[geos-devel] JTS/GEOS performance - smart-ptr vs ref counting
Norman Vine nhv at cape.com
Tue Feb 1 01:34:25 EST 2005
Chapman, Martin writes:
> I don't think storing points in an stl vector is the problem.  I think the problem is definitely the copying of the point
> arrays many times, and allocating/deallocating lots of objects in every loop.
*exactly*  this I believe comes about by trying to emulate Java in C++
in order to keep the code base 'similar'
< There was some good discussion on this back in Nov 2002 >
Cheers
Norman
