[geos-devel] Re: freeBSD ports GEOS
strk at refractions.net
Sun Dec 11 20:09:33 EST 2005
On Mon, Dec 12, 2005 at 01:08:02AM +0100, Konstantin Saurbier wrote:
> strk at refractions.net wrote on Mon Dec 12, 2005 um 12:49:12AM:
> > On Sat, Dec 10, 2005 at 07:39:44PM +0100, Konstantin Saurbier wrote:
> > > Be adviced that geos will not compile on FreeBSD 4.x. I will contact the
> > > GEOS developers later on, but i had no time until now.
> > I successfully build 2.2.1 (out tomorrow) with g++ (GCC) 3.4.4.
> > I confirm that libgeos.so comes out versioned as .4 (libgeos.so.4)
> > SONAME sems to be libgeos.so.4 but didn't have readelf(1) available
> > to check this.
> This sounds very good. I will write a patch for the geos port as soon as
> the new version will be out. Very nice and fast work :-)
> Thank you very much!
Note that I haven't done anything, it just built.
Note also that 2.95.2 didn't make it.
--strk;
