905.9409 1315794.1092,2158881.4409 1315783.9842,2158874.1826 1315779.1386,2158866.8243 1315777.6931,2158862.5793 1315775.9584,2158861.9183 1315775.8244,2158852.2101 1315771.7209,2158840.8243 1315767.0681,2158840.1646 1315766.6295,2158837.6683 1315765.5744,2158835.0004 1315763.7778,2158830.782 1315762.9401,2158804.782 1315752.1901,2158800.9407 1315749.6252,2158796.4361 1315748.7227,2158770.6861 1315737.9727,2158766.0169 1315734.8434,2158760.6412 1315733.7548,2158734.8912 1315722.8798,2158734.1709 1315722.395,2158733.3504 1315722.2285,2158707.3504 1315711.2285,2158694.5065 1315702.5763,2158680.3278 1315699.618,2158654.8278 1315688.493,2158654.2225 1315688.0803,2158653.5705 1315687.9441,2158602.0705 1315665.4441,2158594.2879 1315660.1351,2158586.0679 1315658.3894,2158547.5679 1315641.2644,2158541.4544 1315637.0644,2158535.1755 1315635.714,2158509.6755 1315624.214,2158499.8929 1315617.456,2158490.1773 1315615.3253,2158469.5338 1315605.8131,2158448.8994 1315596.4062,2158434.4132 1315586.3554,2158420.4654 1315583.2393,2158399.7334 1315573.4891,2158378.7594 1315563.7218,2158369.1023 1315556.9636,2158360.0585 1315554.9238,2158334.8085 1315542.9238,2158329.7857 1315539.3794,2158325.207 1315538.337,2158274.707 1315514.087,2158264.5958 1315506.9212,2158255.6705 1315504.8516,2158205.1705 1315480.1016,2158194.9914 1315472.8263,2158186.3561 1315470.7878,2158161.3561 1315458.2878,2158157.9208 1315455.8118,2158155.0719 1315455.1352,2158117.5719 1315436.2602,2158115.8525 1315435.0175,2158114.4393 1315434.6809,2158089.4393 1315422.0559,2158086.114 1315419.649,2158070.7756 1315412.5376,2158020.7756 1315386.7876,2158017.6959 1315384.5398,2158005.1081 1315378.6524,2157967.8581 1315359.1524,2157965.1797 1315357.1838,2157955.2167 1315352.4911,2157932.9085 1315340.6588,2157918.2167 1315332.8661,2157916.2065 1315331.3802,2157909.2379 1315328.0815,2157884.4879 1315314.8315,2157882.3644 1315313.2556,2157875.3804 1315309.9328,2157850.6304 1315296.5578,2157845.9767 1315293.0899,2157831.6734 1315286.213,2157782.6734 1315259.213,2157779.5118 1315256.8368,2157770.6596 1315252.5523,2157733.9096 1315232.0523,2157732.276 1315230.8178,2157727.9416 1315228.7131,2157703.4416 1315214.9631,2157699.8661 1315212.2539,2157690.775 1315207.8083,2157654.275 1315187.0583,2157649.7596 1315183.6174,2157639.0526 1315178.3374,2157614.8026 1315164.3374,2157614.0388 1315163.7514,2157612.3227 1315162.904,2157575.8227 1315141.779,2157567.7055 1315135.5436,2157550.4277 1315126.8915,2157514.4277 1315105.5165,2157513.6887 1315104.9423,2157512.2378 1315104.2149,2157087.4878 1314851.4649,2157087.212 1314851.2503,2157086.6747 1314850.9808,2156340.9247 1314406.8558,2156339.9303 1314406.0821,2156338.0085 1314405.1165,2156287.2685 1314374.8103,2156282.7585 1314372.1165,2156275.587 1314366.5288,2156262.3709 1314359.8143,2156225.8709 1314337.5643,2156223.8083 1314335.9422,2156220.2554 1314334.1315,2156183.7554 1314311.7565,2156180.2656 1314309.0049,2156174.4532 1314306.0276,2156119.7032 1314272.1526,2156113.2362 1314267.0319,2156103.079 1314261.7814,2156048.829 1314227.6564,2156045.321 1314224.8574,2156040.1342 1314222.1634,2156003.8842 1314199.1634,2155996.3998 1314193.1678,2155985.9829 1314187.704,2155931.9829 1314152.829,2155926.7985 1314148.6415,2155920.0656 1314145.0869,2155866.3156 1314109.9619,2155859.3408 1314104.2972,2155850.8392 1314099.7705,2155819.1579 1314078.7483,2155797.3392 1314064.2705,2155790.9662 1314059.0574,2155783.7032 1314055.1612,2155748.2032 1314031.2862,2155745.6712 1314029.2019,2155742.9049 1314027.7136,2155689.6549 1313991.7136,2155680.9486 1313984.5289,2155671.9593 1313979.6455,2155636.7093 1313955.3955,2155635.8439 1313954.6755,2155634.9859 1313954.2089,2154096.157 1312893.784,2153654.8421 1312589.6689,2153502.1773 1312484.4658,2153051.6187 1312174.0976,2153051.446 1312173.9539,2153051.2752 1312173.861,2152824.5475 1312017.6263,2152824.5252 1312017.611,2152453.4238 1311761.9018,2152220.2313 1311601.2194,2152171.3197 1311567.5166,2152163.0952 1311560.668,2152155.3094 1311556.3973,2152114.0594 1311527.5223,2152110.5995 1311524.6195,2152107.4827 1311522.9036,2152074.4827 1311499.6536,2152064.3929 