[geos-devel] Problems to compile under SPARC Station
strk at refractions.net
Wed Sep 22 16:41:35 EDT 2004
On Wed, Sep 22, 2004 at 01:28:20PM -0700, Paul Ramsey wrote:
> I think a 2.0.1 release would not hurt, comments?
> P
The more numbers we add after the initial 2
the more relaxed we'll feel when it comes to increment it :)
--strk;
> strk at refractions.net wrote:
> >I think Paul Ramsey has fixed this.
> >Pull down CVS version or extract a 2.0.0 patch .
> >--strk;
> >On Wed, Sep 22, 2004 at 01:28:42PM -0300, Marco Vieira wrote:
> >>Hi all
> >> I´m trying to compile GEOS 2.0.0 in a Sun Ultra-5 Sparc station with
> >>Debian 3.0 and I'm geting the following error in the Make process:
> >># I followed the instructions of the README: my /usr/local/lib are OK and
> >>I runned ldconfig.
> >># The ./configure appear to runs well.
> >>rfserver:/home/marco/download/install/geos-2.0.0# make >make_out.txt
> >>In file included from Geometry.cpp:171:
> >>../../source/headers/geos/version.h:9: warning: `GEOS_VERSION' redefined
> >>*Initialization*:1: warning: this is the location of the previous
> >>definition
> >>LineString.cpp: In method `bool geos::LineString::isSimple() const':
> >>LineString.cpp:221: comparison of distinct pointer types `geos::Geometry
> >>*' and `const geos::LineString *' lacks a cast
> >>make[2]: *** [LineString.lo] Error 1
> >>make[1]: *** [all-recursive] Error 1
> >>make: *** [all-recursive] Error 1
> >> Does any one knows whats up?
> >>Marco Vieira.
> >>Fone: + 55 51 9101-1267
> >>marco_vieira at uk2.net
> >>Making all in source
> >>make[1]: Entering directory
> >>`/home/marco/download/install/geos-2.0.0/source'
> >>Making all in geom
> >>make[2]: Entering directory
> >>`/home/marco/download/install/geos-2.0.0/source/geom'
> >>source='Coordinate.cpp' object='Coordinate.lo' libtool=yes \
> >>depfile='.deps/Coordinate.Plo' tmpdepfile='.deps/Coordinate.TPlo' \
> >>depmode=gcc /bin/sh ../../depcomp \
> >>/bin/sh ../../libtool --mode=compile g++ -DHAVE_CONFIG_H -I. -I.
> >>-I../../source/headers -I../../source/headers/geos -I../../source/headers
> >>-DGEOS_VERSION=""2.0.0"" -g -O2 -c -o Coordinate.lo `test -f
> >>'Coordinate.cpp' || echo './'`Coordinate.cpp
> >>mkdir .libs
> >>g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
> >>-I../../source/headers/geos -I../../source/headers -DGEOS_VERSION=2.0.0
> >>-g -O2 -c Coordinate.cpp -Wp,-MD,.deps/Coordinate.TPlo -fPIC -DPIC -o
> >>.libs/Coordinate.o
> >>-g -O2 -c Coordinate.cpp -Wp,-MD,.deps/Coordinate.TPlo -o Coordinate.o
> >>>/dev/null 2>&1
> >>source='CoordinateSequence.cpp' object='CoordinateSequence.lo'
> >>libtool=yes \
> >>depfile='.deps/CoordinateSequence.Plo'
> >>tmpdepfile='.deps/CoordinateSequence.TPlo' \
> >>-DGEOS_VERSION=""2.0.0"" -g -O2 -c -o CoordinateSequence.lo `test -f
> >>'CoordinateSequence.cpp' || echo './'`CoordinateSequence.cpp
> >>-g -O2 -c CoordinateSequence.cpp -Wp,-MD,.deps/CoordinateSequence.TPlo
