[geos-devel] cygwin Compile Error
Mark Coletti
mcoletti at gmail.com
Wed Feb 16 17:28:57 EST 2005
On Wed, 16 Feb 2005 17:15:22 -0500, Jon Schlueter
<jon.schlueter at gmail.com> wrote:
> I'm using cygwin under windows xp pro
> $ gcc -v
> Reading specs from /usr/lib/gcc-lib/i686-pc-cygwin/3.3.3/specs
> Configured with: /gcc/gcc-3.3.3-3/configure --verbose --prefix=/usr
> --exec-prefix=/usr --sysconfdir=/etc --libdir=/usr/lib
> --libexecdir=/usr/lib --mandir=/usr/share/man
> --infodir=/usr/share/info
> --enable-languages=c,ada,c++,d,f77,java,objc,
> pascal --enable-nls --without-included-gettext --enable-libgcj
> --with-system-zlib --enable-interpreter --enable-threads=posix
> --enable-java-gc=boehm --enable-sjlj-exceptions
> --disable-version-specific-runtime-libs --disable-win32-registry
> Thread model: posix
> gcc version 3.3.3 (cygwin special)
> I just pulled down the CVS version of geos from CVS
> I configured it and then tried compiling when I hit this error
> Jonschl at Endemion ~/geos-cvs/geos/source/geom
> $ make
> if /bin/bash ../../libtool --mode=compile --tag=CXX g++
> -DHAVE_CONFIG_H -I. -I. -I../../source/headers -I../../source/he
> aders/geos -I../../source/headers -DGEOS_VERSION=""2.1.1"" -g -O2
> -MT CommonBits.lo -MD -MP -MF ".deps/CommonBits.Tpo
> " -c -o CommonBits.lo `test -f '../precision/CommonBits.cpp' || echo
> './'`../precision/CommonBits.cpp; \
> then mv -f ".deps/CommonBits.Tpo" ".deps/CommonBits.Plo"; else rm -f
> ".deps/CommonBits.Tpo"; exit 1; fi
> g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
> -I../../source/headers/geos -I../../source/headers -DGEOS_VERSION=2.
> 1.1 -g -O2 -MT CommonBits.lo -MD -MP -MF .deps/CommonBits.Tpo -c
> ../precision/CommonBits.cpp -DPIC -o .libs/CommonBits.
> o
> In file included from /usr/include/c++/3.3.3/cmath:51,
> from /usr/include/c++/3.3.3/bits/locale_facets.tcc:41,
> from /usr/include/c++/3.3.3/locale:47,
> from /usr/include/c++/3.3.3/bits/ostream.tcc:37,
> from /usr/include/c++/3.3.3/ostream:535,
> from /usr/include/c++/3.3.3/iostream:45,
> from ../../source/headers/geos/geom.h:20,
> from ../../source/headers/geos/precision.h:54,
> from ../precision/CommonBits.cpp:27:
> /usr/include/ieeefp.h:185: error: previous declaration of `int isnan(double)'
> with C++ linkage
> /usr/include/math.h:125: error: conflicts with new declaration with C linkage
> /usr/include/ieeefp.h:186: error: previous declaration of `int isinf(double)'
> with C++ linkage
> /usr/include/math.h:126: error: conflicts with new declaration with C linkage
> /usr/include/ieeefp.h:187: error: previous declaration of `int finite(double)'
> with C++ linkage
> /usr/include/math.h:127: error: conflicts with new declaration with C linkage
> /usr/include/ieeefp.h:191: error: previous declaration of `int isnanf(float)'
> with C++ linkage
> /usr/include/math.h:240: error: conflicts with new declaration with C linkage
> /usr/include/ieeefp.h:192: error: previous declaration of `int isinff(float)'
> with C++ linkage
> /usr/include/math.h:241: error: conflicts with new declaration with C linkage
> /usr/include/ieeefp.h:193: error: previous declaration of `int finitef(float)'
> with C++ linkage
> /usr/include/math.h:242: error: conflicts with new declaration with C linkage
> make: *** [CommonBits.lo] Error 1
> I did a little bit of digging and found the following patch fixed the
> compile error
> $ cvs diff -ub
> cvs diff: Diffing .
> Index: geom.h
> RCS file: /home/cvs/postgis/geos/source/headers/geos/geom.h,v
> retrieving revision 1.38
> diff -u -b -r1.38 geom.h
> --- geom.h 15 Feb 2005 17:15:13 -0000 1.38
> +++ geom.h 16 Feb 2005 22:25:34 -0000
> @@ -22,7 +22,7 @@
> #include <vector>
> #include <algorithm>
> #include <map>
> -#include <math.h>
> +#include <cmath>
> #include <geos/platform.h>
> using namespace std;
> Is this a known issue? or just on my system?
> Jon Schlueter
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
I had the same problem building in Ming/Msys, but did the far more inelegant
extern "C" {}
wrapper nonsense -- which is what cmath does behind the scenes..
I'm taking reality in small doses to build immunity.