1311491.1623,2152055.8882 1311486.4324,2152023.1382 1311462.9324,2152012.6635 1311454.0395,2152004.6062 1311449.5126,2151972.1062 1311425.7626,2151965.6883 1311420.2659,2151957.7277 1311413.4478,2151949.2406 1311408.6154,2151947.8512 1311407.8243,2151943.0384 1311404.2222,2151907.6012 1311377.6993,2151904.7392 1311375.2195,2151902.8841 1311374.1606,2151870.6341 1311349.9106,2151859.2304 1311340.0077,2151852.6287 1311336.201,2151852.3663 1311336.0497,2151828.3663 1311317.6747,2151816.5885 1311307.357,2151810.1777 1311303.623,2151778.4277 1311278.873,2151775.0784 1311275.913,2151773.3434 1311274.8997,2151741.5934 1311250.0247,2151724.4521 1311234.8387,2151716.5527 1311230.1604,2151693.0527 1311211.2854,2151690.9989 1311209.4435,2151690.1 1311208.9103,2151658.6 1311183.5353,2151640.6379 1311167.4038,2151633.7224 1311163.2444,2151594.9724 1311131.2444,2151586.3485 1311123.404,2151583.3433 1311121.5848,2151544.5933 1311089.2098,2151537.5365 1311082.7572,2151525.4717 1311071.7255,2151519.8376 1311068.2674,2151489.3376 1311042.1424,2151486.323 1311037.9869,2151479.9154 1311034.0332,2151449.4154 1311007.6582,2151443.7209 1310999.7696,2151432.1914 1310992.5856,2151432.0078 1310992.4712,2151401.7578 1310965.8462,2151400.2261 1310963.7047,2151397.1576 1310961.7879,2151366.9076 1310935.0379,2151361.6224 1310927.6301,2151357.5581 1310921.9336,2151350.7217 1310917.5965),(2148933.7523 1312131.37,2148935.001 1312435.78,2148935.8357 1312638.72,2148936.6815 1312844.86,2148937.481 1313039.71,2148938.3292 1313245.52,2148939.4129 1313509.5367,2148632.351 1313509.1986,2148572.311 1313509.14,2148474.7901 1312038.5201,2148433.9565 1311422.7496,2148424.1069 1311274.2195,2148556.809 1311274.2195,2148582.7118 1311110.1683,2148625.8832 1310928.8486,2148617.7693 1310612.408,2148628.6406 1310610.0168,2148639.7475 1310607.657,2148650.871 1310605.3767,2148662.0105 1310603.176,2148673.1654 1310601.055,2148684.3353 1310599.0139,2148695.5194 1310597.0528,2148706.7173 1310595.1717,2148715.2298 1310593.7993,2148728.0899 1310893.52,2148928.641 1310885.37,2148929.1239 1311002.9901,2148929.1239 1311003.0037,2148929 1311003,2148930.75 1311425.125,2148930.857 1311425.1258,2148933.381 1312039.69,2148933.7523 1312131.37),(2154894.7125 1316488.9352,2154874.31 1316514.7,2154765.625 1316514.6558,2153167.7036 1316514.0055,2153151.1151 1316513.9988,2153042.4369 1315829.3262,2153710.1861 1314077.8529,2154191.8176 1313514.2415,2154209 1313514.25,2154208.9844 1313514.2723,2154238.5219 1313514.2904,2155435.9404 1315898.6237,2155426.8867 1315905.6557,2155415.2431 1315914.8077,2155403.6527 1315924.0271,2155395.9555 1315930.2105,2155384.4545 1315939.5412,2155373.0002 1315948.9303,2155322.8379 1315990.3682,2155315.0201 1315996.8969,2155308.5605 1316002.4029,2155302.1516 1316007.9679,2155295.7942 1316013.5916,2155289.4885 1316019.2733,2155284.4818 1316023.8602,2155278.2708 1316029.6453,2155272.1133 1316035.4872,2155266.0096 1316041.3853,2155259.9603 1316047.3391,2155253.9658 1316053.3483,2155248.0268 1316059.4122,2155243.3158 1316064.3024,2155237.4777 1316070.4635,2155231.6965 1316076.678,2155225.9725 1316082.9453,2155221.4348 1316087.9967,2155213.5836 1316096.9164,2155199.3539 1316113.3809,2155173.2044 1316143.8186,2155147.1693 1316174.3543,2155121.249 1316204.9874,2155108.332 1316220.3403,2155082.5846 1316251.1188,2155000 1316350.3282,2154943.0519 1316418.3796,2154911.83 1316458.94,2154911.7999 1316467.1184,2154894.7125 1316488.9352)),((2161956.88285496 1311192.63745687,2162083.21755932 1311234.3406913,2161969.6908 1311172.3106,2161968.3133 1311180.3784,2161961.69 1311176.26,2161956.88285496 1311192.63745687)),((2162310.90505432 1311335.40437426,2162353.4428 1311363.8272,2162371.7473 1311312.7675,2162378.263 1311296.4783,2162387.0215 1311274.582,2162408.0464 1311219.2217,2162429.0255 1311161.9348,2162480.576 1311030.1947,2162481.079 1311029.9296,2162487 1311014.25,2162497.5 1310987,2162517.75 1310933.375,2162567.75 1310793.75,2162622.75 1310653.375,2162634 1310624.375,2162671.25 1310527.25,2162725.5 1310382.375,2162772.5 1310264.125,2162804.5 1310175.5,2162819.25 1310133,2162850.75 1310040.25,2162863.25 1310000,2162871.5 1309972,2162881.25 