> >>-fPIC -DPIC -o .libs/CoordinateSequence.o
> >>-g -O2 -c CoordinateSequence.cpp -Wp,-MD,.deps/CoordinateSequence.TPlo -o
> >>CoordinateSequence.o >/dev/null 2>&1
> >>source='CoordinateSequenceFactory.cpp'
> >>object='CoordinateSequenceFactory.lo' libtool=yes \
> >>depfile='.deps/CoordinateSequenceFactory.Plo'
> >>tmpdepfile='.deps/CoordinateSequenceFactory.TPlo' \
> >>-DGEOS_VERSION=""2.0.0"" -g -O2 -c -o CoordinateSequenceFactory.lo
> >>`test -f 'CoordinateSequenceFactory.cpp' || echo
> >>'./'`CoordinateSequenceFactory.cpp
> >>-g -O2 -c CoordinateSequenceFactory.cpp
> >>-Wp,-MD,.deps/CoordinateSequenceFactory.TPlo -fPIC -DPIC -o
> >>.libs/CoordinateSequenceFactory.o
> >>-Wp,-MD,.deps/CoordinateSequenceFactory.TPlo -o
> >>CoordinateSequenceFactory.o >/dev/null 2>&1
> >>source='DefaultCoordinateSequence.cpp'
> >>object='DefaultCoordinateSequence.lo' libtool=yes \
> >>depfile='.deps/DefaultCoordinateSequence.Plo'
> >>tmpdepfile='.deps/DefaultCoordinateSequence.TPlo' \
> >>-DGEOS_VERSION=""2.0.0"" -g -O2 -c -o DefaultCoordinateSequence.lo
> >>`test -f 'DefaultCoordinateSequence.cpp' || echo
> >>'./'`DefaultCoordinateSequence.cpp
> >>-g -O2 -c DefaultCoordinateSequence.cpp
> >>-Wp,-MD,.deps/DefaultCoordinateSequence.TPlo -fPIC -DPIC -o
> >>.libs/DefaultCoordinateSequence.o
> >>-Wp,-MD,.deps/DefaultCoordinateSequence.TPlo -o
> >>DefaultCoordinateSequence.o >/dev/null 2>&1
> >>source='DefaultCoordinateSequenceFactory.cpp'
> >>object='DefaultCoordinateSequenceFactory.lo' libtool=yes \
> >>depfile='.deps/DefaultCoordinateSequenceFactory.Plo'
> >>tmpdepfile='.deps/DefaultCoordinateSequenceFactory.TPlo' \
> >>DefaultCoordinateSequenceFactory.lo `test -f
> >>'DefaultCoordinateSequenceFactory.cpp' || echo
> >>'./'`DefaultCoordinateSequenceFactory.cpp
> >>-g -O2 -c DefaultCoordinateSequenceFactory.cpp
> >>-Wp,-MD,.deps/DefaultCoordinateSequenceFactory.TPlo -fPIC -DPIC -o
> >>.libs/DefaultCoordinateSequenceFactory.o
> >>-Wp,-MD,.deps/DefaultCoordinateSequenceFactory.TPlo -o
> >>DefaultCoordinateSequenceFactory.o >/dev/null 2>&1
> >>source='PointCoordinateSequenceFactory.cpp'
> >>object='PointCoordinateSequenceFactory.lo' libtool=yes \
> >>depfile='.deps/PointCoordinateSequenceFactory.Plo'
> >>tmpdepfile='.deps/PointCoordinateSequenceFactory.TPlo' \
> >>PointCoordinateSequenceFactory.lo `test -f
> >>'PointCoordinateSequenceFactory.cpp' || echo
> >>'./'`PointCoordinateSequenceFactory.cpp
> >>-g -O2 -c PointCoordinateSequenceFactory.cpp
> >>-Wp,-MD,.deps/PointCoordinateSequenceFactory.TPlo -fPIC -DPIC -o
> >>.libs/PointCoordinateSequenceFactory.o
> >>-Wp,-MD,.deps/PointCoordinateSequenceFactory.TPlo -o
> >>PointCoordinateSequenceFactory.o >/dev/null 2>&1
> >>source='PointCoordinateSequence.cpp' object='PointCoordinateSequence.lo'
> >>libtool=yes \
> >>depfile='.deps/PointCoordinateSequence.Plo'
> >>tmpdepfile='.deps/PointCoordinateSequence.TPlo' \
> >>-DGEOS_VERSION=""2.0.0"" -g -O2 -c -o PointCoordinateSequence.lo `test
