[geos-devel] GEOS Exceptions
Chris Hodgson
chodgson at refractions.net
Tue Apr 19 12:39:08 EDT 2005
OK, that makes more sense to me then... sorry for the confusion...
Chris
strk at refractions.net wrote:
>On Tue, Apr 19, 2005 at 09:34:11AM -0700, Chris Hodgson wrote:
>>>In section 8.3 they have an EMPTY value, something like this:
>>>PRIMARY
>>>= OPTIONAL SEQUENCE / REPEATED SEQUENCE
>>>/ SPECIAL SEQUENCE / GROUPED SEQUENCE
>>>/ META IDENTIFIER / TERMINAL / EMPTY.
>>>EMPTY = .
>>If the spec says this as quoted above, then this does in fact mean that
>>EMPTY means nothing.
>>It literally says, EMPTY equals nothing, period. I haven't looked at the
>>rest of the spec, but there's nothing ambiguous about it here, IMHO.
>That's not OGC SFS spec, but an example in the EBFN spec.
>I think you're right here because EMPTY is defined.
>OGS SFS does not define EMPTY, and use <bracketed> strings
>for defined things.
>--strk;
>_______________________________________________
>geos-devel mailing list
>geos-devel at geos.refractions.net
>http://geos.refractions.net/mailman/listinfo/geos-devel