1309937,2162888.75 1309908.875,2162896.25 1309880.75,2162943.25 1309690.875,2162953.75 1309647.875,2162961.75 1309613.375,2162967.5 1309587.5,2162974 1309557.5,2162982.25 1309518.375,2162990.75 1309475,2162995.75 1309449,2163002.25 1309414.125,2163006.75 1309388,2163011 1309361.875,2163015.25 1309335.75,2163064.25 1309028.375,2163070.75 1308991.5,2163075.75 1308966.125,2163095.5 1308878.125,2163106.5 1308833.25,2163119.25 1308788.75,2163133.25 1308744.625,2163148.75 1308701.125,2163166 1308658.125,2163184.5 1308615.75,2163204.5 1308574.125,2163226 1308533.125,2163249 1308493,2163273.25 1308453.625,2163298.75 1308415.125,2163325.75 1308377.5,2163354 1308340.875,2163398.5 1308287.75,2163428.5 1308255.125,2163446.5 1308236.5,2163987.75 1307686.5,2164020.75 1307652.625,2164054 1307618.875,2164087 1307585,2164113.25 1307557.875,2164153 1307517,2164185.75 1307482.875,2164218.75 1307448.75,2164251.5 1307414.625,2164284 1307380.375,2164316.75 1307346.125,2164349.25 1307311.75,2164370.75 1307288.625,2164388.75 1307267.875,2164493.5 1307144.25,2164606.5 1307010.625,2164628.75 1306984.875,2164654 1306956.5,2164674.5 1306934.25,2164698 1306909.5,2164724.5 1306882.5,2164743.25 1306863.875,2164768 1306840.375,2164793 1306817.125,2164815.5 1306796.875,2164840 1306775.75,2164872 1306750.5,2164892.5 1306734.5,2164926.5 1306707.375,2164946.75 1306690.875,2164966.75 1306674.25,2164986.75 1306657.5,2165009.75 1306638,2165033.75 1306617.125,2165154 1306510.625,2165175.75 1306490.25,2165310.4489 1306357.7521,2165286.252 1306339.3693,2165286.8 1306338.83,2165258.57 1306316.78,2165000 1306114.76,2164798.1012 1305957.0185,2164703.5627 1305883.1565,2164430.2722 1305669.6375,2163573.25 1305000,2163536.4426 1304971.2949,2163533.48 1304968.98,2163532.3818 1304970.522,2163529 1304975.125,2163518.5 1304982.625,2163518.5017 1304982.6545,2163518.4704 1304982.6768,2163504.24 1304992.78,2163497.39 1305000,2163489.01 1305008.83,2163465.9198 1305030.97,2163465.84 1305000,2163465.206 1304753.41,2163463.8475 1304225.9519,2163463.75 1304226,2163435 1304247.875,2163417.5 1304269.75,2163401 1304273.875,2163034.75 1304552.875,2163032.5 1304554.625,2162890.75 1304947.25,2162912.75 1305000,2162969.5 1305135.875,2162970 1305137.25,2162736.75 1305425.125,2162706.75 1305395.25,2162865.5 1305153.375,2162864 1305000,2162863.75 1304963.625,2162761.75 1304877.25,2162754.75 1304852,2162734.75 1304827.125,2162723.25 1304808.5,2162720.25 1304799,2162715.75 1304790,2162709.25 1304781.375,2162700.25 1304775,2162653.25 1304748.875,2162642.5 1304747.375,2162633.5 1304741.5,2162623.5 1304737.75,2162604.25 1304726.5,2162596 1304719.75,2162590 1304711.375,2162579.25 1304708,2162569.25 1304702.75,2162560.25 1304696.125,2162543 1304685.25,2162535.5 1304677.375,2162521.75 1304660.125,2162514.75 1304651.5,2162506.75 1304645,2162501 1304635.125,2162496.75 1304625.5,2162477.75 1304576.75,2162449.5 1304531,2162426 1304494.125,2162406.5 1304468,2162402.5 1304457.875,2162396.5 1304448.75,2162389 1304441.625,2162377.25 1304423.875,2162364.75 1304392.5,2162364.25 1304382.375,2162363 1304377.375,2162361.5 1304367.875,2162358.5 1304357.5,2162353.75 1304346.375,2162193.75 1304348,2162170.25 1304247.25,2161676.75 1304255.375,2161639 1304376,2160758.25 1304382.25,2160763.25 1304270.375,2160827.25 1301690.5,2160834 1300925,2160977.5 1300948,2161052 1300960,2161130.25 1300972.5,2161251.5 1300991.875,2161285.75 1300997.375,2161451 1301023.875,2161454.75 1300752.875,2161327.5 1300722.25,2161307.75 1300717.625,2161290.75 1300713.625,2161258.5 1300706.125,2161238.75 1300701.75,2161219 1300697.375,2161199.25 1300693.125,2161179.5 1300688.875,2161159.75 1300684.625,2161138.25 1300680.25,2160987 1300649.5,2160909 1300633.75,2160892.75 1300630.5,2160880.75 1300628.125,2160864.5 1300625.125,2160852.5 1300623,2160836.75 1300620.25,2160836.9691 1300594.9588,2160836.5 1300594.875,2160807.5 1300590.375,2160778.75 1300586.125,2160741.75 1300581.375,2160701.0801 1300576.815,2160695.1301 1300576.3326,2160686.943 1300575.4929,2160678.1262 1300574.6532,2160668.2597 1300573.6036,2160659.8627 1300572.9738,2160650.2062 1300572.1341,2160641.1794 1300571.5043,2160632.5725 