[geos-devel] MingW build (was: autotools problems)
strk at refractions.net
Thu Dec 8 05:06:46 EST 2005
Mike, Charles,
please try this *temporary* package:
http://geos.refractions.net/geos-2.2.1CVS.tar.gz
--strk;
On Thu, Dec 08, 2005 at 02:22:07AM -0500, Mike Leahy wrote:
> Hello,
> I'm just adding to this, because I ran into troubles compiling
> geos-2.2.0 today using msys/mingw. I found this post in this list, and
> tried various combinations of the suggested solution. What I found did
> work was "LDFLAGS=-no-undefined ./configure <options>", after which
> make/make install ran fine. However, if I uncommented
> AC_LIBTOOL_WIN32_DLL in configure.in as suggested, that seemed to cause
> problems when I tried to run make (see errors below). I suppose it
> could be out of date msys/mingw installations...I'm not really sure. I
> used msys-1.0.10 and mingw-4.1.0, and after running into this problem,
> updated the automake and autoconf binaries...same results.
> I'm guessing that if I got it to work without uncommenting
> AC_LIBTOOL_WIN32_DLL, then I should be happy and just move on...am I wrong?
> Regards,
> Mike
> $ make
> cd . && /bin/sh /Downloads/geos-2.2.0/missing --run aclocal-1.9
> Can't locate Automake/Config.pm in @INC (@INC contains: C
> /mingw/AutoMake/share/automake-1.9 /usr/lib/perl5/5.6.1/msys
> /usr/lib/perl5/5.6.1 /usr/lib/perl5/site_perl/5.6.1/msys
> /usr/lib/perl5/site_perl/5.6.1 /usr/lib/perl5/site_perl .) at
> /mingw/bin/aclocal-1.9 line 36.
> BEGIN failed--compilation aborted at /mingw/bin/aclocal-1.9 line 36.
> WARNING: `aclocal-1.9' is missing on your system. You should only need
> it if
> you modified `acinclude.m4' or `configure.in'. You might want
> to install the `Automake' and `Perl' packages. Grab them from
> any GNU archive site.
> cd . && /bin/sh /Downloads/geos-2.2.0/missing --run automake-1.9 --gnu
> Can't locate Automake/Struct.pm in @INC (@INC contains: C
> /mingw/bin/automake-1.9 line 47.
> BEGIN failed--compilation aborted at /mingw/bin/automake-1.9 line 47.
> WARNING: `automake-1.9' is missing on your system. You should only need
> it if
> you modified `Makefile.am', `acinclude.m4' or `configure.in'.
> You might want to install the `Automake' and `Perl' packages.
> Grab them from any GNU archive site.
> cd . && /bin/sh /Downloads/geos-2.2.0/missing --run autoconf
> /mingw/bin/autoconf:
> /Downloads/geos-2.2.0/c:/progra~1/AutoConf/bin/autom4te: No such file or
> directory
> /mingw/bin/autoconf: exec:
> /Downloads/geos-2.2.0/c:/progra~1/AutoConf/bin/autom4te: cannot execute:
> No such file or directory
> make: *** [configure] Error 1
> strk at refractions.net strk at refractions.net
> Wed Dec 7 10:49:59 PST 2005
> * Previous message: [geos-devel] autotools problems
> * Next message: [geos-devel] call for 2.2.1
> * Messages sorted by: [ date ] [ thread ] [ subject ] [ author ]
> Ok, thanks to Mark we fixed the MingW issue by:
> - Uncommenting AC_LIBTOOL_WIN32_DLL in configure.in
> - Adding -no-undefined to LDFLAGS for both C++ and C lib
> Additionally we added acsite.m4 to the distribution, so future
> users will be able to regenerate build scripts.
> This calls for 2.2.1 - see 2.2.1 mail (coming next).
> --strk;
> On Fri, Dec 02, 2005 at 02:10:03PM +0100, strk at refractions.net wrote:
> > Guys, I need some help with the Makefile.am
> > under source/capi (the new CAPI thing).
> > I'm really unsure of wheter it is constructed
> > correctly. As a matter of fact I've hade report
> > of failures for MingW builds.
> > The point is building a library and a program.
> > The library is libgeos_c.
> > The program is geostest.
> > libgeos_c depends (links against) libgeos.
> > geostest depends (links against) libgeos_c.
> > Current Makefile.am is as follows:
> > ----8<--------------------------------------------------
> > prefix=@prefix@
> > top_srcdir=@top_srcdir@
> > GEOS_CAPI_VERSION="@VERSION at -CAPI- at CAPI_VERSION@"
> > noinst_PROGRAMS = geostest
> > geostest_SOURCES = geostest.c
> > #geostest_LDADD = libgeos_c.la
> > geostest_LDADD = $(top_builddir)/source/geom/libgeos.la libgeos_c.la
> > geostest_INCLUDES = -I.
> > capidir = $(includedir)
> > nodist_capi_HEADERS = \
> > geos_c.h
> > lib_LTLIBRARIES = libgeos_c.la
> > LIBS = $(top_builddir)/source/geom/libgeos.la
> > DIR_SOURCES = \
> > geos_c.cpp
> > libgeos_c_la_SOURCES = $(DIR_SOURCES)
> > libgeos_c_la_CPPFLAGS = -DGEOS_CAPI_VERSION='$(GEOS_CAPI_VERSION)'
> > libgeos_c_la_LDFLAGS = -version-info
> @CAPI_INTERFACE_CURRENT@:@CAPI_INTERFACE_REVISION@:@CAPI_INTERFACE_AGE@
> > dist-local:
> > cp -p $(DIST_SOURCES) Makefile.am Makefile.in $(distdir)
> > MingW build report show a WARNING at libgeos_c.la build:
> > *** Warning: This system can not link to static lib archive
> ../../source/geom/libgeos.la.
> > *** I have the capability to make that library automatically link in when
> > *** you link to this library. But I can only do this if you have a
> > *** shared version of the library, which you do not appear to have.
> > libtool: link: warning: undefined symbols not allowed in
> i686-pc-mingw32 shared libraries
> > And a lots of "undefined reference" error at geostest build, where
> > undefined symbols seems the ones in libstdc++.
> > Any successful MingW builder here, or does the Makefile.am looks fine ?
> > --strk;
> > /"\ ASCII Ribbon Campaign
> > \ / Respect for open standards
> > X No HTML/RTF in email
> > / \ No M$ Word docs in email
> > geos-devel mailing list
> > geos-devel at geos.refractions.net
> > http://geos.refractions.net/mailman/listinfo/geos-devel
> \ / Respect for low technology.
> X Keep e-mail messages readable by any computer system.
> / \ Keep it ASCII.
/ \ Keep it ASCII.
