[geos-devel] ABI/API status and future development thougths
Chris Hodgson
chodgson at refractions.net
Thu Apr 21 13:26:30 EDT 2005
Strk, here's my input for you...
It seems like every change that anyone wants to make right now is going
to break ABI, so I say start a new branch, and stop worrying about it.
You have already identified the best way to prevent further ABI breakage
- the "compatibility layer", and switching everything over to using it
will effectively be an API breakage - so you might as well fit the other
API-breaking changes into the same branch (exception throwing, etc.). If
you plan these changes carefully, it should be possible to limit future
API breakage, perhaps by adding new/alternative functions instead of
replacing/breaking existing ones.
You might also want to think about what exactly the goals of GEOS are -
to continue to mirror JTS development, or to move away from the Java
roots and into a more optimized C++ implementation? I think that since
there now exists the GJC option for a direct JTS-to-C-compatible
compilation option, it makes more sense for GEOS to work towards being
more optimized for C++, while still sharing algorithm changes
back-and-forth with JTS.
I hope that's useful input...
Chris
strk at refractions.net wrote:
>I just updated the NEWS file and made a simple
>test to inspect compatibility between 2.1.1 and
>current CVS.
>Well, ABI is broken already. Probably due to
>inlining of some functions aimed at improving
>performance.
>On the other hand, the part of API used by
>postgis is still intact (ie. requires recompilation
>but then works fine). Postgis uses about all of
>Geometry methods and many CoordinateSequence methods.
>With the help of ChangeLog I might attempt at taking
>the ABI back to compatible with 2.1.1. That might allow
>us to release a 2.1.2 slightly faster then 2.1.1 but not
>significantly as inlines made the big difference.
>Alternatively we can give the ABI break for granted and
>go on with optimizzation continuing with inlines.
>This is for ABI.
>About API. Breaking that means you won't be able to build
>old packages using GEOS using new relese of GEOS.
>For example, postgis-1.0.0 won't be able to use a new GEOS
>iff it will throw exceptions by ref instead of by pointers.
>This is just an example, and is the wider one, as the GEOS
>interface is pretty big and brokage can happen at different
>levels of "deepness". For example current GEOS CVS has a
>different interface on BufferSubgraph, but 'simple' clients
>won't use BufferSubgraph directly, nor is its interface
>documented (I had care to cut-down documentation specifically
>for this purpose in previous releases). This means that simple
>clients will continue to work with this change but more
>complex ones will need to be modified to support new API and
>introduce some kind of compile-time switch based on GEOS version
>to support multiple GEOS interfaces.
>Sorry if I'm being long and boring but I think having this written
>helps everybody taking a decision. I'm bound to good quality but
>I know the hassles of ever-changing interfaces (instability).
>Whatever we decide to do I think a good approach would be providing
>some form of simplified interface to GEOS for use by clients, aimed
>at giving the hard-to-maintain stability of both API and ABI.
>This could be a shared library shipped with GEOS and acting as
>an 'adapter' between the always-moving GEOS lib and the client code
>keeping the ->GEOS interface in sync with GEOS and the ->user interface
>as stable as possible.
>I've made a first implementation of such an adapter for JTS, providing
>JTS access to C/C++ code in a stabler fashion (reduced API, abstract
>datatype and garbage collector basically). I envision the GEOS
>counterpart to follow that effort, althought garbage collection would be
>harder to do (it's there for free with libgcj - the GNU java lib).
>So what I'm saying is that next GEOS release could provide this wrapper
>and client code willing to stop this annoyances could link against the
>wrapper instead of against the main lib. One other advantages of this
>would be that choice between GEOS and JTS would be a matter of a single
>define to change function prefixes.
>Implementation costs in this direction would be:
> - porting the WKB parser
> - intergaring the boheme garbage collector
>Enough noise, I hope someone will actually read this :P
>Every contribution on the topic is highly apprieciated!
>--strk;
>_______________________________________________
>geos-devel mailing list
>geos-devel at geos.refractions.net
>http://geos.refractions.net/mailman/listinfo/geos-devel