1300570.8746,2160623.9655 1300570.2448,2160615.1487 1300569.615,2160605.912 1300569.1952,2160596.8852 1300568.7753,2160585.7592 1300568.1455,2160578.4118 1300567.9356,2160570.2247 1300567.5158,2160566.0902 1300567.2652,2160566.0912 1300567.0903,2160330.75 1300556.125,2160203.8756 1300550.1313,2160194.5127 1300549.9278,2160177.4374 1300548.8823,2160049.2409 1300542.8262,2160011.4425 1300541.4665,2160000 1300540.7037,2159989.483 1300540.0026,2159907.5 1300536.125,2159877.3217 1300534.301,2159855.2944 1300533.0053,2159837.5808 1300531.6634,2159835.25 1300531.5,2159833.8656 1300531.3819,2159804.5271 1300529.1593,2159766.8361 1300525.3133,2159766.5745 1300525.2821,2159766.25 1300525.25,2159723.75 1300520.625,2159706.9233 1300518.5613,2159705.2999 1300518.3905,2159679.9162 1300515.3137,2159673.5769 1300514.2994,2159665.5 1300513.25,2159628.5 1300507.875,2159602.25 1300503.75,2159536.75 1300492.375,2159315 1300447.875,2159283.75 1300441.375,2159253 1300434.5,2159211.75 1300424.625,2158782.5 1300318.75,2158654 1300287.125,2158618.25 1300278.5,2158582.5 1300270.25,2158546.5 1300262.25,2158510.5 1300254.75,2158467.25 1300246.125,2158428.25 1300238.875,2158402.25 1300234.25,2158358.75 1300227,2158326 1300221.625,2158291.75 1300216.625,2158253.75 1300211.625,2158215.5 1300207.375,2158189 1300204.875,2158154.5 1300202.125,2158099.5 1300198.5,2158065.5 1300197.25,2158040.25 1300197.25,2158009.25 1300198.25,2157983.75 1300200.125,2157953 1300203.5,2157922.25 1300208.125,2157897.25 1300212.75,2157869.75 1300218.875,2157844.25 1300225.5,2157755 1300252.625,2157725.5 1300262,2157684.75 1300276.125,2157650.25 1300288.875,2157615.75 1300302.5,2157581.75 1300316.75,2157553.5 1300329.25,2157520.25 1300344.875,2157487 1300361.25,2157454.25 1300378.375,2157427.25 1300393.125,2157184.25 1300531.375,2157101.5 1300580.5,2156919.25 1300689,2156764.75 1300781.125,2156743 1300793.625,2156718 1300807,2156690 1300820.75,2156661.5 1300833.625,2156635.25 1300844.375,2156584 1300862.5,2156576 1300886.375,2156546 1300873.75,2156515.75 1300881.375,2156213.5 1300946.125,2156187.5 1300951,2156159.25 1300955,2156130.75 1300957.625,2156100 1300959,2156032.25 1300958.5,2156007 1300957.375,2155981 1300955.125,2155814.25 1300931.75,2155789 1300927.875,2155383.5 1300854.75,2155355.25 1300849.5,2155312.75 1300841.25,2155284.75 1300835.5,2155249.5 1300828,2155214.5 1300820.125,2155172.5 1300810.25,2155130.5 1300799.875,2155095.75 1300790.875,2155060.25 1300778.25,2155030.5 1300765.75,2155000 1300752.25,2154972.25 1300739.25,2154942.25 1300724.375,2154915.25 1300710.125,2154886 1300694,2154859.5 1300678.75,2154509 1300467,2154279.25 1300322.625,2154252.75 1300304.875,2154231 1300288.625,2154209.75 1300271.625,2154191 1300255.125,2154166.75 1300231.5,2154149.5 1300213.5,2154128.75 1300189.5,2153978 1300000,2153827.25 1299810.5,2153809.5 1299789.5,2153747.75 1299728,2153729.5 1299710.75,2153710.25 1299694.5,2153690.25 1299679.375,2153669.5 1299665.125,2153648 1299652.125,2153626 1299640.125,2153603.25 1299629.25,2153580.25 1299619.625,2153556.5 1299611.125,2153532.5 1299603.875,2153508 1299597.875,2153483.25 1299593.125,2153458.5 1299589.75,2153204 1299565.25,2153175.25 1299562,2153146.5 1299558,2153118 1299553.25,2153089.75 1299547.625,2153057.75 1299540.375,2153026.25 1299532,2152998.5 1299523.875,2152967.75 1299513.625,2152937 1299502.5,2152729 1299423,2152705 1299413.5,2152680.75 1299403.625,2152640.25 1299386.75,2151913.75 1299081.5,2151871.5 1299063.625,2151834 1299047.625,2151359.75 1298844.125,2151322.5 1298828.5,2150998.5 1298698.75,2150970.75 1298688.5,2150944.25 1298680.25,2150919.25 1298673.875,2150894 1298668.5,2150868.75 1298664.375,2150843 1298661.375,2150816.5 1298659.5,2150789 1298659.75,2150761.5 1298662,2150734.25 1298666,2150707.25 1298671.875,2150681 1298679.75,2150655 1298689.25,2150630 1298700.625,2150605.75 1298713.75,2150582.5 1298728.5,2150556 1298738.125,2150539.25 1298762.625,2150517.75 1298783.625,2150495.5 1298806.625,2150476.25 1298827.375,2150456.25 1298850.125,2150254.75 1299094.625,2150232 1299121.875,2150203.75 1299154.125,2150180 1299180.5,2150155.5 1299206.5,2150135.75 