[geos-devel] ABI/API status and future development thougths
strk at refractions.net strk at refractions.net
Thu Apr 21 12:19:03 EDT 2005
On Thu, Apr 21, 2005 at 05:12:16PM +0100, Artem Pavlenko wrote:
> HI strk
> Great to see GEOS is moving at last
> I'll have a look at new changes over this weekend. I'm really into
> having GEOS3 as new effort, and maybe keep GEOS2 as a compatibility
> branch?.
> It looks like *a lot* can be done even after you apply Dale's  patches.
> One thing that keeps popping out, is a different
> 'geometry models' in use, and it is a clearly  'slow-down' factor in
> GEOS (clients need to convert their geometries into geos ones and
> possibly back). There might be a smart way to address all that, but it
> will need radical changes. Shall we have a discussion about 'geometry
> model'?
If you have a "smart way" handy why not ?
We are at a storming phase anyway.
--strk;
> Anyway, good news!
> Artem
> strk at refractions.net wrote:
> >I just updated the NEWS file and made a simple
> >test to inspect compatibility between 2.1.1 and
> >current CVS.
> >Well, ABI is broken already. Probably due to
> >inlining of some functions aimed at improving
> >performance.
> >On the other hand, the part of API used by
> >postgis is still intact (ie. requires recompilation
> >but then works fine). Postgis uses about all of
> >Geometry methods and many CoordinateSequence methods.
> >With the help of ChangeLog I might attempt at taking
> >the ABI back to compatible with 2.1.1. That might allow
> >us to release a 2.1.2 slightly faster then 2.1.1 but not
> >significantly as inlines made the big difference.
> >Alternatively we can give the ABI break for granted and
> >go on with optimizzation continuing with inlines.
> >This is for ABI.
> >About API. Breaking that means you won't be able to build
> >old packages using GEOS using new relese of GEOS.
> >For example, postgis-1.0.0 won't be able to use a new GEOS
> >iff it will throw exceptions by ref instead of by pointers.
> >This is just an example, and is the wider one, as the GEOS
> >interface is pretty big and brokage can happen at different
> >levels of "deepness". For example current GEOS CVS has a
> >different interface on BufferSubgraph, but 'simple' clients
> >won't use BufferSubgraph directly, nor is its interface
> >documented (I had care to cut-down documentation specifically
> >for this purpose in previous releases). This means that simple
> >clients will continue to work with this change but more
> >complex ones will need to be modified to support new API and
> >introduce some kind of compile-time switch based on GEOS version
> >to support multiple GEOS interfaces.
> >Sorry if I'm being long and boring but I think having this written
> >helps everybody taking a decision. I'm bound to good quality but
> >I know the hassles of ever-changing interfaces (instability).
> >Whatever we decide to do I think a good approach would be providing
> >some form of simplified interface to GEOS for use by clients, aimed
> >at giving the hard-to-maintain stability of both API and ABI.
> >This could be a shared library shipped with GEOS and acting as
> >an 'adapter' between the always-moving GEOS lib and the client code
> >keeping the ->GEOS interface in sync with GEOS and the ->user interface
> >as stable as possible.
> >I've made a first implementation of such an adapter for JTS, providing
> >JTS access to C/C++ code in a stabler fashion (reduced API, abstract
> >datatype and garbage collector basically). I envision the GEOS
> >counterpart to follow that effort, althought garbage collection would be
> >harder to do (it's there for free with libgcj - the GNU java lib).
> >So what I'm saying is that next GEOS release could provide this wrapper
> >and client code willing to stop this annoyances could link against the
> >wrapper instead of against the main lib. One other advantages of this
> >would be that choice between GEOS and JTS would be a matter of a single
> >define to change function prefixes.
> >Implementation costs in this direction would be:
> >	- porting the WKB parser
> >	- intergaring the boheme garbage collector
> >Enough noise, I hope someone will actually read this :P
> >Every contribution on the topic is highly apprieciated!
> >--strk;
> >_______________________________________________
> >geos-devel mailing list
> >geos-devel at geos.refractions.net
> >http://geos.refractions.net/mailman/listinfo/geos-devel