> >>-f 'PointCoordinateSequence.cpp' || echo './'`PointCoordinateSequence.cpp
> >>-g -O2 -c PointCoordinateSequence.cpp
> >>-Wp,-MD,.deps/PointCoordinateSequence.TPlo -fPIC -DPIC -o
> >>.libs/PointCoordinateSequence.o
> >>-Wp,-MD,.deps/PointCoordinateSequence.TPlo -o PointCoordinateSequence.o
> >>>/dev/null 2>&1
> >>source='Dimension.cpp' object='Dimension.lo' libtool=yes \
> >>depfile='.deps/Dimension.Plo' tmpdepfile='.deps/Dimension.TPlo' \
> >>-DGEOS_VERSION=""2.0.0"" -g -O2 -c -o Dimension.lo `test -f
> >>'Dimension.cpp' || echo './'`Dimension.cpp
> >>-g -O2 -c Dimension.cpp -Wp,-MD,.deps/Dimension.TPlo -fPIC -DPIC -o
> >>.libs/Dimension.o
> >>-g -O2 -c Dimension.cpp -Wp,-MD,.deps/Dimension.TPlo -o Dimension.o
> >>>/dev/null 2>&1
> >>source='Envelope.cpp' object='Envelope.lo' libtool=yes \
> >>depfile='.deps/Envelope.Plo' tmpdepfile='.deps/Envelope.TPlo' \
> >>-DGEOS_VERSION=""2.0.0"" -g -O2 -c -o Envelope.lo `test -f
> >>'Envelope.cpp' || echo './'`Envelope.cpp
> >>-g -O2 -c Envelope.cpp -Wp,-MD,.deps/Envelope.TPlo -fPIC -DPIC -o
> >>.libs/Envelope.o
> >>-g -O2 -c Envelope.cpp -Wp,-MD,.deps/Envelope.TPlo -o Envelope.o
> >>>/dev/null 2>&1
> >>source='Geometry.cpp' object='Geometry.lo' libtool=yes \
> >>depfile='.deps/Geometry.Plo' tmpdepfile='.deps/Geometry.TPlo' \
> >>-DGEOS_VERSION=""2.0.0"" -g -O2 -c -o Geometry.lo `test -f
> >>'Geometry.cpp' || echo './'`Geometry.cpp
> >>-g -O2 -c Geometry.cpp -Wp,-MD,.deps/Geometry.TPlo -fPIC -DPIC -o
> >>.libs/Geometry.o
> >>-g -O2 -c Geometry.cpp -Wp,-MD,.deps/Geometry.TPlo -o Geometry.o
> >>>/dev/null 2>&1
> >>source='GeometryCollection.cpp' object='GeometryCollection.lo'
> >>libtool=yes \
> >>depfile='.deps/GeometryCollection.Plo'
> >>tmpdepfile='.deps/GeometryCollection.TPlo' \
> >>-DGEOS_VERSION=""2.0.0"" -g -O2 -c -o GeometryCollection.lo `test -f
> >>'GeometryCollection.cpp' || echo './'`GeometryCollection.cpp
> >>-g -O2 -c GeometryCollection.cpp -Wp,-MD,.deps/GeometryCollection.TPlo
> >>-fPIC -DPIC -o .libs/GeometryCollection.o
> >>-g -O2 -c GeometryCollection.cpp -Wp,-MD,.deps/GeometryCollection.TPlo -o
> >>GeometryCollection.o >/dev/null 2>&1
> >>source='GeometryCollectionIterator.cpp'
> >>object='GeometryCollectionIterator.lo' libtool=yes \
> >>depfile='.deps/GeometryCollectionIterator.Plo'
> >>tmpdepfile='.deps/GeometryCollectionIterator.TPlo' \
> >>-DGEOS_VERSION=""2.0.0"" -g -O2 -c -o GeometryCollectionIterator.lo
> >>`test -f 'GeometryCollectionIterator.cpp' || echo
> >>'./'`GeometryCollectionIterator.cpp
> >>-g -O2 -c GeometryCollectionIterator.cpp
> >>-Wp,-MD,.deps/GeometryCollectionIterator.TPlo -fPIC -DPIC -o
> >>.libs/GeometryCollectionIterator.o
> >>-Wp,-MD,.deps/GeometryCollectionIterator.TPlo -o
> >>GeometryCollectionIterator.o >/dev/null 2>&1
> >>source='GeometryComponentFilter.cpp' object='GeometryComponentFilter.lo'
> >>libtool=yes \
> >>depfile='.deps/GeometryComponentFilter.Plo'
> >>tmpdepfile='.deps/GeometryComponentFilter.TPlo' \