1299226.875,2150105.5 1299257.125,2150084.75 1299276.875,2150058.75 1299301.125,2150037.75 1299320.25,2150010.75 1299343.75,2149987.5 1299363.375,2149966.5 1299380.625,2149691.75 1299600.125,2149666.75 1299619.625,2149641.25 1299638.375,2149615.5 1299656.625,2149589.25 1299674.125,2149562.5 1299691.125,2149535.5 1299707.375,2149512 1299720.75,2149438.5 1299760.75,2149401.75 1299780.125,2149360.25 1299801.375,2149337 1299812.75,2149314.5 1299823.5,2149054.25 1299944.75,2149009.75 1299965.25,2148965 1299985.25,2148931.5 1300000,2148886.25 1300019.25,2148859 1300030.625,2148822.5 1300045.5,2148777 1300063.75,2148731.25 1300081.5,2148694.25 1300095.375,2148666.75 1300105.5,2148639 1300115.5,2148602 1300128.625,2148555.5 1300144.625,2148527.5 1300154,2148480.75 1300169.25,2148204.5 1300256.625,2148173.5 1300266,2148144.5 1300273.875,2148112.75 1300281.75,2148083.5 1300288.375,2147714 1300366.875,2147679.5 1300373.875,2147645 1300380.5,2147619 1300385.125,2147584.25 1300390.75,2147549.5 1300395.875,2147514.5 1300400.625,2147488.5 1300403.75,2147462.25 1300406.625,2147436 1300409.25,2147401 1300412.25,2147365.75 1300414.875,2147330.75 1300416.875,2147295.5 1300418.375,2147260.5 1300419.375,2147234 1300419.75,2147207.5 1300419.875,2147172.5 1300419.625,2147137.25 1300418.75,2146734 1300406.875,2146702.5 1300405.375,2146667.5 1300402.5,2146631 1300398.25,2146596.25 1300392.875,2146535.75 1300382.25,2146509.75 1300377.125,2146481.75 1300370.375,2146451.5 1300361.75,2146426.5 1300353.375,2146401.75 1300344.125,2146377.25 1300333.875,2146351.25 1300321.625,2146325.5 1300308.375,2145791.75 1300000,2145763.75 1299983.875,2145742.25 1299970.375,2145718 1299955.875,2145692.75 1299942.875,2145667 1299931.125,2145640.75 1299920.625,2145613.75 1299911.625,2145586.5 1299904,2145559 1299897.875,2145531 1299893.125,2145503 1299889.875,2145474.75 1299888.125,2145446.25 1299887.75,2145418 1299889,2145389.75 1299891.625,2145207.25 1299916.75,2145000 1299951.375,2144927.25 1299963.125,2144733 1299993.125,2144693.25 1300000,2144576.5 1300020,2144541 1300026.5,2144499.75 1300035,2144470.5 1300041.75,2144435.5 1300050.5,2144407.9931 1300058.0199,2144519.9618 1300067.0584,2145010.7118 1300146.8084,2145021.4419 1300149.8579,2145036.7164 1300151.1677,2145084.4664 1300159.4177,2145100.1361 1300163.9557,2145119.8723 1300165.7837,2145167.3723 1300174.6587,2145183.7819 1300179.5324,2145201.7369 1300181.3155,2145243.4869 1300189.6905,2145261.507 1300195.1728,2145278.6481 1300196.9929,2145314.1481 1300204.6179,2145330.8856 1300209.8346,2145344.8297 1300211.3993,2145386.0797 1300220.7743,2145403.1004 1300226.1906,2145415.6332 1300227.6698,2145456.8832 1300237.5448,2145481.6049 1300245.5685,2145497.2105 1300247.5351,2145538.2105 1300258.0351,2145547.8498 1300261.2477,2145553.3293 1300261.9547,2145588.5793 1300271.2047,2145620.2958 1300281.8796,2145635.5251 1300283.9873,2145676.2751 1300295.4873,2145691.5042 1300300.7697,2145697.8529 1300301.6759,2145738.6029 1300313.5509,2145766.2129 1300323.2595,2145775.8771 1300324.7117,2145819.3771 1300338.0867,2145848.3758 1300348.5243,2145856.5321 1300349.8116,2145899.7821 1300363.8116,2145924.6541 1300372.9717,2145930.3127 1300373.9001,2145962.5627 1300384.7751,2145971.1213 1300390.0853,2145974.3891 1300391.2888,2145988.5425 1300393.6865,2146031.5425 1300408.6865,2146044.2501 1300416.6627,2146063.4234 1300420.0375,2146095.4234 1300431.6625,2146105.9586 1300438.3696,2146120.9659 1300441.091,2146152.9659 1300453.091,2146165.0911 1300460.8985,2146181.4608 1300463.9647,2146223.9608 1300480.4647,2146239.4208 1300490.5465,2146259.0089 1300494.3604,2146290.5089 1300507.1104,2146301.8455 1300514.6191,2146315.3846 1300517.3269,2146357.3846 1300534.8269,2146371.3816 1300544.2006,2146387.2005 1300547.4654,2146428.9505 1300565.4654,2146445.539 1300576.7226,2146463.1041 1300580.4774,2146494.3541 1300594.4774,2146506.9217 1300603.1362,2146519.4701 1300605.8872,2146560.7201 1300624.8872,2146580.014 1300638.3296,2146598.0308 1300642.4272,2146628.7808 1300657.1772,2146640.1438 1300665.2265,2146650.1642 1300667.5529,2146690.9142 1300687.5529,2146705.1735 1300697.7507,2146712.9442 1300701.3785,2146723.8016 