[geos-devel] problem with GEOS buffer(0) -- JTS works
strk at refractions.net strk at refractions.net
Mon Aug 22 07:23:30 EDT 2005
I confirm the bug. It seems a vector being sorted contains
a corrupted pointer... I'm working on it.
--strk;
On Fri, Aug 19, 2005 at 07:24:05PM -0400, dblasby at openplans.org wrote:
> I tried to buffer (ie. union) these two giant multipolygons.  Both
> worked in JTS in less than 200mb of memory.
> Both crashed PostGIS.  The FJ multipolygon crashes Postgresql almost
> immediately.  The RS multipolygon takes a while and crashes when it
> gets to about 500mb of memory usage.  See attached .zip.
> POSTGIS="1.0.3" GEOS="2.1.3" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
> DBPROC="0.3.0" RELPROC="0.3.0"
> dave
> NOTE: these are really geometrycollections of polygons instead of true
> multipolygons.
> This mail sent through IMP: https://webmail.limegroup.com/
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