> >>-DGEOS_VERSION=""2.0.0"" -g -O2 -c -o GeometryComponentFilter.lo `test
> >>-f 'GeometryComponentFilter.cpp' || echo './'`GeometryComponentFilter.cpp
> >>-g -O2 -c GeometryComponentFilter.cpp
> >>-Wp,-MD,.deps/GeometryComponentFilter.TPlo -fPIC -DPIC -o
> >>.libs/GeometryComponentFilter.o
> >>-Wp,-MD,.deps/GeometryComponentFilter.TPlo -o GeometryComponentFilter.o
> >>>/dev/null 2>&1
> >>source='GeometryFactory.cpp' object='GeometryFactory.lo' libtool=yes \
> >>depfile='.deps/GeometryFactory.Plo'
> >>tmpdepfile='.deps/GeometryFactory.TPlo' \
> >>-DGEOS_VERSION=""2.0.0"" -g -O2 -c -o GeometryFactory.lo `test -f
> >>'GeometryFactory.cpp' || echo './'`GeometryFactory.cpp
> >>-g -O2 -c GeometryFactory.cpp -Wp,-MD,.deps/GeometryFactory.TPlo -fPIC
> >>-DPIC -o .libs/GeometryFactory.o
> >>-g -O2 -c GeometryFactory.cpp -Wp,-MD,.deps/GeometryFactory.TPlo -o
> >>GeometryFactory.o >/dev/null 2>&1
> >>source='IntersectionMatrix.cpp' object='IntersectionMatrix.lo'
> >>libtool=yes \
> >>depfile='.deps/IntersectionMatrix.Plo'
> >>tmpdepfile='.deps/IntersectionMatrix.TPlo' \
> >>-DGEOS_VERSION=""2.0.0"" -g -O2 -c -o IntersectionMatrix.lo `test -f
> >>'IntersectionMatrix.cpp' || echo './'`IntersectionMatrix.cpp
> >>-g -O2 -c IntersectionMatrix.cpp -Wp,-MD,.deps/IntersectionMatrix.TPlo
> >>-fPIC -DPIC -o .libs/IntersectionMatrix.o
> >>-g -O2 -c IntersectionMatrix.cpp -Wp,-MD,.deps/IntersectionMatrix.TPlo -o
> >>IntersectionMatrix.o >/dev/null 2>&1
> >>source='LinearRing.cpp' object='LinearRing.lo' libtool=yes \
> >>depfile='.deps/LinearRing.Plo' tmpdepfile='.deps/LinearRing.TPlo' \
> >>-DGEOS_VERSION=""2.0.0"" -g -O2 -c -o LinearRing.lo `test -f
> >>'LinearRing.cpp' || echo './'`LinearRing.cpp
> >>-g -O2 -c LinearRing.cpp -Wp,-MD,.deps/LinearRing.TPlo -fPIC -DPIC -o
> >>.libs/LinearRing.o
> >>-g -O2 -c LinearRing.cpp -Wp,-MD,.deps/LinearRing.TPlo -o LinearRing.o
> >>>/dev/null 2>&1
> >>source='LineSegment.cpp' object='LineSegment.lo' libtool=yes \
> >>depfile='.deps/LineSegment.Plo' tmpdepfile='.deps/LineSegment.TPlo' \
> >>-DGEOS_VERSION=""2.0.0"" -g -O2 -c -o LineSegment.lo `test -f
> >>'LineSegment.cpp' || echo './'`LineSegment.cpp
> >>-g -O2 -c LineSegment.cpp -Wp,-MD,.deps/LineSegment.TPlo -fPIC -DPIC -o
> >>.libs/LineSegment.o
> >>-g -O2 -c LineSegment.cpp -Wp,-MD,.deps/LineSegment.TPlo -o LineSegment.o
> >>>/dev/null 2>&1
> >>source='LineString.cpp' object='LineString.lo' libtool=yes \
> >>depfile='.deps/LineString.Plo' tmpdepfile='.deps/LineString.TPlo' \
> >>-DGEOS_VERSION=""2.0.0"" -g -O2 -c -o LineString.lo `test -f
> >>'LineString.cpp' || echo './'`LineString.cpp
> >>-g -O2 -c LineString.cpp -Wp,-MD,.deps/LineString.TPlo -fPIC -DPIC -o
> >>.libs/LineString.o
> >>make[2]: Leaving directory
> >>make[1]: Leaving directory
> >>_______________________________________________
> >>geos-devel mailing list
> >>geos-devel at geos.refractions.net
> >>http://geos.refractions.net/mailman/listinfo/geos-devel