1300703.9791,2146754.3016 1300719.4791,2146758.9677 1300722.8655,2146779.4243 1300732.416,2146819.6743 1300753.416,2146827.03 1300758.8146,2146854.0168 1300771.6569,2146894.0168 1300793.2819,2146901.0897 1300798.5535,2146922.4446 1300808.877,2146962.1946 1300831.002,2146969.3909 1300836.4347,2146988.0568 1300845.5881,2147017.8068 1300862.5881,2147029.1875 1300871.2806,2147054.4768 1300883.9351,2147093.4768 1300907.0601,2147100.8287 1300912.7696,2147114.8353 1300919.8611,2147153.8353 1300943.4861,2147161.1605 1300949.2304,2147173.7897 1300955.6951,2147726.6825 1301297.3538,2147753.9162 1301313.8543,2147781.0737 1301330.1329,2147787.364 1301333.8266,2147841.947 1301365.5609,2147848.0999 1301369.1024,2147875.5841 1301384.5921,2147886.9041 1301390.9026,2147917.4381 1301407.749,2147945.3888 1301422.9222,2147954.3168 1301427.6905,2147987.9492 1301445.4622,2147996.809 1301450.0935,2148025.1735 1301464.6764,2148034.1882 1301469.2344,2148068.0757 1301486.1781,2148096.6042 1301500.2821,2148125.3915 1301514.1933,2148137.2071 1301519.8385,2148148.863 1301525.3427,2148177.7005 1301538.8002,2148206.9559 1301552.1348,2148218.9544 1301557.5407,2148253.3931 1301572.8678,2148265.0141 1301577.976,2148274.1699 1301581.9502,2148309.5075 1301597.0121,2148318.8817 1301600.986,2148365.225 1301620.1278,2148391.7991 1301630.8152,2148422.0311 1301642.7446,2148448.9713 1301653.1731,2148478.0485 1301664.1161,2148514.4112 1301677.6055,2148524.0436 1301681.1407,2148553.2285 1301691.5974,2148562.8277 1301694.9673,2148597.9731 1301707.1187,2148605.5933 1301709.7128,2148619.3837 1301714.2854,2148622.3662 1301716.1254,2148627.3347 1301716.9358,2148645.3619 1301722.9768,2149720.712 1302078.1109,2149720.7965 1302078.1388,2149892.2119 1302134.7359,2149896.595 1302137.4362,2149903.9186 1302138.6315,2149944.9186 1302152.3815,2149961.798 1302162.8349,2149988.562 1302167.4438,2150029.062 1302181.8188,2150044.8628 1302191.7964,2150067.9124 1302195.9518,2150108.1624 1302210.9518,2150118.765 1302217.7636,2150133.2724 1302220.4552,2150163.5224 1302232.0802,2150174.2178 1302239.0288,2150188.1479 1302241.6855,2150218.1479 1302253.5605,2150233.3703 1302263.5589,2150252.0655 1302267.2588,2150291.8155 1302283.6338,2150303.748 1302291.5901,2150317.5638 1302294.4004,2150347.3138 1302307.0254,2150363.2398 1302317.7665,2150380.602 1302321.4225,2150410.102 1302334.4225,2150424.7141 1302344.4242,2150439.6689 1302347.6692,2150478.9189 1302365.5442,2150494.5547 1302376.3882,2150509.5962 1302379.7529,2150548.3462 1302398.0029,2150565.5129 1302410.0721,2150573.0132 1302413.5425,2150587.7749 1302416.9734,2150616.7749 1302431.2234,2150621.1957 1302434.3865,2150624.9805 1302435.2731,2150653.9805 1302449.6481,2150659.2961 1302453.4655,2150686.5906 1302466.0946,2150715.3406 1302480.8446,2150721.7342 1302485.5035,2150747.8226 1302497.795,2150776.3226 1302512.92,2150781.9122 1302517.0527,2150800.7625 1302526.0554,2150829.0125 1302541.4304,2150834.4323 1302545.4817,2150850.3944 1302553.1958,2150888.1444 1302574.1958,2150898.0569 1302581.6772,2150923.4227 1302594.1771,2150951.1727 1302610.1771,2150955.5516 1302613.5352,2150965.2489 1302618.3511,2150993.2489 1302634.7261,2151006.9358 1302645.2893,2151033.8101 1302658.9367,2151061.3101 1302675.6867,2151066.8193 1302680.0177,2151076.1703 1302684.8053,2151103.6703 1302701.8053,2151113.0242 1302709.2089,2151127.5506 1302716.7443,2151154.8006 1302733.9943,2151164.7798 1302741.9799,2151178.634 1302749.2611,2151205.634 1302766.7611,2151215.1772 1302774.482,2151227.0955 1302780.8199,2151254.0955 1302798.6949,2151264.3705 1302807.0908,2151275.9667 1302813.3318,2151301.4667 1302830.5818,2151317.4612 1302843.7847,2151333.3123 1302852.4658,2151358.5623 1302870.0908,2151369.6794 1302879.4052,2151379.4254 1302884.8042,2151409.4254 1302906.1792,2151419.2455 1302914.488,2151427.0944 1302918.8784,2151452.0944 1302937.0034,2151472.4321 1302954.3557,2151486.5 1302962.375,2151511 1302980.75,2151515.1992 1302984.392,2151517.871 1302985.9208,2151542.371 1303004.4208,2151555.1977 1303015.5819,2151562.6829 1303019.9132,2151587.1829 1303038.7882,2151610.0429 1303058.8751,2151621.2578 1303065.4878,2151645.2578 1303084.6128,2151663.7847 1303101.1633,2151671.4043 1303105.7217,2151711.9043 1303138.8467,2151727.2156 1303152.701,2151732.6408 1303155.9842,2151756.8908 1303176.2342,2151782.5682 1303199.7071,2151789.7587 1303204.1393,2151813.5087 1303224.6393,2151815.4484 1303227.3239,2151819.5128 1303229.8376,2151843.2628 1303250.4626,2151852.6027 1303263.4298,2151871.3638 1303275.2179,2151894.8638 1303296.2179,2151906.1862 1303312.175,2151927.2847 1303325.6772,2151950.2847 1303346.9272,2151952.3184 1303349.8444,2151955.947 1303352.174,2151978.947 1303373.549,2151988.9745 1303387.9774,2152006.1016 1303399.1451,2152028.8516 1303420.8951,2152035.9727 1303431.2978,2152047.4844 1303438.8846,2152077.4844 1303468.1346,2152086.8776 1303482.0018,2152101.2619 1303491.6131,2152123.5119 1303513.8631,2152132.0285 1303526.6091,2152144.3676 1303534.9544,2152166.3676 1303557.4544,2152172.8994 1303567.3499,2152181.9513 1303573.5281,2152203.7013 1303596.1531,2152214.6948 1303612.9624,2152229.0911 1303622.9366,2152250.5911 1303645.9366,2152257.4059 1303656.5172,2152265.9047 1303662.4592,2152287.1547 1303685.5842,2152297.3726 1303701.5984,2152309.4524 1303710.1576,2152337.4524 1303741.4076,2152345.6217 1303754.3901,2152354.7984 1303760.9608,2152375.5484 1303784.5858,2152383.8197 1303797.8761,2152386.5234 1303800.8243,2152394.9562 1303806.9342,2152415.4562 1303830.8092,2152418.3714 1303835.5523,2152433.496 1303852.0447,2152460.496 1303884.1697,2152467.3612 1303895.4729,2152496.3725 1303927.7951,2152522.6225 1303960.4201,2152525.57 1303965.3922,2152535.4179 1303976.4501,2152554.9179 1304001.0751,2152559.4686 1304008.82,2152573.0882 1304024.286,2152592.3382 1304049.161,2152596.1793 1304055.7826,2152606.3682 1304067.4552,2152625.3682 1304092.4552,2152630.5974 1304101.561,2152643.0307 1304115.966,2152661.7807 1304141.216,2152666.5386 1304149.609,2152676.6344 1304161.4187,2152701.3844 1304195.4187,2152710.4796 1304211.642,2152727.294 1304231.6502,2152745.294 1304257.2752,2152751.7247 1304268.9761,2152762.0038 1304281.3464,2152779.7538 1304307.2214,2152784.7898 1304316.5062,2152792.0924 1304325.3692,2152815.5924 1304360.2442,2152827.3255 1304382.0927,2152842.0803 1304400.3359,2152864.8303 1304435.4609,2152870.4023 1304446.0671,2152876.5904 1304453.7831,2152899.0904 1304489.1581,2152909.6084 1304509.381,2152919.878 1304522.3828,2152941.878 1304558.1328,2152954.3887 1304582.6296,2152964.6697 1304595.8717,2152980.6697 1304622.8717,2152989.1298 1304639.7844,2152995.1819 1304647.6678,2153010.9319 1304674.9178,2153016.6057 1304686.4162,2153020.3083 1304691.275,2153041.0583 1304727.775,2153056.5276 1304759.4091,2153064.849 1304770.5414,2153084.849 1304807.2914,2153093.2632 1304824.9102,2153097.1535 1304830.1684,2153111.9035 1304857.9184,2153119.6672 1304874.3827,2153122.8304 1304878.6981,2153137.3304 1304906.5731,2153143.6675 1304920.1684,2153145.9794 1304923.3463,2153444.2304 1305506.8591,2153557.4625 1305728.1655,2153562.5613 1305737.9489,2153565.779 1305743.7331,2153568.8019 1305748.8514,2153571.8734 1305753.8651,2153573.3341 1305756.228,2153576.893 1305761.7556,2153580.0282 1305766.5244,2153586.0982 1305775.1438,2153587.7795 1305777.5089,2153589.7666 1305780.13,2153598.0791 1305790.8343,2153598.5525 1305791.4305,2153598.7462 1305791.6679,2153603.1625 1305796.9594,2153603.3348 1305797.1591,2153611.0515 1305805.9588,2153619.2136 1305814.7434,2153619.3143 1305814.8504,2153621.9406 1305817.5418,2153622.0832 1305817.6844,2153629.9195 1305825.3311,2153633.0531 1305828.3147,2154078.5966 1306244.9236,2154078.6009 1306244.9298,2154078.6084 1306244.9346,2154830.0019 1306947.5395,2154861.0333 1306976.1303,2154878.3476 1306991.8759,2154892.5447 1307004.4303,2154911.8216 1307021.3972,2154928.883 1307036.1511,2154942.3489 1307047.6854,2154962.856 1307064.8188,2154983.4005 1307081.7845,2155000.9245 1307095.9011,2155010.4871 1307103.5817,2155027.1169 1307116.6105,2155047.2586 1307132.3116,2155053.0299 1307136.7302,2155073.7593 1307152.3174,2155099.5725 1307171.6373,2155110.6569 1307179.7374,2155124.8431 1307189.9168,2155145.2325 1307204.282,2155175.206 1307225.2635,2155262.7574 1307285.5912,2155499.4316 1307448.6727,2155820.4303 1307669.8584,2155820.4527 1307669.877,2155820.4748 1307669.889,2156047.053 1307826.0207,2156073.712 1307844.3848,2156318.95109848 1308013.31821012,2156317.7327 1307899.23,2156314.28 1307576.2025,2157711.43 1307566.5,2158437.5 1307561.4587,2159162.74 1307556.4231,2159218.1106 1305859.375,2159246.15 1305000,2159250.5754 1304864.4008,2159696.0924 1304850.5649,2159803.2061 1304728.1492,2159806.5524 1304730.9463,2159814.9261 1304738.0874,2159824.8807 1304746.7656,2159836.36 1304757.03,2159912.0715 1304825.7209,2159917.1062 1304830.3456,2159922.0831 1304835.0323,2159927.0016 1304839.7803,2159932.82 1304845.55,2159986.0708 1304899.1896,2160000 1304913.73,2160013.0837 1304927.4019,2160016.9984 1304931.6245,2160019.4366 1304934.3597,2160050.56 1304969.98,2160078.17 1305000,2160192.369 1305124.1499,2160204.38 1305137.07,2160124.91 1305524.47,2160558.1345 1305737.9405,2160543.6167 1305859.375,2160534.23 1305937.89,2160681.89 1305936.93,2160484.64 1307547.25,2160596.7591 1307546.47,2160764.8731 1307040.9444,2160866.4126 1307042.1316,2161776.1976 1307052.7695,2162698.18 1307063.5499,2163176.0125 1307081.3825,2163449.3904 1307352.3195,2163309.1183 1307494.8884,2163168.8466 1307637.4567,2163028.58 1307780.02,2162986.7119 1307738.5295,2162980.6699 1307732.6658,2162975.3162 1307727.6048,2162971.4544 1307724.0302,2162966.7792 1307719.7854,2162962.0596 1307715.59,2162957.2962 1307711.4444,2162952.4896 1307707.349,2162947.6402 1307703.3043,2162942.7486 1307699.3108,2162938.6405 1307696.0222,2162932.008 1307690.8357,2162924.4605 1307685.1125,2162669.04 1307495.27,2162664.24 1307566.46,2162485.49 1307881.42,2162044.17 1307976.04,2161977.722 1308066.3009,2161806.51 1308298.87,2161738.8527 1308506.4709,2161663.0192 1308739.1597,2161606.27 1308913.29,2161610.9668 1308974.858,2161610.62 1308974.81,2161628.67 1309219.33,2161629.6201 1309219.3713,2161649 1309473.41,2161562.42 1309538.08,2161563.0106 1309843.75,2161563.22 1309952.1,2162027.8999 1309957.854,2162260.34 1309960.7323,2162441.93 1309962.9809,2162655.9953 1309965.6316,2162770.54 1309967.05,2162820.54 1309967.67,2162815.23 1309985.82,2162810.8538 1310000,2162765.4732 1310134.7523,2162732.0237 1310227.4986,2162424.9552 1311036.5644,2162413.2 1311068.14,2162310.90505432 1311335.40437426),(2157784.56 1304623.33,2156896.47 1304626.13,2156896.47 1304626.1251,2156896.5 1304626.125,2156901.6726 1304163.4375,2156913.82 1303083.1253,2157171.88 1303081.92,2157177.43 1302406.82,2156714.24 1302416.3311,2156708.98 1302246.27,2156619.63 1302055.26,2156579.2 1301882,2155960.5883 1301882.0294,2155962.665 1301875.8514,2155962.9607 1301875,2155965.2865 1301868.3039,2155967.9898 1301860.7852,2155969.8372 1301855.7892,2155971.7207 1301850.8067,2155974.6133 1301843.3589,2155976.5865 1301838.4112,2155979.6132 1301831.0168,2155982.72 1301823.6557,2156046.6163 1301674.5,2156882.32 1301677.2966,2157162.38 1301678.2337,2157369.42 1301678.9265,2157576.65 1301679.62,2157550.2001 1300358.3647,2157558.4529 1300354.5459,2157569.4979 1300349.5236,2157586.1326 1300342.1398,2157602.8462 1300334.9365,2157619.6368 1300327.9145,2157636.5024 1300321.0745,2157653.4411 1300314.4175,2157670.4508 1300307.9442,2157681.8291 1300303.731,2157693.2374 1300299.6001,2157710.4052 1300293.5583,2157721.8862 1300289.6338,2157739.1601 1300283.9026,2157756.4949 1300278.3586,2157768.0844 1300274.767,2157832.79 1300254.96,2157840.5087 1300252.6538,2157848.2469 1300250.4217,2157856.0086 1300248.2727,2157861.54 1300246.7963,2157861.2364 1300359.5708,2157860.9841 1300453.2594,2157860.9267 1300474.6074,2157860.8459 1300504.6075,2157860.4951 1300634.9118,2157860.2522 1300725.1224,2157859.9014 1300855.4267,2157859.5506 1300985.7309,2157859.1728 1301126.0586,2157858.4847 1301381.6555,2157857.68 1301680.5534,2157852.8479 1301875,2157821.7769 1303125.3199,2157809.2261 1303630.3699,2157804.3474 1303826.6899,2157799.2359 1304032.3799,2157792.81 1304290.96,2157784.56 1304623.33)),((2156327.9654947 1308019.52779376,2156497.6313 1308136.4024,2156497.8238 1308136.5626,2156498.0141 1308136.6661,2156871.1135845 1308393.77328742,2156862.31 1308005.06,2156327.9654947 1308019.52779376)))
') as shape ) as b
